Baby's First Rig
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=6877
Printed Date: 27 March 2026 at 2:16am
Topic: Baby's First Rig
Posted By: Rog
Subject: Baby's First Rig
Date Posted: 16 October 2006 at 8:02am
Hi,
When I was in the UK around PLASA time I went to my sisters house and got some old slides. These are the first systems I build and designed
The bass is 2 x 12" reflex. The port is a shelf port at the bottom of the box. Can't remember what the woofers are but they were 30 watts and had a whizzer cone. The 2 bass cabs were driven of a Selmer 100 watt valve amp. The amp had a 5 band graphic eq and I put all the mid and top sliders all the way down and the lowest fader all the way up. The driver in the tea chest is a 12" Celestion guitar speaker. Above that is by first attempt at a HF horn. The cab sides are made from 12 mm pine and the top and bottom are made from 3 mm hardboard. The horn was made from really thin sheet metal that I cut with tin snips. Driver was a Celestion comp driver, not sure which one. I put a cap inline as the crossover. The cab above that is a 10" speaker that used to be used in schools. Not sure about the power, but could not have been more than 15 watts. The tea chest and school speaker were driven from the amp that was used in the school to power the 10" cabs. It was valve and had 70v line out and also a 8 and 4 ohm tap. Must have been around 40 to 50 watts. It had bass and treble, so I cut all the bass and turn the treble flat out. The comp drivers were driven from a pye amp. Again it was valve and looked a lot like what old taxi company radio transmitters looked like. Again tuned the bass down and treble right up.
I don't have an exact date for this system, but its mid to late 1970's. Maybe 76 or 77. I thought it sounded great, but then we all do at that age. I used it for discos around the village halls near to where I lived, which was close to Glastonbury at that time.
This is my first system I built for the first company I had. The company was called Sound Faclities. Bass was 18" Fane classic 275 watt woofers in really massive reflex cabs. They look like horns but the horn was so short it did nothing, but I thought it made it look good so went with it. These were driven from a Studiomaster 800 B or C, can't remember and its not in this pic. Upper bass were w bins loaded with powercell 250's. What a driven that was for its day. The W's were powered by a MM Electonics AP360. The cabs above which look like philles were 2 x 10" on a short horn. Bit like a phille but all wood and no fibreglass. These were driven from a 250 watt per channel amp that I built from modules and put in a case. Can't remember the make But it wasn't maplin or the MXF ones as neither of those compaines were trading then I don't think. The HF horns were built from wood and were a bit like Altec mantaray horns. The compression driver was the same one from the system before, which was a Celestion. HF amp was another module kit type thing and was 100 watts per side. The crossover was an RSD (early studiomaster) 3 way and you had variable crossover points. Can't remeber the crossover points but the 2 x 10" and HF horns were driven from the same outputs. I made a simple active crossver circuit that went before the HF amp to filter the mid from the comp driver. Mixer was a 12 channel Soundtracs. Like an early CM 4400 but smaller. Still love Soundtracs consoles to this day. I had some outboard, I think there was a analogue delay line and a spring reverb.
I used this setup for discos and bands. Again hard to say when I first put it together but I think it was around 1984/1985, maybe earlier.
I wanted to get the pics I took when I used to mix stage 2 (1986/7) at Glastonbury festival for you Ian as we used loads of Martin 215 mk 2's and philles, but had to leave my sisters house before I could find them. I will get her to scan them for me as I think she knows where they are.
Hope you've all had a laugh at these systems, I know I have.
Best whises,
Rog.
Posted By: al_x
Date Posted: 16 October 2006 at 8:50am
no carpet?
i thought it was compulsary for disco's to have it.
Posted By: gingerbiscuit69
Date Posted: 16 October 2006 at 8:52am
that first one is a classic, but we all have to start somewhere!! remember mine was some dual 12" ported chipboard cabs, loaded with Fane Hiwatt guitar drivers and 2x celestion Ht50 horns per side driven with a carlbro 500 amp on the 12's fullrange, and an acoustic amp thing from argos on the tops, with bass right down and treble right up. sounded aweful!!
