PPX idle warm up time
Category: Other Chat
Forum Name: Golden oldies
URL: https://forum.speakerplans.com/forum_posts.asp?TID=65401
Printed Date: 26 March 2026 at 6:55pm
Topic: PPX idle warm up time
Posted By: GregM
Subject: PPX idle warm up time
Date Posted: 29 March 2012 at 7:13pm
Guys,
It's been a very (very) long time since I had any PPX amps in my stable, and at my age, the memory doesnt work too reliably anymore!......
I wanting to know whether the cooling fan and thero trigger in my PPX450 are actually working, and until Sunday I'm not going to get a chance to plug it in a source and pair of speakers so I'm just sitting here with it powered up idling, getting quite warm and wondering why I can't remember how warm they get before the fan should cut in....
Can anybody advise (Ian?) approximately how long after powering up and idling they are warm enough to trigger the fan?, obviously I don't want to wait too long only to discover the fan's stuffed, and I've let it toast itself, but equally, I'm inpatient so don't want to wait until Sunday!!
New toys eh?, tsk!
Greg
Remember, if you don't want to hear the answer, don't ask the question!
Posted By: Mhamplification
Date Posted: 29 March 2012 at 8:17pm
Greg
The fan should come on and run for a couple of minutes then switch off again  It depends how the bias is set as to how long it takes till the fan should come on, maybe 5-10 minutes is the norm.
 Might be best to bypass the thermal switch to check it is working properly,  a lot of the fans in older PPX amps are 115 volts so don`t hardwire it to the mains.  You can wire it via the mains transformer primary windings to get 115 volts
Let us know how you get on
Good to see you have a ""decent amp"" in your collection now
Martin
Posted By: GregM
Date Posted: 29 March 2012 at 8:53pm
Thanks Martin,
Useful to know the early ones had 115v fans, I'll bet that's caught out a few dabblers!
The machine got rather warm just idling for about 25 mins, and no sign of the fan firing up, so I've powered off until I have the time to poke about which won't be until the weekend.
I'll definitely try bridging the thermo unit as a start - assuming I can find it.  I'm downloading the schematic at the mo so hopefully it's quite obvious.  Seems a very long time since I opened up a PPX.
Regards,
Greg
Date Posted: 29 March 2012 at 9:25pm
That doesnt sound right Greg,as Martin says,the fan should trip-on after around 5 minutes at idle.
The trip is a thermal switch mounted on the heatsink next to the Hitachi mosfets.
Posted By: GregM
Date Posted: 29 March 2012 at 9:46pm
Hmmm, that was what I feared, I had a distinct feeling from what I'd read here in the past the fan would cut in reaonable quickly.
I just hope a possibly dead fan hasn't allowed it to over cook in the past, I won't get to dig into it until Sunday. Seller (yep, on SP Ouch) sold it as fully working, and actually confirmed having tested it the morning before i was due to collect it so I maybe just looking at a duff fan.  Fingers X'd.
Cheers Ian for the pointer - I'm sure the trip will become obvious.
Greg
Date Posted: 29 March 2012 at 9:56pm
Should be ok,on the heatsink there are two thermal switches,one trips the fan at 60* if i remember,and the other switch is a thermal cutout at 90*,which should protect the devices...there is also another thermal trip on the transformer as well,which shuts the power off if the transformer overheats.Quite well protected these amps!
Just checked mine,def. 115v fan.
Posted By: GregM
Date Posted: 29 March 2012 at 9:58pm
Good man, thank you.
Good old fashioned engineering eh?, protection ruled the way!
Greg
Date Posted: 29 March 2012 at 10:05pm
You can see one switch at the far end of the heatsink inline with the output devices,the other switch is other end of of heatsink.(hidden by the fan in ths photo)
Edit,this is a 900,but layout is same in 450.
Posted By: VSS
Date Posted: 29 March 2012 at 10:14pm
Fan is 115 V . I replaced one in one of my ppx 900 . If I'm not mistaken the fan runs continiously from the moment the amp is switched on ( ppx 900 ) . Anyway , mine are .
Posted By: GregM
Date Posted: 29 March 2012 at 10:15pm
Except that one's also got nice handles! LOL
Thanks again Ian - I know what I'm looking at now - and can also see the tranny thermal cut out too.
Posted By: GEB
Date Posted: 29 March 2012 at 10:20pm
Stick a 240v fan in, wire it up to be on full wack 100% of the time?
Posted By: GregM
Date Posted: 10 April 2012 at 8:57pm
Update time - just in case anybody was actually following the story of my migration back from HH to Citronic.....
Despite being filthy inside and out, it works!, both channels pump away, although channel B did seem a tad quieter in my very untechnical test.
