Highest amplifier supply rails?
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=64433
Printed Date: 27 March 2026 at 5:32am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Highest amplifier supply rails?
Posted By: BUZguy
Subject: Highest amplifier supply rails?
Date Posted: 06 March 2012 at 10:53pm
Was wondering what amp has the highest +/- voltage rails in the non tier designs? i.e. single pos. rail, zero and single neg. rail.
Posted By: Peter Papp [PKN]
Date Posted: 06 March 2012 at 11:06pm
PKN 3PHASE-20K +/- 276V I have not seen any other audio amps with even close values
Posted By: Muckerbarnes1
Date Posted: 07 March 2012 at 1:55am
You are of course talking semiconductor and not thermionic.
------------- Billy Dawg.
Posted By: Earplug
Date Posted: 07 March 2012 at 10:30am
Peter Papp [PKN wrote:
]PKN 3PHASE-20K +/- 276V I have not seen any other audio amps with even close values
Have they invented a speaker that can work at that voltage level (or is that a lighting amp )??
------------- Earplugs Are For Wimps!
Posted By: jbinks
Date Posted: 07 March 2012 at 10:48am
I'm sure there is a car-audio "speaker" out there that claims to handle 10k... Would be a fun experiment.
In reality however, that kind of amp would be for driving many speakers at once, not just one! So the loads would be connected series-parallel to achieve the best loading for the amp and also voltage across each driver.
------------- Can you have too many 1850-horns or PKN XE amps??
Date Posted: 07 March 2012 at 11:14am
There are just very few speakers which can handle above 200V peaks. I meant only peaks with super carefully maintained average-to-peak ratio with rms limiter, etc... The ability of extra headroom compared the +/- 276V to an amp for example an XE6000 with 190V rail (which is still pretty high) is significant even on moderated power levels with smaller speakers too.
Posted By: teslaman
Date Posted: 07 March 2012 at 11:59am
If you mean class-AB with no rail switching (i.e. not class G/H) then i've seen up to +/- 90/100V split rails but there are probably more extreme examples out there (Maplin 1kW amp kit or OMP 1kW MOSFET amp perhaps?). Above these rail voltages it's harder to find decent transistors and more effeciency from class-G/H helps keep dissipation down anyway whilst lowering the maximum voltage the devices see. Class-D is a different matter of course...
Posted By: burningbush
Date Posted: 07 March 2012 at 1:46pm
What about a big valve amp, don't they have kV supply rails?
------------- music is the message
Posted By: M4trix
Date Posted: 07 March 2012 at 3:22pm
I'm a bit skeptic about PKN 3PHASE-20K power ratings. I would like to see the design. Which transistor they used in the output? Transistors that can withstand at least 550V and designed for audio? Unfortunately this is beyond my knowledge.
/me digging on the net about this case....
Posted By: simonp1100
Date Posted: 07 March 2012 at 3:45pm
1.21 gigawatts per rail.
Sorry i was waiting for someone to say that, thought i would get in there first.
Date Posted: 07 March 2012 at 4:31pm
Anode supply voltage to KT66 of 475-575v. Anode supply voltage to V1505 of 2-2.5kV.
From the Audio Freq. Amplifier Design book from GEC ltd (London) 1957.
Posted By: Earplug
Date Posted: 07 March 2012 at 6:25pm
Class D will use switching transistors - usualy fets, not audio devices.
{Maybe that´s why they don´t sound right, haha. Just kidding!}
Posted By: M4trix
Date Posted: 07 March 2012 at 6:54pm
teslaman wrote:
If you mean class-AB with no rail switching (i.e. not class G/H) then i've seen up to +/- 90/100V split rails but there are probably more extreme examples out there (Maplin 1kW amp kit or OMP 1kW MOSFET amp perhaps?). Above these rail voltages it's harder to find decent transistors and more effeciency from class-G/H helps keep dissipation down anyway whilst lowering the maximum voltage the devices see.Class-D is a different matter of course... |
Ecler's PAM 6100 is a class AB amplifier with two 3,6kVA toroidal transformers, cca. 150V DC per rail and delivers 1750W per channel on 4 ohms load. That's the highest power supply voltage I've seen in a AB class design. It has 24 switching fets in the output, IRFP360.
Posted By: kedwardsleisure
Date Posted: 07 March 2012 at 7:14pm
Some of the big Trace Elliot bass amp heads use around 630V. I don't think this is a good idea!
------------- Kevin
North Staffordshire
Posted By: BUZguy
Date Posted: 07 March 2012 at 8:34pm
I think the Maplin 1Kw and the BK Electronics 1000w module were both approx +/-90v.
Posted By: studio45
Date Posted: 07 March 2012 at 9:49pm
630v with solid state devices? Really?
