HD 15 450mm wide
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=606
Printed Date: 27 March 2026 at 12:38am
Topic: HD 15 450mm wide
Posted By: Martin
Subject: HD 15 450mm wide
Date Posted: 19 September 2004 at 10:43pm
I know that HD15 have to be 470mm+36mm(2*18)and that is 506mm.I found that 450 is ideal for me (first I have tops 450mm wide)and second and more important is that I need 450mm becouse of packing.If I loose only lower cutoff frequency I'm ready to "sacrifice".I found that this bass anyways don't go so deep,so 65 hz instead of 55 is OK.
So do I loose much if box is narrower (5,6 cm)?
Also I have 2 JBL m151-8 can I put them in box,I know they are not best choice but I have them already.
Thanks and sorry for my bad english
Martin
