Show Off Your Passive Crossover
URL: https://forum.speakerplans.com/forum_posts.asp?TID=69557
Printed Date: 27 March 2026 at 7:52am
Topic: Show Off Your Passive Crossover
Posted By: djtuffer
Subject: Show Off Your Passive Crossover
Date Posted: 04 August 2012 at 2:20pm
This is my first passive crossover I have built from scratch.  I was quite pleased with it so I thought I would post a pic.
This is the response it gives. It's measured inside so isn't super accurate.
This is the biggest single component I have seen in a passive crossover in a pro audio cab.  It's a 12mh coil from an L2 Audio TX15 sub rated at 1000w.  I don't need them as I run the system active but It's an impressive size!
Show me yours!
Posted By: space-face
Date Posted: 04 August 2012 at 4:00pm
Nice work! Next time do it to NASA standards :-)
http://blog.makezine.com/2012/02/28/how-to-splice-wire-to-nasa-standards/" rel="nofollow - http://blog.makezine.com/2012/02/28/how-to-splice-wire-to-nasa-standards/
Posted By: lost eden
Date Posted: 04 August 2012 at 5:46pm
And don't use 3-core mains cable for speaker wire ;P
Posted By: djtuffer
Date Posted: 04 August 2012 at 6:00pm
What's wrong with using mains cable?  It's 1.5mm stranded copper.  What's wrong with that?
Posted By: colint
Date Posted: 04 August 2012 at 6:09pm
It could possibly overheat better to strip some 2.5 or 4mm speaker cable if you have it, The other thing make sure there's not the possibility of any of the cables touching. (the bare ends of the two blue wires seem a little close)
Other than that well done trying something that many people shy away from not many people even on here would attempt to build their own crossovers. Clap
Posted By: djtuffer
Date Posted: 04 August 2012 at 6:15pm
1.5mm is rated for 15a which is 1800 watts at 8 ohms.  It should be fine in these short distances.  I agree about the blue cables being a little close.  Will sort that.
Posted By: colint
Date Posted: 04 August 2012 at 6:24pm
Better to over engineer as far as I'm concerned.
To be honest most of the club sound installations in the 70's-80's were done on main's cable so (seen loads of them) including twin & earth so I wouldn't think it would be a major problem.
Posted By: boab
Date Posted: 04 August 2012 at 7:55pm
good effort.
Im sure you will see no problems with your wire just look at the capacitor leads.
Here is an x-over for one of my Hi-fi cabs (12" + 8" + Bullet)
Posted By: ceharden
Date Posted: 04 August 2012 at 8:31pm
1.5mm stranded is going to be absolutely fine on a crossover board.  In any case it's far thicker than a lot of the component leads!  Obviously common sense needs to be applied and if you're building a high power 4 Ohm crossover for example the currents are going to be higher and you'll need thicker wire.
Date Posted: 04 August 2012 at 8:43pm
Yes indeed,you should see some of the shonky thin wire i have seen in some supposedly good-quality hifi speakers over the years.
Nice job for a first effort by the way tuffer.
Posted By: MarjanM
Date Posted: 04 August 2012 at 9:45pm
Posted By: lukam
Date Posted: 05 August 2012 at 8:25am
Smile
http://imageshack.us/photo/my-images/842/mx15kretnica.jpg/" rel="nofollow">
Posted By: slaz
Date Posted: 05 August 2012 at 8:45am
Hope its not too much of a thread-jack ....
I've seen plenty of reference designs/calculators for passive Xovers around the place, but don't think I've seen any that cater for mixed driver impedances .... (although I haven't yet scoured around that much).
I'm likely to need a design for integrating a 4 ohm mid/bass driver with a small compression driver or possibly bullet (which is almost certainly gonna be 8 ohms) .... anyone have circuits/calculators for this ?
TIA.
Posted By: audiomik
Date Posted: 05 August 2012 at 9:27am
Slaz
this link might be of use: http://www.colomar.com/Shavano/crossover12db.html
otherwise some of the online Xover calculators ask for the impedance of each load to be entered
In both instances, expect to have to do some 'tweaking' of values for best results
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Posted By: slaz
Date Posted: 05 August 2012 at 9:47am
Originally posted by audiomik audiomik wrote:
Slaz
Mik
Thanks Mik .... will have a proper gander later ....
Posted By: djtuffer
Date Posted: 05 August 2012 at 12:14pm
I have found that these crossover calculators don't realy work.  You have to spend a lot of money on pro stuff like LEAP before you can get simulations that get close to reality.  Trial and error is the best way in my opinion.
Posted By: ceharden
Date Posted: 05 August 2012 at 12:42pm
The majority of crossover calculators will only give 'ideal' values, assuming flat frequency and impedance responses for the drivers etc.  You can use them as a starting point providing you take the other factors into account.