------------- Studio45 - Repairs & Building Commotion Soundsystem -Mobile PA
Posted By: Nitz V1505
Date Posted: 07 March 2012 at 10:40pm
| The good old V1505, thats what inspired my user name!!!!!
------------- LET THE BASS ROLL LIKE THUNDER
Date Posted: 07 March 2012 at 10:42pm
630v with solid state devices? Really? | Thats gotta be valve, probably KT88/6550.
Date Posted: 07 March 2012 at 10:58pm
Yeah I was thinking of the V8 that uses 4 matched pairs of KT88. Serious stress and the valve bases coated in silicone grease.
------------- Kevin
North Staffordshire
Date Posted: 08 March 2012 at 11:08am
Would love to hear it hooked up to a G sub or two loaded with Fane 18xb's!!!!!!!
Posted By: DjLeco
Date Posted: 08 March 2012 at 4:24pm
I use on mine modules of amplification, +/- 96-98Vdc
AB-B Class module amps.
Test here:
http://www.youtube.com/watch?v=KrenN56u-GY" rel="nofollow - http://www.youtube.com/watch?v=KrenN56u-GY
------------- I'm A Stupid SMART Romanian...
Date Posted: 08 March 2012 at 5:54pm
There is no available circuitry which would be able to use 100% of the DC bus range. Generally there is at least 5V or more drop due semiconductors, coils and ripple,etc.. effects.
Posted By: M4trix
Date Posted: 08 March 2012 at 7:16pm
Test here:
You burnt the floor with those dummy load resistors.
Posted By: DjLeco
Date Posted: 08 March 2012 at 7:31pm
Yes!
That means POWER.
Also dummy load was almost destroyed (melted ceramic)
Power is power, but at me is CONTINUOUS power!
Posted By: M4trix
Date Posted: 08 March 2012 at 7:48pm
DjLeco wrote:
Power is power, but at me is CONTINUOUS power! |
Yeah, you're right. Btw, you did a nice job there with your amplifier. Congratz.
Posted By: DjLeco
Date Posted: 08 March 2012 at 7:54pm
It will follow, 2 ch on BTL for big power into 8 and 4 ohms, AB-B class sound, and in next future, I will develop a big power classD amp, (bass exclusive15Hz-330Hz) a big power class TD amp, (fullrange 20Hz-20Khz) and maybe a easier version of I class amp.
Now, waiting for my PCB designer, to make the PCB design of SMPS, so therefore, proceed to build complete LECO amplifier, amplifier with continuous power cappability, not burst.
SMPS, almost 5200Watts peak power, here:
http://www.youtube.com/watch?v=O74jJUo7eA4&feature=player_embedded" rel="nofollow - http://www.youtube.com/watch?v=O74jJUo7eA4&feature=player_embedded
Posted By: studio45
Date Posted: 08 March 2012 at 9:10pm
You are crazy, you wouldn't see me purposefully shorting out something with a power supply that big. However it's nice to know your amp won't break if someone crazy buys it ;) Presumably the finished version will cut the power if it detects a short circuit rather than driving 27A into it all night?
Posted By: BUZguy
Date Posted: 08 March 2012 at 9:46pm
DjLeco wrote:
I use on mine modules of amplification, +/- 96-98Vdc AB-B Class module amps. Test here: http://www.youtube.com/watch?v=KrenN56u-GY" rel="nofollow - http://www.youtube.com/watch?v=KrenN56u-GY | That is indeed a bit mad. Can I ask why you disconnect and connect the load while a lot of power is coming through? The arc damage to the output tag on the amp board must be a bit of a mess! This is a Mosfet circuit I take it?
Posted By: DjLeco
Date Posted: 09 March 2012 at 1:49pm
I sold deja more than 30 modules of amplification, till now, mine co-forumist frineds, trust me and my quality design, of amplifier module.
Connecting and disconnecting the load at such big power, gives to the smps, very abrupt differences of power consumption, very big differences of di/dt, so, a weak design, will blow the switching devices, more than sure.
Audio signal is an "mixture" with big differences between min and max peaks, so the SMPS must handle very big differences of consumption, and must be capable to handle it continuous without limmitings.
Mine smps will have couple types of protection, short circuit , overcurent , thermal, and will be dual sosftstart type, also for main AC and secondary DC, total independent, for minimising inrrush current.
The SMPS will offer multiple DC outputs, all of them protected of shortcircuit, but I will make a thread, when everything will be done, with pictures and tests.
Maybe today, I will make a test with mine modules in BTL mode, on 8 ans 4 ohms dummy load, to see the output power, and all.
Keep close!
Posted By: Earplug
Date Posted: 09 March 2012 at 6:16pm
Haha - nice videos, but if your (life) insurance company sees this, your premiums are going uuuup!
