lower-mid horn design
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=623
Printed Date: 27 March 2026 at 12:39am
Topic: lower-mid horn design
Posted By: RayVaughn
Subject: lower-mid horn design
Date Posted: 24 September 2004 at 12:33pm
Currently the main weak point of our system is the lower mid range.
I want to design a horn to cover this range and I'm happy to be radical with design and materials.
The frequency range they need to cover is 150Hz to 1kHz although we may actually bring the top crossover point down an octave in practice.
Our bass bins are similar to Turbosound TSW 118 and we typically use 6 or 9 per side. When we get our new amps the bass will be capable of 140dB (ish) at 1 meter as a maximum SPL.
I'm guessing that it's ideal to design a horn that covers a wider range than it'll be used for so aiming for a good response from 100Hz to 2kHz is practical?
Which horn flare is best for this range?
Any thoughts on drivers?
We're prepared to spend the cash to make these sound excellent.
Thanks in advance,
Ray Vaughn
www.innerfield.co.uk
Ray Vaughn and on
www.rocketfestival.com
Posted By: Pinheiro
Date Posted: 24 September 2004 at 12:50pm
Hi Ray
to do one horn to cover 100hz to 2khz (single driver)is for me an no win plan
try this HD15 from 80/100hz to 180/220hz and MT102 180hz to 16khz
and you get one kick ass quad amp system but big and heavy
or you can get some turbo aspect tops(i dot know if they are ok or not)or some flood flash to be on the safe side
my take hope it helps
yours Vitor
Date Posted: 24 September 2004 at 1:26pm
Originally posted by Pinheiro Pinheiro wrote:
Hi Ray
yours Vitor
Vitor,
We've already got 18 bass bins - seems kinda pointless building HD15s which cover a similar range.
We've also already got upper mids that we really like the sound of that are currently m 1kHz to 7kHz and tweeters that are loud and ok from 7k up.
So you see it's a specific range that I want to cover.
Of course I could go buy some bluse boxes but thats hardly in the spirit of this forum is it!
thanks anyway
Ray Vaughn and on
Posted By: Elliot Thompson
Date Posted: 24 September 2004 at 1:28pm
Hi
If you're planning to build some horns, I recomend 100 Hz straight horn (Quarterwave of course!) with a 15 inch driver with a QTS of 0.2 - 0.26
Having around four of them fed with some good power (800+) should really get the job done.
I'm currently using EAW KF 750's. But, I used to use some old 170 Hz straight horns. (4 of them) The total mouth of the combined four was 56 inches by 62 inches (2 high, 2 wide) They housed 18 inch drivers, but, I used the old EV Proline EVM 15L (no. 7.5%) instead. The low mids were very potent to say the least.
Best Regards,
Date Posted: 24 September 2004 at 1:48pm
Originally posted by Elliot Thompson Elliot Thompson wrote:
Hi
Best Regards,
Quarterwave - so the length of the horn needs to be more than 1/4 the wavelength? So 1m long is good?
Why use a 15" driver though? There are some 2.5" and 3" voice coil 10" out there with good power handling (though not 800w continuous) and I'd be very worried about cone breakup at 1kHz with a 15".
Here's the drivers I'm thinking of:
Precision devices PD107
18 Sound 10ND610
JBL 2012H
Ray Vaughn and on
Date Posted: 24 September 2004 at 2:05pm
RayVaughn
Yes. that will be fine.
RayVaughn
You said "Low Midrange", so, it should be cutoff at 1khz (Least efficient). The majority the work will be coming from 500 - 150Hz, and, cutoff at 120 or 100 Hz. (Whichever sounds better)
RayVaughn
18 Sound 10ND610
JBL 2012H
When I think of midrange, I think 10 inch drivers. When I think of   Low Midrange/Midbass, 15 or 12 inch drivers comes to mind.
I just don't think a 10 inch can handle frequencies under 400 Hz very well without cone breakup.
Best Regards,
Date Posted: 24 September 2004 at 2:35pm
I'm confused. For me 'cone break-up' is where the diaphragm stops acting as a piston and exhibits resonant modes across it. This is one reason why we use smaller diaphragms at higher frequencies.
The disadvantage with using smaller diaphragms for lower frequencies is less air being moved rather than break up - no?
Also the diameter of a 15" speaker is approaching the wavelength at 1kHz which causes beaming in a direct radiating design. It's not clear to me how this influences behaviour in a compression design but my guess is it's not good.
