Just a musing really ... tiny LF horn ecnlosures ?
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=54924
Printed Date: 27 March 2026 at 8:46am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Just a musing really ... tiny LF horn ecnlosures ?
Posted By: slaz
Subject: Just a musing really ... tiny LF horn ecnlosures ?
Date Posted: 22 July 2011 at 11:16am
Well - any horn design bods here have a bit of time on their hands ?
Just wondering if the following is vaguely possible :-
Use 2 small drivers - 6.5" or so .... in some kind of push-pull arrangment to play down to about 60 ? 65 ? 70 ? - with _very_ high efficiency - in something with overall volume about that of a large suitcase.
There are some quite efficient mid drivers in that size (some neo = good from weight POV) - with Fs in the 70-80 range I think .... prob very low xmax ....... but they're all 8R (or 16) .... Being 8R puts amplifier power down to a tiny 10W per driver in my idea - yeah :-) - but could horn loading make up _that_ much ground in SPL at those kind of frequencies - in that kind of enclosure volume ?
I could do the trawling for drivers if anyone's curious enough to look into it ....
P.S. I should say "very high efficiency" compared to same driver performance in a BR box/whatever.
Posted By: darkmatter
Date Posted: 22 July 2011 at 12:48pm
food for thought:
http://www.volvotreter.de/dl-section.htm
http://www.diyaudio.com/forums/subwoofers/177690-ultraslim-tapped-horn.html
http://mirror2.avsforum.com/avs-vb/showthread.php?t=1329139
http://www.diysoundgroup.com/65_Tapped_Horn.htm