Posted By: MarjanM
Date Posted: 16 October 2006 at 9:04am
My first "sub" was looking just like a washing machine.
It was in a white box of exact wash mashine size with a 15 inch driver taken out of the bas guitar amp placed in the middle of the baffle.
Sweet isn it?
Date Posted: 16 October 2006 at 9:05am
amprack...
the speakers on top (that was my bedroom setup when i was 12!!)
Date Posted: 16 October 2006 at 9:50am
Wow,good man for finding the photos Rog,your first Sound facilities rig is virtually identical to my first proper 1978 rig...even down to the MM ap 360s!
 Here is a photo (hope u can see this Rog!) of one of the early stacks...home made plywood W-bin with 15"JBL K140 driver, Altec 816c cab with Altec 421-8h driver,HH radial horns (the mk11 variety)..12" mid flared cab with JBL K120 guitar speaker,and topped with a pair of peizos.....the Sound City 4x12s were used for a spot of"in fill"....worth noting that all the drivers (apart from the peizos) were alnico magnet,and the system had a lovely punch to it,albeit with nothing going on below 60hz!.....bear in mind this was 1978,and most peoples home hi-fi was about 25 watts,so 1kw of proper speakers certainly got some favourable comments...this system,although basic by todays standards,was better than a lot of club installs back then,and would still sound nice today..far better than Peavy Hi-sys!..not bad for almost 30 years old!
love to see the photos of your later Martin system.
Posted By: Strange Daze
Date Posted: 16 October 2006 at 11:33am
(goes to dig out old photies.....)
Posted By: Lasse Lukkari
Date Posted: 16 October 2006 at 11:58am
You guys have been doing this before I was even born (1983)...
Posted By: Static Age
Date Posted: 16 October 2006 at 12:15pm
indeed, when JBLman had that rig back in 1978 i was only one year old
Date Posted: 16 October 2006 at 1:00pm
surely that just makes a couple of these members feel old!?
Posted By: james folkes
Date Posted: 16 October 2006 at 5:10pm
still cooking today...
http://imageshack.us">
james.
mardy hippy.
Posted By: SmokeyJoe
Date Posted: 16 October 2006 at 5:12pm
@ GingerBiscuit69:
If you were 12 when u had that rig, how old are you know?? You gotta be very young coz i can see a modern collection of Harry Potter books on your top shelf...
- SmokeyJoe
Posted By: Jay Lawless
Date Posted: 16 October 2006 at 7:04pm
my rig when i was 13:
tops were loaded with a 10" PylePro PPA10 with a Piezo for highs, the sub was a 12" Digital Max ADF-292, the sub i still have have.
i didn't know much more then size, wattage and ohm rate at that time haha
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Date Posted: 17 October 2006 at 4:42am
lol, im 18 now, I had no pics of just the origional speakers, the subs and Alto amp were not there origionally. the amprack pic was the origional system .... however bad it is!
Posted By: djpix99
Date Posted: 17 October 2006 at 5:11am
my system in September 2005: Chipboard piezo box's, a pair of laney 100watt speakers, a pair of custom sound 200watt speakers loaded with carlsbro and eminence drivers and to finish off a pair of 300watt max skytec subs, all powered by a dynamix pa amp and a c-audio sr606(Which I still use know, but am upgrading soon, due to its weight) hehe
Posted By: Tom Umney
Date Posted: 17 October 2006 at 10:13am
My first system when I was 15 was way too sh*te to take a picture of. Basically was Tornado 300w max 3 way disco speakers with 12 inch bass + 5 and 1/4 inch mid, large piezo tweeter horn and a Sherwood hifi amp.
http://cgi.ebay.co.uk/TORNADO-ST-3-300W-FLOOR-STANDING-SPEAKERS_W0QQitemZ290039846938QQihZ019QQcategoryZ69967QQssPageNameZWDVWQQrdZ1QQcmdZViewItem - http://cgi.ebay.co.uk/TORNADO-ST-3-300W-FLOOR-STANDING-SPEAKERS_W0QQitemZ290039846938QQihZ019QQcategoryZ69967QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
These were exactly the same piece of sh*te I had. Except mine hit the dust bin a month after using them for parties.