Thanks for the advice but the jury's still out on this i reckon...
Ray Vaughn and on
Date Posted: 24 September 2004 at 3:30pm
RayVaughn        I'm confused. For me 'cone break-up' is where the diaphragm stops acting as a piston and exhibits resonant modes across it. This is one reason why we use smaller diaphragms at higher frequencies.
I agree. But, 1 Khz is midrange, and, anything below that is considered low midrange. If you want to go down to 150Hz cleanly, you're better off with a larger driver.
RayVaughn
From my experience, smaller drivers will distort faster than larger drivers, when used in lower mid frequencies, under high spl use.
Since we are talking low midrange here, an not bass, your not going to find 10 inch drivers with 15 inch characteristics for midrange purposes. If you are so against 15 inch for low midrange, use a 12 inch instead.
RayVaughn
All speakers beam at a given frequency. The samething applies to horns. A Parametric will solve this problem.
RayVaughn
If you noticed, when I mentioned using 15's for low midrange, I mentioned, the EVM. The EVM is a speaker, not a woofer, and, offers a more fullrange sound. Today, you may not find a 15 that offers such  a response like the EVM 15. So, you might be better off going for a 12 inch for the design.
I know the horn determines the frequency. But, I feel that a larger speaker is more efficient at 200 Hz, than a smaller one.
Best Regards,
Posted By: Dave Slater
Date Posted: 24 September 2004 at 7:28pm
try Rog's MT122 design or hold out for his new fibreglass horns
they'll do what you're asking just miss out the comp driver (or build separate boxes like we did, check out Dom's system)
it doesn't matter what frequency your playing you still have to shift air to produce it and two 12's are going to shift more than one 15
we play ours from 120Hz to 800Hz with about 500w into each driver and it sounds rather nice too
Date Posted: 24 September 2004 at 9:08pm
It's not a bad idea. I'd be making boxes with one driver in - never seen the point of making heavy things unnecessarily.
Did you use the sn-12b?
Any idea of the sensitivity of the cab?
Have you plotted a frequency response?
Ray Vaughn and on
Posted By: Timber_MG
Date Posted: 24 September 2004 at 9:09pm
To get that sort of bandwidth a phase plug is probably on the cards. I have been doing some planning myself for a 130Hz tactrix horn with the P.Audio SN-12B which models fantastically. The thing is that if you want to get low frequencies out of a Mid-horn, you need to move air and this means increasing the distance between the phasing plug and the driver cone. In my case Rog’s phase plug equation results in an upper cutoff of 1.6kHz for a 5mm clearance and I assume that this is an ideal case scenario for a multi-slit annular phase plug (I’d probably stay with one slit for my first try at a bass-mid horn)
A good phase plug evens out the arrival time of different parts of the cone to the horn throat (one wants a planar wavefront at the horn throat) and the directivity is governed by the horn mouth at lower frequencies and progressively by sections nearer to the throat as frequency increases. Could anyone post the speed of sound is through a paper cone? Rog?
My only concern with neo drivers is the small rear chamber which might cause the magnet to de-magnetize at the high temperatures, so perhaps an aluminium access plate is a good idea (the models favour around 3l rear chambers if one wants to keep excursion in check around fc)
My local P.Audio dealer told me that they’d be getting in the P-12N in their next shipment, so that might be a nice candidate for reverse-mounting the driver (doesn’t model as nicely as the SN-12B though). The magnet at the back of the driver is fairly big and has a suitable profile as a (botched) phase plug, but the compression chamber would limit upper bandwidth even with some tricks to reduce the volume and probably some funky molding on the horn throat (fibre-glass = evil). A German company Xmax uses an 18Sound 12MB1000 reverse mounted and with the phase plug stuck to the back of the driver crossed at 800 Hz to a DAS ND-10 (yummy, but at a price) on a big 60x40 horn and this top is said to sound very good and have very low compression.
If Rog’s 12” Mid-horn is not an option in the near future, perhaps you should ask Dirk Hahn from www.x-max.de about their horn and the 18Sound 12MB1000 to go with it. I don’t remember the price (wasn’t cheap) and it’s good from 140Hz, probably a bit lower in pairs. Pm me with your e-mail and I’ll forward measurements if you’re interested.
