staiper micro scoop question
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=56286
Printed Date: 27 March 2026 at 10:58am
Topic: staiper micro scoop question
Posted By: hmaudio
Subject: staiper micro scoop question
Date Posted: 28 August 2011 at 3:20pm
what exactly does this part do?
iv built 4 and iv not put that part on Confused
Posted By: eltron
Date Posted: 28 August 2011 at 8:35pm
It forms the throat. Notice the 110 mm measurement on the left!
Look at the super scooper plan for instance, you'll find the so called "dog leg" on it also.
Edit: I missed the last part of your post: If you left it out the throat has theoretically moved downwards in the horn (technically to the narrowest point), thus making the back chamber bigger and horn shorter.
Posted By: mobiele eenheid
Date Posted: 28 August 2011 at 9:47pm
Personally I'm not sure whether it will give you any noticeable difference (to your hearing that is). You could however glue it in there through the speaker cutt out, if you make it in two halves (in the length).
Best regards Johan
Posted By: hmaudio
Date Posted: 29 August 2011 at 12:26am
Thanks for the replies, il get some made up and see if i can hear any difference,
cheers
Adam
Posted By: phildat
Date Posted: 29 August 2011 at 10:49pm
Looks like it ensures positive expansion throughout the design.
Its just a ride.
Posted By: MINTEVENTRESOURCES
Date Posted: 01 March 2023 at 5:01pm
Was there a noticiable difference in performance by adding the dog leg?
Mint Event Resources
Posted By: stitchie
Date Posted: 11 June 2024 at 6:04pm
still got 4 of these built by you HMAudio really good sub cab for a 15" driver