Posted By: jethrocker
Date Posted: 17 October 2006 at 5:20pm
My first system: A pair of ancient Citronic chipboard w-bins, with nice stained wood edging and little piezo horns to cover tops. Ran them off a Realistic (Tandy) 200w amp, with sexy twin VU meters on the front-could have watched those needles swing all day..
No pics as digital hadn't happened and it's anyones guess where me old school photos are at nowadays. They looked wicked though..and at age 15, (with no knowledge of the negative effects of the folding on midrange frequencies) of course they sounded awesome too.
Posted By: mykey
Date Posted: 17 October 2006 at 10:19pm
 i left school in 1980, well it was 1979 actually my mum and dad didnt now nor did "Matterson's" at West Ham, dont eat matterson meat guy's you wouldnt believe what some of the workers get up to.
Rog and Jbl, i had almost the same rig as well
......just all them hanging there like giant bananas.
Posted By: super-hero
Date Posted: 18 October 2006 at 5:20am
This was the first set of speaker boxes that I built. The top boxes are loaded with EV drivers and Eminence horns. These were made before I had power tools. so all done with hand tools. The scoops are from the Eminence book and loaded with Eminence drivers. I had invested in a jigsaw to build these.
The scoops were built specificaly for my friends 18th birthday party, that's him in the photo.
They all got sold a while ago, but they are still out there being used, which is good.
I'm not an animal, I'm a human being.
Posted By: al_x
Date Posted: 18 October 2006 at 6:44am
first rig circa 2005  (the 4x10" mid tops we put 600w in each were only loaded with 25w clestion guitar speakers!)
Date Posted: 18 October 2006 at 6:57am
 Love seeing all this old rigs,funny thing struck me,most of these ancient rigs are still better than some of the current ones on Squatjuice!
Posted By: Mircea Bartic
Date Posted: 16 November 2006 at 1:18pm
While browsing trough my old pics I came across this pic
this was my first system
I've built it around year 2000 with a lot of sweat and tears
I was poor at that time, but I was happy
It took me about a year and a half to raise enough money...
in the pic there are 2 fullrange speakers (12" + 8"+ Piezo tweeter) and above that I had some really big horn flares loaded with nasty ear bleeding Piezzo drivers
the amp in the left is built by me and was a 2x150W / 4 ohms stuppidly heavy nasty speaker blowing piece of  s*it , but it was loud
the amp in the right (also built by me) is a 2x100W / 4 ohm used to power the HF horns (they were piezzo , so no crosovers were necesary)
the whole system sounded verry bad by my curent standards, but back then I was extremely proud
this was the first system that made the police show up everytime
the folowing pic is me & some friends of mine on 1 st of January 2000 (party for which the sound system was built for )
I'll let you guess which one is me
oh...., those were such happy times....
http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Posted By: Ted Blowhard
Date Posted: 16 November 2006 at 2:23pm
The gay one?
Date Posted: 16 November 2006 at 3:19pm
I'll pretend I didn't read that
Ex Nexus_3
Posted By: odc04r
Date Posted: 16 November 2006 at 3:55pm
Has the guy on the couch passed out and been drawn on or is that a really bad moustache
Posted By: TRE4U2NV
Date Posted: 16 November 2006 at 6:53pm
how do we put pics up found some old skool pics and probably mykey first solo build box  lol
Date Posted: 17 November 2006 at 6:35am
Ex Nexus_3
Posted By: Joe Grime
Date Posted: 18 December 2006 at 2:21pm
http://www.freewebs.com/jskpa/PA220002.JPG -
Posted By: xlogic
Date Posted: 19 December 2006 at 11:24am
Good thread
My first rig :)
ok the black and white in the 1st pic makes it look a lot older but that was taken summer 2002 or 2003 i think
Date Posted: 19 December 2006 at 11:57am
  Hey yes Xlogic,that black and white photo could have come right out of the 1970`s! looking good!