Martin
Posted By: loophole
Date Posted: 24 September 2004 at 9:39pm
we've just bought two of the new fibreglass horns, loaded with sn-12b drivers. we've got no way of doing a plot at the moment, and the boxes arent even finished, but they're sounding great..... the drivers are still running in, but theyre just beginning to come into their own
and they look nuff rowdy too, never a bad thing ;)
Posted By: JD01
Date Posted: 25 September 2004 at 12:40am
@ RayVaughn: How do you cover the range from 100-1000Hz now? And what tops are these, going only from 1000Hz up? Seems there is already a misunderstanding or misconception......
I agree with Pinheiro that you won't get this spectrum out of one box in a good way. Around 200-300Hz there is kind of a boundary for what speakers/horns can do, so you can design a horn that will be very good below 200Hz or you can do one that will be good above 200Hz. This is, of course, NOT a limitation coming from the diameter of the speaker, but the type of the horn. If you want real output around 150Hz and below you need to have the horn folded for getting it into a transportable shape. Above 200Hz you need a straight horn, because the mids won't play well in a folded design. Of course a folded horn will go even lower then 100Hz.... and a good 10" horn with phase plug will go above 1kHz...... but there is no good way to do it with one speaker in one box.....
As I said the output capabilities have nothing to do with the drivers diameter. The most amazing sub horns use 12" speakers.... Why? Simply because bigger drivers won't take the stress on the cone (bigger cone plus proportionally higher BL --> more stress). We have bass horns with 4 10" drivers per horn. They can do 40Hz (in a stack of four) to 250Hz real flat and really good sounding (flat doesn't mean that the timeline looks good too!) and they get very loud, so you see, the size doesn't matter in this case! Of course these are 10" drivers made for bass, not for mids.
15" drivers in horns should not be operated above 700Hz and even that doesn't sound really good.... and of course a horn of that type won't go below 130 or 150Hz (because it has to be straight and has to have a reasonable size)! So....
Date Posted: 25 September 2004 at 9:51am
It's a 4 way system (per stack)
6 or 8 Fane 18" in short horns (a la TSW 118)  currently up to 175Hz
Array of 16 direct radiating 7" Kevlar mid-bass drivers 175Hz - 1KHz
4 direct radiating 6" surroundless Kevlars 1kHz - 7Khz
4 EV DH3 compression drivers on CD horns 7kHz up
Don't ask me about the kevlars, they're not available to the public - they're a favour from a friend. The 6" are most unusual as the effective radiating area of the diaphragm narrows with frequency as a result of having no surround. Nothing else sounds quite like them.
The  6"  are  fairly sensitive in the region we use them (100dB/w)  but will be the limiting factor  when i upgrade the lower mid. Thats ok. There's a price to pay for effortless clarity in vocals etc.
The 7" are not very sensitive and  despite the largish array  don't cut the mustard.  I could just replace them with a light coned 2" voice coil driver and throw more power in but a horn is clearly a better way to go.
This makes sense. Maybe I need to be realistic and design for a 150Hz to 500Hz range.
I'm just not sure whether to try and design something where the roll-off is somewhat outside the range that will be used or match it exactly.
Agreed.
Also true.
So...
I'm going to try and design for a 100Hz to 800Hz range with a view to using 150Hz - 500Hz
Ray Vaughn and on
Date Posted: 25 September 2004 at 10:27am
I've been experimenting in McBeans program with various drivers and horn flares. The best results have been with the TAD 1201 driver but I'm unhappy with it's low frequency performance.
The SN-12B has a relatively high moving mass which seems to diminish high frequency performance greatly.
I've also had a look at the Beyma 122ND which has a high BL and a very low moving mass.
I can only assume that these very light cone/coils will be more susceptible to break-up modes...
I too had assumed that a phase plug would be necessary but don't really know what I'm doing! Still, I'll have a look at the phase plug equations of Rogs that you're talking about.
Currently the models I've done in McBean are only exhibiting 2mm excursions even at 100Hz...
Ray Vaughn and on
Posted By: JD01
Date Posted: 25 September 2004 at 1:55pm
I see. So you want to go down to 500Hz with the 6" speakers then? Will they 'like' that?
How do you crossover? All active or some ways passive?
Date Posted: 25 September 2004 at 3:44pm
4-way active using BSS Omnidrive, 24dB L-R slopes, per band limiters.
Only eq is a 6dB/octave ramp from 10kHz up to compensate for the roll-off of the tweeters.
