Best sounding woofer in B&C Sub18
Category: Plans
Forum Name: Ported Enclosures
Forum Description: Post all your reflex and bandpass and 'other' boxes with holes in stuff here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=61923
Printed Date: 27 March 2026 at 4:54am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Best sounding woofer in B&C Sub18
Posted By: niftyg
Subject: Best sounding woofer in B&C Sub18
Date Posted: 17 January 2012 at 7:04pm
What does everyone think is the best driver for the Sub18 enclosure?
The 700w or is the 1200w worth it?
Posted By: BASSWARRIOR
Date Posted: 17 January 2012 at 9:17pm
pd 186 or b&c18tbx 1200,thats what it was design around
------------- big up to all the sound junkies like me. love my addiction, hope they don't find a cure.
Posted By: levyte357
Date Posted: 17 January 2012 at 9:31pm
BASSWARRIOR wrote:
pd 186 or b&c18tbx 1200,thats what it was design around |
Was designed for some of the B&C range of 18s.
http://www.bcspeakers.com/suggested.php?id=0000000008" rel="nofollow - http://www.bcspeakers.com/suggested.php?id=0000000008
- Cabinet Type
Bass Reflex - Box Volume
183 Dm3 - Tuning Frequency
35 Hz - Nominal Impedance
8 ohm - LF Limit
35 Hz - Continuous Power Handling
1400 W - Nominal Power Handling (AES)
700 W - Sensitivity (1W/1m)
97 dB - Max Peak SPL
131 dB - Max Long SPL
125 dB
Components
http://www.bcspeakers.com/SGG/PDF/207.pdf" rel="nofollow">  DRAWING
However there are reflex drivers better than 18TBX100, which also sound better in that cab.
------------- "Who am I? I'm the guy who does his job.. You must be the other guy".
Posted By: luton_soundman
Date Posted: 17 January 2012 at 9:42pm
still waiting to hear fane prime xs in these, heard very good things about them
Posted By: simonh
Date Posted: 17 January 2012 at 10:05pm
Fane prime XS. I have them loaded in my B&C Sub18's
Posted By: infrasound
Date Posted: 17 January 2012 at 10:15pm
simonh wrote:
Fane prime XS. I have them loaded in my B&C Sub18's |
Simon, what is your verdict of the XS?
Cheers,
Date Posted: 17 January 2012 at 10:27pm
Not heard personally, but told Turbomax 1000 almost untouchable in this cab, given enough power.
Not sure if porting adjusted, don't think would be needed.
Posted By: simonh
Date Posted: 17 January 2012 at 11:18pm
Cheers, |
I'm pleased with them Infrasound. Only have a small set-up, I use them in combination with a set of 12", 2" mid/tops. They work well together. Originally heard them at a test event organised by Mikeybear. He had a pair of B&C Sub18's loaded with Fane SB's. PauliePaul brought along an XS to make the comparison. Noticeable difference, sounded a lot deeper. However, I tend to only play soul, funk, disco and house music from the 80's & 90's, so I'm not really look for heavy sub bass anyway.
Date Posted: 17 January 2012 at 11:27pm
Thanks for the detailed response.
I'll chalk that up as another +1 for the XS! Need to get a proper listen to them soon....
Posted By: niftyg
Date Posted: 18 January 2012 at 12:15am
I should have mentioned I am in Canada so I'm very limited for brands, B&C being the best I have found. Let me know if there is anything better in the area!
Posted By: niftyg
Date Posted: 18 January 2012 at 6:47am
Reading back at some threads apparently these speakers are better than B&C:
http://www.usspeaker.com/18.htm
I can't run that speaker enclosure program due to having a Mac.. would anyone be so kind as to tell me which speaker compares to the high end B&C listed on the Sub18 plans and if additional tuning would be needed.. which the best speaker would be.
We're only starting with 1 sub so I want it to be good, and that brand seems the best available near Canada.
Posted By: pfly
Date Posted: 18 January 2012 at 7:42am
18sound drivers would be my choice out of those. Faital, Ciare or Beyma aren't exactly bad either, though.
Posted By: niftyg
Date Posted: 18 January 2012 at 8:01am
So apparently this site carrys lots of brands!