The fan switch (presumably a thermistor?) did have an intermittent fault, there was what I guess was a dry joint/fractured cable at the heatsink end - a quick strip back and resolder and the fan pops in and out every 5-6 mins as you guys suggested it would.
I do need to spend a fair bit of time cleaning it out and tidying up the casework - (oh, and finding some front handles!), then it'll find a new job which may just become a core part of my home hi fi Smile
Martin - out of curiousity, would you happen to have a full copy of the service manual and schematics for the PPX450 I could see?, I really fancy seeing how much of my ancient BBC training I could remember - then, when I bugger it up I can add the PPX to the pile of kit waiting to find their way to you for service and/or repair!!
Greg
Posted By: colint
Date Posted: 10 April 2012 at 9:18pm
Greg
What part of the handles are you looking for Greg? if it's the front panel/plate with the handle supports on there are some on ebay at the moment, the front pieces you can make up from some steel bar very easily.
Col.
Posted By: GregM
Date Posted: 10 April 2012 at 9:29pm
Col.
Col - it's the easy bits I'm missing, the flat steel strips - some bozo obviously took them off a long time ago so I just need spend a bit of time measuring up.
Greg
Posted By: colint
Date Posted: 10 April 2012 at 9:36pm
Ok that's going to be a bit easier on the wallet, if you want to make them up & send them to me and I'll get them powder coated for you it'll last longer than paint.
Posted By: GregM
Date Posted: 10 April 2012 at 9:49pm
Thanks Col, thats a nice offer - and it may, just, swing the idea of a PPX gracing the lounge to the good woman!
Date Posted: 11 April 2012 at 9:59am
Greg
I only have the circuit diagrams for the PPX series
There are lots of different versions and issue numbers
The main pcb is either PC1061/4 or PC 1062/4 and issue 1-8
The powers supply seems to be the same throughout
If you see what boards yours has I will try and get it on line somewhere or scan them
Martin
Posted By: GregM
Date Posted: 11 April 2012 at 4:00pm
Hi Martin,
Just took a look, mine has the PC1061 and PC 1062 boards on channels A & B but both are marked up as Issue J, not numbered 1-8...... Each board is fitted with a trio of J49 and K134 devices.
Ian PM'd me a set of schematics which include a few pages I'd not seen before, but still no sign of what seems to be a mystery 'Channel B' power section......
Any/all help welcomed.
Greg
Posted By: mooreb
Date Posted: 11 April 2012 at 8:27pm
I'll Help! I have quite a few ppx amps for sale plus i'm sure i've got a few handles (that came with the power switch kit) Smile
Posted By: bass*en*mass
Date Posted: 11 April 2012 at 8:52pm
tut, tut - do i smell a sales talk?! :)
Posted By: GAZ.
Date Posted: 11 April 2012 at 9:36pm
A difference I've noticed in my PPX's is two of them don't have hitachi fets in, the rest do.
I'm guessing the 2 that dont are later ones built after the hitachi fets were discontinued?
100% Earth Moving Bass
Date Posted: 11 April 2012 at 9:50pm
I have also heard of that Gaz,i think a few of the very late ones had BUZ devices?
Posted By: GAZ.
Date Posted: 11 April 2012 at 10:28pm
Yeah one of my 150's has BUZ900 and 905's in and one 1600 has something other than hitachi's in, I don't think they're BUZ devices though? Its the only one I have with the later style power switch.
Posted By: GAZ.
Date Posted: 11 April 2012 at 10:32pm
Just been on the phone to another forum member, I've a feeling I may be tempted into owning another PPX or several soon
Posted By: GregM
Date Posted: 11 April 2012 at 10:37pm
Ooooh, 'Dibs' on share-ies...WinkWink
Posted By: GAZ.
Date Posted: 11 April 2012 at 10:45pm
Race you to the PPX's ! You know who has them too!
Posted By: mooreb
Date Posted: 12 April 2012 at 12:24am
Now now i'm sure that 'member' has enough to keep you both happy! Smile
Posted By: DJ Pirate Preacher
Date Posted: 05 December 2024 at 10:00pm
Well, how about that?
I have the identical issue with my Lantek PPX450 as does GregM.
I'm not as electronically minded as the rest of you.
Can the person known as "Ian" send me the manual for the amp?
I couldn't find it online.
I need this fixed yesterday as it is December and the Christmas events & NYE events are piling up, waiting for me.
We have no electronics repair tech in my part of wilderness Canada.
Thanks.
Date Posted: 17 December 2024 at 12:17pm
Does this help?
https://elektrotanya.com/citronic_ppx-450_sch.pdf/download.html" rel="nofollow - https://elektrotanya.com/citronic_ppx-450_sch.pdf/download.html
Date Posted: 17 December 2024 at 7:15pm
Maybe.
Not really, for me.  I'm not electronically literate.
Thanks.