I tried running the 6" down to 750Hz last weekend and it sounded good. I'd say slightly better than crossing over at 1K but It's subtle. According to the designer of the drivers 500Hz is ok. I'm planning to add another 4 of these per side anyway and angle them down by 20 degrees becuase the top end of the range is quite directional.
They should add well below 1K if they're close enough together so I'll get another 3dB at the bottom of their range.
Ray Vaughn and on
Posted By: JD01
Date Posted: 25 September 2004 at 7:56pm
Adding up on the 6" seems to be a good idea...
Have you considered designing a passive crossover for the 6" to tweeter cross? So you could really do two horns... it's because I don't think that your existing basshorns could do better if crossed over at 100Hz or even slightly lower. I mean the rest of your system seems to be very audiophil, so why getting the 'slow' and heavy 18" above 100Hz?
Date Posted: 25 September 2004 at 8:44pm
It's a fair point - maybe...
I'm reluctant to split the mid any further - more sources, more x-over trouble ...
On the other hand maybe the lower mid horn can extend down a bit.
Here's the SPL plot from McBean with the TAD TM-1201 on a cosh horn
I know its a pie in the sky plot here but maybe 120Hz is on the cards ;)
Ray Vaughn and on
Date Posted: 25 September 2004 at 9:00pm
My sims show the SN-12B to be very good up to around 800Hz regarding power response and if one looks at 0 to 30 degree performance,  I seem to be able to get the horn up to 1kHz and a little higher or there abouts until I get -6dB @ 30 degrees off axis (designing for a 60 degree cab). I presume the -6dB @ the angle I want to cross over in a horn top to be the highest I can push the horn before I get lobing, right? A 40 degree solution might allow one to cross higher.
The problem with McBean for HF horn design is that it doesn't accurately model the behaviour of a horn at high frequencies (David says so himself). Methinks this is where AJHorn, Speak, Akabak and what not come into their own, but Akabak is a tad too much for a student's budget. This is the bit where one just keeps the side-walls conical as far as possible and lets the phase plug make the horn contour and hopes for the best. The other approach is to make a phasing plug like a big compression driver and a couple it to a “normal” = “without nose” horn. The reverse mounting the driver seems a little risky, though it allows the horn to be shorter physically and lowers power compression.
For simplicity there is nothing like buying a working solution though.
Date Posted: 25 September 2004 at 9:18pm
And you should model into 4x pi, way too little ripple in that plot for it to be a reasonably sized horn (except if you plan on tops much wider than 50cm). That is some extreme bandwidth you have there, but TAD is very expensive and IIRC has around 100W power handling. I generally use Tractrix flares as they end up shorter and show less ripple than hyperbolic/expo horns of the same mouth area (though I may be doing something wrong)
Posted By: roborg
Date Posted: 26 September 2004 at 7:48pm
<p ="Msonormal">To get that sort of bandwidth a phase plug is probably on
<p ="Msonormal"><o:p> </o:p>
<p ="Msonormal">A good phase plug evens out the arrival time of different
<p ="Msonormal">My only concern with neo drivers is the small rear chamber
Yeah i suspected a mid-horn cab i've built was getting seriously hot (2x300w 10"s driven with about 1Kw.) I also have a tiny rear volume (smaller than mt102) & really thick walls, so heat dissipation was only thru the speaker cone (which was getting damn hot after a full power test (so were the neighbours tempers    )
So i fitted a 100mm plastic tube through the rear of the box to each speaker vent (sealed with silicone sealant) & now it's all peachy. It sounds as good as before only without the insane heat buildup & prolly much less power compresssion, i didn't notice any P-C before but then i was getting bad hearing compression
The prob with an aluminium access panel is that for the cooling to work you don't want to put damping material over it & u really need to line all the walls of a mid-cab with a good heavy layer of absorbent stuff.
Cheers,
Rob.
Posted By: roborg
Date Posted: 26 September 2004 at 10:29pm
Here's a pic of the mid-cab cooling butchery the holes are now filled with 100mm plastic tubing. The drivers get hottish to the touch now, but no more & that's after a real thrashing.
Date Posted: 27 September 2004 at 12:36am
Interresting. I take it the driver doesn't have a vented pole piece, as otherwize you'd have a very leaky box. Come to think of it the SN-12B doesn't seem to have an opening on the back plate either, but I think in the long run leaks might creep in at some stage.