Posted By: DJ Coupé
Date Posted: 19 December 2006 at 12:05pm
Originally posted by gingerbiscuit69 gingerbiscuit69 wrote:
amprack...
nice marzocchi sticker gingerbiscuit.
im working on my first build at the moment. Its looking like 4 18" fane folded horn bins (or maybe cerwn bins dunno yet) 4 bill fitzmaurice tuba 30s (must remember to order the plans) loaded with jbl 2206 and im still pondering over mid and high. any suggestions
Posted By: major_gloom
Date Posted: 19 December 2006 at 4:25pm
james.
ha! james , i acquired one of those amps the other day , my mate dug it out of a skip! theres nothing much wrong with it other than a bit of a crackle when turning up the gains. (anyone know a good cure for this by the way?)
the only difference i can see between yours and mine are the MM logo on the front is slightly different and mine has xlr inputs rather than jacks.
i dont know anything about these amps , it doesnt even say the wattage on mine.
can you give me any info on them ? age , spec etc ... googles being no help.
ta
Date Posted: 19 December 2006 at 5:13pm
try some switch clearner in the pots then twizzle them round a bit .... its all the crap thats got in there in the past few years!
Date Posted: 19 December 2006 at 5:17pm
MM AP360...specs....2 x 180w into 8 ohms.2 x 240w into 4 ohms.age...they were made from 1977 up to about 1982.built in Royston Herts.
Date Posted: 19 December 2006 at 6:56pm
is that royston vasey?
Date Posted: 19 December 2006 at 7:29pm
nice one for the info by the way . do people rate these out of interest? it certainly seems quiet well built as most british built audio stuff of this era ive come across seems to be.
Posted By: Rog
Date Posted: 19 December 2006 at 7:45pm
MM 360 was great in its day as there was not much else around with that power, well nothing affordable.
Haven't hear one for years so can't coment on how they sound compared with modern stuff, but should hold up its own still.
The construction is tank like and almost bomb proof. The only problem might be that as your amp could be almost 30 years old, most of the caps will need replacing soon. It could also be hard to get the output transistors or other components if they go wrong. I know many of the transistors in the H&H V900 are obsolete now.
I love the way the amp clips, or dosen't seem to. You just keep pushing it and the sound gets a bit warmer. Thats the way an amp should clip. Rauch DVT's used to do the same thing. I powerd a lot of the first acid house parties from Rauch DVT 250's and its the only amp I've ever seen that you can run from the start of the night to the end with all the clips lights on at full brightness. And they never took out any drivers.
Rog.
Date Posted: 19 December 2006 at 8:45pm
i used to power my mids off the two mm ap360s, in all honesty i think they sounded slightly nicer then than now, but one c-audio pulse 4 x 300 gives them a little bit more power yet saves 6 rack units and about 40 kg... in spite of their complete lack of clip lights they are curiously easy to live with, i was waiting for audible distortion to set in before i backed off and for this application i never had to, they just sounded warm and crisp.
i'd be interested to find out what you think of/do with yours major gloom. if you tire of it i know of a good home!
james.
mardy hippy.
Posted By: jazomir
Date Posted: 20 December 2006 at 4:36am
Did you know that the MM stood for Mickey Mouse - not a name given by rivals or users but apparently by the manufacturers themselves, as even they thought the amps were so cheap as to be almost a joke.
ps The founders of the company had a known pedigree, but I have forgotten what it is. (I sound like the dead captain in Dark Star don't I?)
Date Posted: 20 December 2006 at 4:57am
Price comparrison from 1979......English amps..
