HD15 Response Plots for different drivers
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=655
Printed Date: 27 March 2026 at 12:39am
Topic: HD15 Response Plots for different drivers
Posted By: Andrew
Subject: HD15 Response Plots for different drivers
Date Posted: 01 October 2004 at 7:15am
I measured my system and the response was much flatter than expected, particularly in the bass, where the HD15 (only) was being used for a nice lightweight system with throw.  I expected there to be a peak, as on the HD15 plans, but it was not present.
I've just thought why there might be a difference, the original plots were made for some American specification driver, but I then used an alternative one from P Audio.
Rog, can you give us some predictions on how different drivers should perform in this cabinet?  I can't remember all the new recommendations, but plots of the Eminence, C15 500LF, and the Neo would be a good start.
Posted By: Rog
Date Posted: 01 October 2004 at 8:18am
Hi Andew,
I wish I had time to build three HD 15's and put diffrent drivers in them and do the plots for each of them.
The P Audio that you use will have a fltter response. Its a good driver and works well in the HD 15. The driver I measured was not so good. If only I had the C15 500 LF when I first built the first HD 15.
Rog.
Posted By: Dom
Date Posted: 01 October 2004 at 8:43am
If I can make it to the bass shootout and if I can liberate my system then if anyone has the drivers they can be loaded into some of my HD15's as we used t-nuts and clamps to secure the driver, so they can be loaded with any driver...  We've got PD154's in ours, it would certainly be interesting to see the comparison to a P. Audio
Posted By: Andrew
Date Posted: 01 October 2004 at 11:43am
I'm hoping to make it too.  I've got two different cabinet build types, and Eminence and P Audio drivers.  Can anyone bring a Neo driver?
Posted By: loophole
Date Posted: 01 October 2004 at 12:57pm
if i can make it, i've got four, with bm-15lf's for yet another comparison. probably even less peakey than the challengers, they go nice and low..........
Posted By: nightline
Date Posted: 02 October 2004 at 5:49pm
I´m using Beyma 15G400 drivers in my HD15´s, and I love the sound.The freq.respons will be a little bit lower and maybe a Db less.
Kind regards
Jack
Posted By: Andrew
Date Posted: 02 October 2004 at 6:24pm
Can anyone predict, i.e. not measure empirically, what response drivers suitable for the HD15 produce?  Even a rough estimation would be better than none.
Hopefully we will get some empirical results next weekend.
Posted By: whitehousejamie
Date Posted: 08 October 2004 at 6:04pm
Hi All,
When using the HD15 singly, does the C15 or BM15 driver give a flatter response? I would like to try the C15, to replace the Kappas i use at the moment.
Thanks
Jamie
Posted By: freddyi
Date Posted: 08 October 2004 at 6:40pm
in single/pairs hows power handling and punch  of HD15 vs same size angled/vented scoop (like ARLS)? (imagine 40-45Hz highpass is needed on vented type)