The SN-12B doesn't have a traditional backplate to which one could seal easily, but bringing the driver flush to the outside of the box and sealing off the gap around it with some suitable sealant seems like it might help the driver dissipate some of the heat and shorten the cabinet a little more. For access reasons this would have to be incorporated into the acces panel.
Servodrive for instance circulate external air through their motor and achieve compression levels unheard of in traditional motor designs (like 1.5dB long term @ 2 times rated power)
Posted By: roborg
Date Posted: 27 September 2004 at 2:13pm
Actually those drivers do have a vented pole, the vent is mostly obscured by the aluminium plate at the back, behind the little bars. So technically i do have a leaky box, but it's not too much of a leak! In fact when driving hard there doesn't seem to be much air motion at all thru the vent (i hold a piece of tissue near it), so whilst it's probably adding a few losses to the effectiveness of the rear chamber, i think the good cooling is worth it. I've got to get smaart on the job to see how much of an effect the open vents have on the acoustics tho, my suspicion (and hopes ) are not too much....
cheers
Rob
Date Posted: 27 September 2004 at 3:01pm
<>At low frequencies the rear chamber acts primarily as a compliance and brings the resonant frequency of the speaker up to the mid-band of the horn (ideally) as well as reducing interference of the back-pressure from the diaphragm with the output of the horn. Dynaudio used to have a resistive vent system called variovent (fancy word for leaky box).
In a mid-bass horn there is not that much air-movement as in a bass horn so I doubt whether the dustcap would move enough air for you to see a tissue move signifincantly. The resistance to the airflow from inside the rear chamber to outside would be from the spider and the path through the motor (vc gap depending on the design). Treating the spider might be another way to go about this, but now I’m really going off on a tangent. Suppose for mid-boxes it’s still a fair bit safer to use ferrite magnet drivers.
Martin
Date Posted: 27 September 2004 at 7:14pm
Sorry - that plot was 2pi - here's the 4pi plot:
I thought it looked too good to be true. Perhaps you could check I havent made a glaring error in the input params:
The TAD has a Pmax (RMS) of 300w but they say 'rated power' 150w.
The width of our bass tubes is 66cm so each mouth could be that wide.
Ray Vaughn and on
Posted By: Rog
Date Posted: 28 September 2004 at 9:33am
Hi Ray,
Can you get me the other T/S specs, like Qts etc.
Posted By: Rog
Date Posted: 28 September 2004 at 10:04am
Found the specs,
Heres how my version of your horn looks.
Posted By: Rog
Date Posted: 28 September 2004 at 10:24am
Hi Ray,
The above plot is using your specs taken from Hornresp.
I've done some modifications and have come up with this.
Horn lenght 0.8 meters
mouth 66 x 66 cm
throat 350 sqcm
rear chamber 15 liters
front chamber 0.5 liters
here is the lot and the expansion details.
Dist     sqcm   width angle
0.000  350.00  5.30 10.56
0.016  350.52  5.31 10.56
0.032  352.10  5.33 10.59
0.048  354.73  5.37 10.63
0.064  358.44  5.43 10.68
0.080  363.24  5.50 10.75
0.096  369.17  5.59 10.84
0.112  376.27  5.70 10.94
0.128  384.56  5.83 11.06
0.144  394.11  5.97 11.20
0.160  404.98  6.14 11.35
0.176  417.21  6.32 11.52
0.192  430.90  6.53 11.71
0.208  446.12  6.76 11.92
0.224  462.95  7.01 12.14
0.240  481.52  7.30 12.38
0.256  501.91  7.60 12.64
0.272  524.26  7.94 12.92
0.288  548.70  8.31 13.22
0.304  575.38  8.72 13.53
0.320  604.45  9.16 13.87
0.336  636.09  9.64 14.23
0.352  670.48 10.16 14.61
0.368  707.85 10.72 15.01
0.384  748.39 11.34 15.43
0.400  792.37 12.01 15.88
0.416  840.05 12.73 16.35
0.432  891.70 13.51 16.85
0.448  947.63 14.36 17.37
0.464 1008.19 15.28 17.91
0.480 1073.74 16.27 18.49
0.496 1144.66 17.34 19.09
0.512 1221.38 18.51 19.72
0.528 1304.36 19.76 20.38
0.544 1394.10 21.12 21.07
0.560 1491.13 22.59 21.79
0.576 1596.03 24.18 22.54
0.592 1709.43 25.90 23.33
0.608 1832.01 27.76 24.15
0.624 1964.51 29.77 25.01
0.640 2107.71 31.93 25.90
0.656 2262.47 34.28 26.84
0.672 2429.72 36.81 27.81
0.688 2610.45 39.55 28.83
0.704 2805.76 42.51 29.88
0.720 3016.80 45.71 30.99
0.736 3244.85 49.16 32.14
0.752 3491.25 52.90 33.34
0.768 3757.50 56.93 34.58
0.784 4045.17 61.29 35.88
0.800 4356.00 66.00 37.24
Date Posted: 28 September 2004 at 11:13am
*runs off to see how to get hold of AJ horn*
Rog, is GedLee's SPEAK any good taht you know of? Other recommendations for Horn-modeling software not listed in your FAQ?
