REW discrepancy
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=59278
Printed Date: 27 March 2026 at 2:15am
Topic: REW discrepancy
Posted By: soundchippy
Subject: REW discrepancy
Date Posted: 15 November 2011 at 12:38am
Hi all, i've been messing around with room eq wizard and a berry ecm on an old hifi speaker. i'm getting considerably different hf response between using 2 sweeps and 8 sweeps for measurement . |Blue icicle mic stage and generic usb card which i have calibrated using rew. Please see images below. any ideas why? (2 sweeps has better response).
Date Posted: 15 November 2011 at 1:12am
swapped for a different cab. 2/8 sweeps (new cab black(2) and purple(8))
Date Posted: 15 November 2011 at 1:16am
1st cab - mordaunt short festival 2, 2nd cab b&w dm601 s1
mic and cab position same each measurement
Posted By: Tony Wilkes
Date Posted: 15 November 2011 at 8:26am
Mr. S Chippy, I have been using REW for quite a while now, dabbling with it for a few years but now getting quite deep and dirty and can honestly say that I always get repeatable results.
Will have a play later with exactly the number of sweeps that you used.
Tony
p.s.What version are you using?
Date Posted: 15 November 2011 at 5:50pm
Plots were made using REW V5.0
Posted By: Steve_B
Date Posted: 15 November 2011 at 7:04pm
If I remember correctly you have to sign up to their own forum to download the software. It might be worth asking there.
Now with the disclaimer that I don't use REW that much and my copy is not likely to be up to date....
Multiple sweeps use synchronous averaging, so if anything causes an interruption or break in the generated or captured signals the averaging will fail. If your soundcard supports ASIO drivers it is worth trying them (assuming you are not already). A mismatch in the sample rate settings can also cause problems.
Of course if your Berry mic is un-calibrated you might as well guess what the response is anyway. Wink
Date Posted: 15 November 2011 at 7:53pm
In the fullness of time I will make a calibration file for the ECM. Luckily i'm not using it for critical measurements, just playing around trying to get to grips with the program.
I dont appear to have the option of selecting ASIO drivers for my soundcard. Thanks for the post, at least now I can surmise that the 8 sweep plot is more likely incorrect.