Date Posted: 09 March 2012 at 6:54pm
Hope they are CE marked and EMC approved!
------------- Kevin
North Staffordshire
Posted By: DjLeco
Date Posted: 09 March 2012 at 9:14pm
For DIY use, no need any approvement...
Posted By: GAZ.
Date Posted: 09 March 2012 at 10:16pm
DJ Leco's amps certainly seem robust! flat out into 2 ohm, and shorting it out at full power and it doesn't go bang! A lot of amps out there would not take that sort of abuse and still work afterwards.
------------- 100% Earth Moving Bass
Date Posted: 09 March 2012 at 10:52pm
Ok. But your posts seem more like an advert for your amplifiers. Can you post the schematics for them in the spirit of the forum.
------------- Kevin
North Staffordshire
Posted By: GAZ.
Date Posted: 10 March 2012 at 12:07am
Doesn't come across to me as being an advert, more of a "Hey Look what I made!"
Date Posted: 10 March 2012 at 12:43am
I was being polite in a restrained, English way
------------- Kevin
North Staffordshire
Posted By: infamousj
Date Posted: 10 March 2012 at 2:01am
The biggest rails in an amp that I have my hands on is a whole +/- 80vdc. It's a mid 80s Traynor beta800 I'm fixing for a friend, claims 400w per channel at full tilt. After that I'm going to attempt to build my own 100w per channel before moving into big boy power levels, lol.
Have come across Some of Leco's posts Over on diyaudio and his stuff seems to be some very nice designs, keep up the good work... You helpto inspire people like me :)
Posted By: DjLeco
Date Posted: 10 March 2012 at 11:37pm
GAZ. wrote:
DJ Leco's amps certainly seem robust! flat out into 2 ohm, and shorting it out at full power and it doesn't go bang! A lot of amps out there would not take that sort of abuse and still work afterwards. |
Watch here:
http://forum.speakerplans.com/topic64601_post643537.html#643537" rel="nofollow - http://forum.speakerplans.com/topic64601_post643537.html#643537
Posted By: Walkalone
Date Posted: 12 March 2012 at 4:50pm
150VDC rail for class AB??? OMG!!!  Do you have Ecler PAM6100 schematic? I want to see it!
Posted By: M4trix
Date Posted: 12 March 2012 at 10:59pm
Here you go. Actually there is no info about the power supply voltage in the service manual but fortunately I had an opportunity and opened one amplifier on my desk.
His majesty.... the PAM 6100! ---> http://www.2shared.com/document/zdWGt0Ue/ECLER_PAM_4100-6100.html" rel="nofollow">http://www.2shared.com/document/zdWGt0Ue/ECLER_PAM_4100-6100.html
Date Posted: 13 March 2012 at 11:18am
His majesty.... the PAM 6100! ---> http://www.2shared.com//zdWGt0Ue/ECLER_PAM_4100-6100. - http://www.2shared.com/document/zdWGt0Ue/ECLER_PAM_4100-6100.html
Sorry, i can't download from your link. It's say '' The file link that you requested is not valid. Please contact link pulisher or try to make a search''. Please upload to other host, i.e mediafire or 4shared... Thanks!!!  I have a DIY amp, 95VDC per rail. Bridge topo, used 16 pairs per channel and 2KVA IE transformer per channel. Fully complementary input, based from Crest Audio CA 12. I'm used it on my DIY 15' subwoofer.
Posted By: M4trix
Date Posted: 13 March 2012 at 3:19pm
Strange, 2shared always worked. Try this link. http://www.mediafire.com/?xqcx770jv7yr4jm" rel="nofollow - http://www.mediafire.com/?xqcx770jv7yr4jm
15' subwoofer. |
You made it by yourself? Some pics would be nice.
Date Posted: 15 March 2012 at 1:43am
Thanks M4trix!!! Yep! I build it by myself. Sorry, i sold it last week for a friend. I'm building another one, similar. 100VDC for each rail, used 16 pairs per channel, bridge topo with 2500 ~ 3000VA toroidal transformer. 2000W/8ohms, 0.1%THD@ full power is my destination, he he. Now, the PCB design is nearly complete.
Posted By: nev23
Date Posted: 18 March 2012 at 10:33pm
I saw a 5kW amp that had just 2 output valves. Don't know what they were (sorry) but they were anode modulating a 10kW short wave transmitter. The modulation transformer was quite large...
But then the BBC radio 4 long wave transmitter uses a single output valve to deliver 400kW. And It's class B, because it has to be linear for amplitude modulation.
Date Posted: 26 March 2012 at 6:00am
RAM Audio MB1900. Class AB amp with 5 pairs MJL21193/21194 per channel. 2.2KVA EI transformer, 108VDC per rail.