Posted By: Rog
Date Posted: 28 September 2004 at 1:40pm
Hi martin, sorry for the late reply, I have been so busy these days.
I've not used Ged Lees SPEAK, but I will try it now. I like AJ horn, for mid top its great and its predictions are good. So what you see is what it sounds like.
Hornresp is good for bass, but I'm not convinced for mid or top horns.
I also use Akabak with my own models of horns and chambers. This is the best way I have found yet. And no, I' can't send anyone the scrpits.
Rog.
Date Posted: 28 September 2004 at 2:08pm
@ Rog: Thanks, I appreciate the time. Akabak *drool* is a "little" pricey ... methinks AJHorn would be a good value then. The results differ so greatly from hornresp it seems at high frequencies that there is little point to do a mid-horn design with it.
@ Ray: Your diaphragm mass was given as 5 grams and hence you got the insane HF bandwidth . A sim with the T/S of Thielesmall.com differs significantly from Rog's AJHorn plot none the less.
Date Posted: 28 September 2004 at 3:30pm
That's the mass of the diaphragm on the manufacturers website.
The cones a polymer graphite material. I assumed this is one of the reasons why the drivers are £300 each...
http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=1474&taxonomy_id=43-203 - http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=14 74&taxonomy_id=43-203
Ray Vaughn and on
Date Posted: 28 September 2004 at 3:39pm
Originally posted by Rog Mogale Rog Mogale wrote:
Hi Ray,
mouth 66 x 66 cm
throat 350 sqcm
Thanks for this. Very helpful. I'll get AJ horn too and have a play.
Ray Vaughn and on
Date Posted: 28 September 2004 at 3:58pm
A normal A4 sheet is 80grams per squre meter. That means that a 530 square centimetre cone would weigh in at 4.3 grams. The moving mass includes things such as a voice coil and partly the suspension elements in addition to the cone weight. I'd go with the weight of 53 grams (which is fairly light).
Their compression drivers are even more "reasonably" priced but sound absolutely beutiful.
Date Posted: 28 September 2004 at 4:21pm
Where are you getting the 53g from?
The thielesmall.com doesn't seem to list a mms or mmd
Ray Vaughn and on
Date Posted: 28 September 2004 at 5:33pm
I entered the other values into hornresp's wizards. WinISD comes up with a Mms of 59.5g
Posted By: roborg
Date Posted: 28 September 2004 at 5:36pm
If you're gonna play with an MT102 sized cab the aj-horn demo is fairly useful, as it seems to be restricted to a 0.5m horn length, which is pretty much spot on for that cab (PS. model half the cab....) The optimum rear chamber volumes from horn-resp & aj-horn seem to tie in pretty accurately for me, good software all around.
cheers,
Rob
Posted By: Rog
Date Posted: 28 September 2004 at 5:49pm
Funny,
I can model 30 meter horns using my AJ horn.
What version have you got.
Date Posted: 28 September 2004 at 5:51pm
That's mean.
Posted By: Rog
Date Posted: 28 September 2004 at 6:06pm
This is meaner.
Anyone fancy an 11 meter horn with a Void V18 driver in it.
Posted By: Dom
Date Posted: 28 September 2004 at 6:25pm
This is meaner.
I'll go warm up the table saw....  Sort the plans out...
Posted By: roborg
Date Posted: 28 September 2004 at 8:32pm
Funny,
I'm trying the free demo version off their site It's got a few restrictions in it
Now a 30meter horn is something! Makes me think of the plywood tunnel used in the first h-bomb test, 9000ft long with a h-bomb as the driver Alot of noise for a short time....
cheers,
Rob