MM AP360(jacks)......£180
MM AP360(XLRs).......£190
HH S500d..................£432
HH V800....................£470
RSD 800B/800C.........£440
Amcron DC300a.........£630 (american)
       The remarkable thing to note about these MM,is that despite being a budget amplifier,after 30 years,it is still working fine...these British amps from this era were beautifully engineered and built....i doubt if some of the modern budget amps like the Behringer 2500 will last even a quarter of that time.So much for progress.
Posted By: Rog
Date Posted: 20 December 2006 at 5:11am
Yep, they don't build um like they used too.
But I'm trying to.
Its why the series 2 Infinite amps are taking a bit longer than expected. I really want the new infinites to be built like the MM AP360 and the H&H V800. In the new Infinites If the design needs a 20 amp rectifier I've used a 30 amp one. If each cap has to be 15,000 uf I've used 25,000 uf. And I've speced the transformer 1KVa higer than is needed. The output transistors are the best I could find from Motorola, much better than the Toshiba everyone else uses these days. I wanted to go back to the metal T03 package transistor, but its so hard incorporating them to the heatsink.
I've had enough of the cheap import that lasts 1 year. The whole industry is starting to except things to go wrong and not care about it. Take the ultradrive and its frying egg problem. You buy one even though you know it might get the problem and fixes have come about that can show you how to put it right. We don't even blame the company that makes it anymore, we just look up on the internet how to fix it or get another one. Disposable world or what.
Rog.
Date Posted: 20 December 2006 at 7:39am
Thats great news Rog,i havnt bought any new equipment for ages simply for the reason you just said...i allways buy 15 year old stuff and then refurbish it,as i feel that almost all modern gear,what ever the make,allways seems to be built down to a price,rather than up to a spec..(the only exception i can think of is the excellent Lap Gruppen,and maybe Crest , Camco and FFA,but these are hardly budget amps)............i personally wouldnt mind paying an extra 15 or 20% more if the product had top-quality components that were built to last....im sure there are more members who would feel the same way?
Posted By: weezer
Date Posted: 20 December 2006 at 8:01am
Originally posted by xlogic xlogic wrote:
Good thread
My first rig :)
Was that Steart beach?
Glad To Be Of Help
Posted By: Rog
Date Posted: 20 December 2006 at 7:21pm
A big problem is getting good components nowadays.
Transistors can come from Japan are will be reliable, but other things may come from the other far eastern countries even if you buy from a well know UK manufacturer. Its making everything unreliable as the far eastern components are not the same standard as the UK parts used to be. It all roots back to the source. If a componet is made up of 8 different materials then its likely that the source componets could have probelms. So you now have a componet built of materials all with there own probelms and a final product bulit of componets that could have problems. Its not enough that everyone did the best they could during the manufacturing stages if the source materials are at fault.
I think the whole world is going to become a far more unreliable place as more and more compaines turn to the far east for everything. It would be a pity to let that happen and I'm trying my hardest to stop it. Even though I live in the far east. And I think its going to get a lot worse before it gets any better.
Rog.
Posted By: Laurence G
Date Posted: 21 December 2006 at 6:56pm
It doesn't help with different manufactures selling the designs from other companies for there components, and then building them slightly wrong.
I'm in a similar situation of designing electronics gear, and for our market if its sonically brilliant and ultra reliable whats the point, you might as well just get the off the shelf behringer which colours the sound and only lasts for one year!
Mmmmmm cheap leaking capicitors! grrr
Formally know as PGWLE,
Posted By: mykey
Date Posted: 21 December 2006 at 11:53pm
Rog.
then dont buy from China!
even there stainless steel goes rusty
Posted By: mykey
Date Posted: 22 December 2006 at 12:01am
funny you should say that! i was very happy when i was poor and your the one in the middle with the eyebrow's
Posted By: mykey
Date Posted: 22 December 2006 at 12:05am
so you have mine and Chris Allans first box from 1978?
