routed sides
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=64218
Printed Date: 26 March 2026 at 11:31pm
Topic: routed sides
Posted By: lukehaze1
Subject: routed sides
Date Posted: 02 March 2012 at 8:10am
i always thought  routed out sides were the strongest way to build the cab but my carpenter seems to think that if he used buiscets and screws it will hold just aswell. However he is not a cab builder. i dont know any cab builders so was wondering if any could let me know
Posted By: Father-Francis
Date Posted: 02 March 2012 at 8:34am
do you mean rabbeting , if so both ways are good if done correctly
Posted By: hmaudio
Date Posted: 02 March 2012 at 9:58am
alot of people will argue a fully rebated cab is alot stronger but IMO a butt jointed cab is just as strong i not stronger
Posted By: mykey-
Date Posted: 02 March 2012 at 10:17am
basically the more surface glue area the better
so take a rebate joint........18mm at the end, plus say.....7mm deep? so now we have 18+7+7= 32mm glue area instead of 18mm glue area
some people rebate 5mm, but that's still 28mm glue area
Posted By: mykey-
Date Posted: 02 March 2012 at 10:21am
will be fine
size 8 inch and a half pozi screwWink
Posted By: Tony Wilkes
Date Posted: 02 March 2012 at 10:24am
Regardless of glue area the joint cannot be any stronger than the parent material, when the joint fails which gives? I have never found a glued joint to fail regardless of joint type it has always been the material away from the joint.
Rebated joints are probably more resistant to axial loading but you should not have any of those in cabs that have been braced correctly.
Tony
Posted By: mykey-
Date Posted: 02 March 2012 at 10:43am
....even more glue area
http://www.uploadhouse.com/viewfile.php?id=15695790&showlnk=0" rel="nofollow">
Posted By: Wrek0ne
Date Posted: 02 March 2012 at 10:58am
You can also make the joints much more air tight with rebates smothered in glue.
Poll this!
Posted By: Wrek0ne
Date Posted: 02 March 2012 at 11:00am
What kind of router bit do you need for the second one... That looks like an extreme ball ache!!
Poll this!
Posted By: hmaudio
Date Posted: 02 March 2012 at 11:21am
got some old cerwinvega cabs with rebates just like that there mad strong!
Posted By: mykey-
Date Posted: 02 March 2012 at 11:23am
mitres
Date Posted: 02 March 2012 at 12:21pm
yeh i want him to router the sides out because if he used buiscet joints i could see the cab  just vibrateing  to much and fall apart
Posted By: Twirl
Date Posted: 02 March 2012 at 2:29pm
A well built butt-jointed cab properly screwed and glued should not fall apart through vibration! However, as Mike pointed out, the more glue-able surface area the better...
I also find rebating speeds up construction and produces a more accurate build.
Posted By: shagnasty
Date Posted: 03 March 2012 at 9:50pm
The bits you use to cut these mitres are really not for hand-held machines, you want a table mounted router with some serious power, also the bits aren't cheap and can't be sharpened...
I rebate folded horns using a 30mm follower and laser cut steel jig, the jig means I don't have to mark out my panels, I just axe up the sheets on a wall saw and them blast out the horn profile, assemble is a peach and it reall makes a nice job.
A cheat is to use a rail mounted festool router and CAD out you sides 1:1 and use the paper as a template, either spray mount it onto the board or make cuts through it with a stanley knife join the dots with a pencil...
Posted By: ceharden
Date Posted: 04 March 2012 at 1:17am
Both methods are valid.  The key thing whether you're using rebates or biscuits, or even just butt joints is to make sure they're tight.  Wood glue (PVA based) works best when you have the maximum surface area touching each other and cures with them held tightly together.
An accurately cut and assembled butt jointed cab is probably stronger than one with loose fitting rebates and poorly cut panels.
Date Posted: 04 March 2012 at 3:59am
Chris's comments above probably cover the whole question.
Tony
Posted By: Wrek0ne
Date Posted: 04 March 2012 at 11:10am
Good job my house mate has a Festool 1400 router then!! Big smile
Poll this!