If anyone feels so kind as to recommend what the best sub-450 dollar speaker would suite this cabinet, it would be greatly appreciated!
Posted By: Father-Francis
Date Posted: 18 January 2012 at 8:53am
http://www.usspeaker.com/B&C-18TBX100-1.htm" rel="nofollow - http://www.usspeaker.com/B&C-18TBX100-1.htm
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Posted By: keilamym
Date Posted: 19 January 2012 at 1:25am
Posted By: Tony Wilkes
Date Posted: 19 January 2012 at 7:08am
Speak to Assistance Audio in the States about the BMS 18S430v2, as good as anything (and better than most) in this type of box.
Tony
------------- www.forteaudio.eu - BMS - db-Mark Processors - Lexon (SAE)
Posted By: Meat
Date Posted: 19 January 2012 at 8:28am
The 3 nicest sounding 18"ers we've tried in our reflex boxes (slightly bigger) are in order: Volt 4504 JBL 2242 BMS 18N850V2 may have moved up to being better than the JBL now its burned in.
------------- Don't test the champignon sound
Posted By: djtuffer
Date Posted: 20 January 2012 at 5:09pm
I like the sound of Fane 18XBs. There are lots of better performing woofers but I think the XBs are nice and smooth.
Posted By: aperrado
Date Posted: 21 January 2012 at 6:07am
| when you talk of $450.00 dollars are you talking of one sub only or for a pair?
------------- Im hard to learn but still asking
Posted By: aperrado
Date Posted: 21 January 2012 at 6:17am
| I dont know if the peavey lowrider 18 could be an opttion
Posted By: monomixer
Date Posted: 31 January 2012 at 10:00pm
Hi Guys,
any idea how will tmax 1200i perform in this box?
cheers!
Posted By: neonogin
Date Posted: 05 March 2012 at 4:31am
Hi Folks, I have some experience of these boxes as a few clubs I look after have them installed. They became a really popular install box from a company called CVA. They used the b&c design & loaded them with either PD-1850 or BC 18PS76. I have come across many of the boxes in my time & can state that all the ones loaded with the PD drivers that have destroyed themselves. The drivers, that is. Every box I have come across loaded with the BC driver though, has survived more than 8 years of use & still going very strong. In most of my setups the installs run 2x boxes (2x 18PS76) @ 4 ohm off one QSC 2450 in bridge mode. If you run with a QSC, keep the limiters switched off the QSC amp as they appear to mess up the front edge of a kick drum, so use a limiter elsewhere (i.e. processor). Also, make sure you use a high pass filter at around 30-33 Hz, usually 18db BW. So far for me, not one driver lost in years & they always get used to the maximum (DJ's) output with limiters set to just stop the QSC amps from clipping. The QSC amps are not the greatest things in the world in this scenario mind. They sound a little slow & struggle slightly. But hey, in bridge they only chuck out 2400w into 4 & the BC drivers are capable of 1400 each. Transients are the real problem. All in all though a reliable tried & tested setup for me.
Hope this helps.
Posted By: ziontrainsound
Date Posted: 14 July 2012 at 8:52am
hi guys,since i live in austria i'm VERY limited when it gets to drivers (surplus of milk doesn't get me far y'know?) so i have an RCF LF18N401 at home and wanted to know if it sounds any good in the sub18. i don't have access to b&c, Beyma, JBL, etc. i'm new to the forum so excuse mistakes :P thanks in advance
Date Posted: 15 July 2012 at 9:36am
The RCF looks more a horn or BP6 driver, would probably work in a smaller enclosure. Design you own, it really is easy.
Posted By: dashaudio
Date Posted: 20 October 2012 at 3:23pm
i now have 4 of the sub 18 b&c 2 loaded with fane xbs 1000w vers and 2 with the b&c ps76 just waiting to win my amp on bay and will give a good test next sat in a hall but they both sound good too my ears so far
Posted By: Nikkolas
Date Posted: 28 December 2012 at 12:56am
I have 2 cabs loaded with 18xbs and im very happy with the way they sound and perfom, i will soon built another two. I believe that the sub18 design can take a few drivers and all of them will sound ok. Like the pd186, 18xb and the b&c drivers.