if i think your gonna do what i think your gonna do then i wont give you your train spotting diaries back
and your cloggs from morris dancing at corrination gardens
Posted By: mykey
Date Posted: 22 December 2006 at 12:08am
1978 was when i built my first bass bin's
sorry for the many post's but i like this thread
Posted By: unclejam
Date Posted: 22 December 2006 at 12:14am
Rog.
well mikey plz tell mell where are sposed to buy yuor stuff from cuz i dont kno if you noticed this but uhhhh everything is made in china
Posted By: mykey
Date Posted: 22 December 2006 at 12:24am
trev4unv's clogg's are not made in China!
young man there are lot's of product's that are not built in China
Posted By: unclejam
Date Posted: 22 December 2006 at 12:35am
i know i know im jus pulling your leg hey i know this is a bit off topic but uh how much do you/would you charge for lab horn flat packs
oh yeah what are trev4unv's clogg's? tad bit curious
Date Posted: 22 December 2006 at 11:59am
ever thought of sending PM to mykey? if he replies here, rivals start bitching and there goes the forum on another bender!
Posted By: norty303
Date Posted: 22 December 2006 at 12:16pm
I don't think its TOO much of a problem people asking on the forum, just that the person being asked should answer by PM/email.
Hopefully the builders section will be set up soon.  I think once admin set up the new section (i don't think us mods can do that) we can set up a locked thread that the mods can add to as needed.
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Date Posted: 22 December 2006 at 12:23pm
excellent, either way thing have deffinatly improved as of late, so thats cool.
Date Posted: 29 December 2006 at 1:11pm
james.
i was considering using it to power the 4 B&C DE-500 tweeters which will at some point be loaded in the 4 x-tros we're half way through building and should be seen at some point during the summer causing all sorts of mischief on top of our 10 1850 horns. [ will 4 x-tros keep up with 10 1850 horns loaded with void v1000s by the way? i reckon they should, especially as all our crowd seems to care about is bass!] anyway one problem i noticed is the crackly pots which i mentioned earlier , ive also noticed a slightly more worrying problem . when the gains are turned all the way the volume cuts out completley , will this also be solved with a bit of switch cleaner in the pots and a 'bit of a twizzle'? or is this a more fatal problem.
also on the front of my amp it says MM electronics , manufactured by paice , which i didnt notice in james's , is mine a later version ? did paice buy out MM electronics ? any info on this subject would be greatly appreciated . ta . Will
Date Posted: 30 December 2006 at 6:07am
trying out the switch cleaner may solve your problems, it may not. you can only see. try cleaning a whole PA desk, last one i did involved cleaning over 500 pots! very VERY tedious but made it sound much smoother!
Posted By: Peter Moller
Date Posted: 30 December 2006 at 7:32am
Cleaning 2 pots in the MM amp might not be cost effective compared to replacing the pots right away...
If I remember it right those pots arent even PCB mounted, so its just as easy stopping by Maplins and getting a pair of 1£ pots and sticking them in..
One thing to try if they are PCB mounted and you are afraid of solderwork is Cailube MCL - expensive but works wonders on worn pots
/peter
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
Posted By: jazomir
Date Posted: 30 December 2006 at 7:54am
I think that PACE were the original manufacturers -  as I said in my earlier  post, the owners had previous history in the music/electronics business but I can't remember now what it was - I think that PACE may have been their joint initials, but am not certain.
Posted By: mykey
Date Posted: 31 December 2006 at 4:26am
i had amps that were MM PACE i also had to change the pots it was a dodle
Posted By: Robbo
Date Posted: 31 December 2006 at 6:18am
From what I can remember PA:CE came after MM Electronics had been going for a few years---I think one of the companies founders was Tony Reeves--now involved with ART equipment---When MM finally went bust there was a little company called Tresham Audio formed who cloned Klark Teknik Graphics and they really were quite good quality and they also made some crossovers as well.
Posted By: knet94
Date Posted: 05 June 2018 at 3:25am
Ben Wells, thought I would hit you up with this from all the way back in 2006.
