XM15
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=546
Printed Date: 27 March 2026 at 12:52am
Topic: XM15
Posted By: Andrew
Subject: XM15
Date Posted: 05 September 2004 at 2:46pm
Just tried out this unit, was almost as loud as the PA, but with a 75W/4R amp!  Response was pretty flat too.  Well impressed.  Just a tad heavy for me at 29.0kg.
Thanks for an excellent design Rog.
Posted By: Mal X
Date Posted: 06 September 2004 at 8:14pm
did you run them on the passive crossover or active?
Just wondering which to do myself.
Cheers Mal
Mal, how loud was that!!!!!!
Posted By: JD01
Date Posted: 06 September 2004 at 10:49pm
@ Andrew: An upper class 15" + HF wedge at 29kg is too heavy for you? Show me a cab with that performance that is constructed of wood and below that weight..... Even most commercial wedges are heavier than that....
Posted By: Tom Umney
Date Posted: 07 September 2004 at 2:55am
Yep u can get some moulded polyproplene wedge cabs with that excellent response  --- Yorkville and RCF ART series
Posted By: Andrew
Date Posted: 07 September 2004 at 12:43pm
The monitor is extremely solid.  Possible weight savings are to use a Neo driver for the horn, and slightly thinner ply, I used 13 laminate 18mm.
The performance is exceptional, even though I used the passive crossover, and a T-amp!
It is so good that I hope to try putting it up a tower one day near the sweet spot, to contrast with the £4K house PA system, just for a laugh!
Posted By: JD01
Date Posted: 07 September 2004 at 4:05pm
@ ToXiC: That's why I said 'constructed of wood' ;)
@ Andrew: Especially for 18mm laminate and 'non-neo' drivers 29kg is very lightweight. For a box like that 15mm laminate wood be good enough, but it wouldn't save THAT much. Neo drivers would be much better in weight terms, but they have some problems of their own...
Posted By: Andrew
Date Posted: 07 September 2004 at 5:01pm
I'm not aware of any problems with Neo drivers, other than the Bank Manager.  What are they?  My XM15 15" driver is a Neo, the horn driver is not.
I've built a 18mm HD15 with Eminence and two 15mm HD15 with P. Audio, and think the weight saving is worthwhile, for light duty use.
Posted By: JD01
Date Posted: 07 September 2004 at 5:07pm
Oh yeah, right, the 15" is of course a neo....
The problems with neodymium are that they can't take heat and they aren't shock-resistant. Both heat and shocks reduce the magnetic force with time. And neodymium loses its force faster than the conventional magnets even without using/'heating'/moving them....
The price difference isn't that big nowadays. Take a look at the 18Sound speakers. Neos are just a bit more expensive than conventional speakers and they make pretty good ones....
Posted By: Andrew
Date Posted: 07 September 2004 at 5:17pm
Has anyone lost say 3dB of output from a speaker, in practice, to due the various theoretical ways to reduce mangetism mentioned above?
Posted By: JD01
Date Posted: 07 September 2004 at 5:51pm
Yes, but this isn't happening from one day to another. It's a slow process. You even won't notice because it's only a tiny bit everytime.
With HF drivers some other issues come with losing magnetism. The response changes and highs get muddy and mushy....
Posted By: loophole
Date Posted: 07 September 2004 at 6:08pm
and i find neo compression drivers can often sound too harsh and strong motored.
but maybe thats just because we can't afford the sd750s that i really want...
