series/parallel
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=70517
Printed Date: 26 March 2026 at 9:25pm
Topic: series/parallel
Posted By: crystal.a
Subject: series/parallel
Date Posted: 05 September 2012 at 10:29pm
is there any way using a combination of series/parallel wiring i can run 3 bins a channel without it being a 2.66 ohm load??
hell is just a word, the reality is much much worse!
Posted By: djeddie
Date Posted: 05 September 2012 at 10:36pm
If you have 2 bins in series that are then paralleled with 1 bin, you have a load of 5.33Ω... however, you've got the power issue to contend with then.
That is presuming that the bins are 8Ω.
Posted By: Creative
Date Posted: 05 September 2012 at 10:49pm
not to mention that some of the amp's power will be split over the two series bins whilst the one in parallel will be trying to cope with the all the rest by itself!
Time flies like an arrow - fruit flies like a banana!
Posted By: numtie
Date Posted: 05 September 2012 at 10:50pm
never mind the fact 2 of the drivers will recive more power than the third
Disco Hire Wales
Posted By: numtie
or at least i think thats right
Disco Hire Wales
Posted By: numtie
Date Posted: 05 September 2012 at 10:52pm
well i suppose it depends on which has the less resistance the single alone driver or the 2 wired together... and yay tripple post
Disco Hire Wales
Posted By: Creative
Date Posted: 05 September 2012 at 10:57pm
the single bin will have half the resistance of the two series bin so it will be stuck with most of the amp power. Not a good idea. Either only use two bins or get another to make four. Then wire them in series/parallel.
Date Posted: 05 September 2012 at 10:59pm
so with the right amp choice with a little headroom it is a possibility or am i just going to blow a driver/amp, trying to build this system on a budget as i had to sell my last rig for financial reasons.
Date Posted: 05 September 2012 at 11:00pm
little more info i want to run 3 HD15's a side so 6 in total
Posted By: djeddie
Date Posted: 05 September 2012 at 11:02pm
What amp are you planning on using?
Date Posted: 05 September 2012 at 11:10pm
possibly a matrix xp5k not a 2 ohm stable one though
Posted By: numtie
Date Posted: 06 September 2012 at 12:59am
hmm no easy solution i think the choices are
drop 2 of the hd's to run two aside
get another 2hd's
get an amp that will run 2ohm stable
or get a second amp to run 3 pairs
Disco Hire Wales
Posted By: Timebomb
Date Posted: 06 September 2012 at 1:42am
could run 2 banks of 3 in series 24ohm/2=12ohm and bridge the amp then your running 6 ohms a channel?
Date Posted: 06 September 2012 at 12:40pm
Thankyou Timebomb sounds perfect can't find the specs to the xp5k now so not sure what it would be putting out at 12 ohms?
Posted By: Timebomb
Date Posted: 06 September 2012 at 2:32pm
See what you mean its not the easyest amp to find specs for...id guess as its called a 5k thats not rated below 4 ohms per channel then its about 2500W per channel at 4ohms, wich is 5000W at 8 ohms bridge (if it does bridge)so say about 3000W at 16ohms bridge and 4000W at 12 ohms bridge which into 6 drivers is 666W each.
Date Posted: 06 September 2012 at 2:45pm
so that should be fine across 6 pd154's then? :)
Posted By: Timebomb
Date Posted: 06 September 2012 at 2:58pm
Yeah would be about right id say,  assuming that amp does what i guessed it does, might be an idea to PM andy and check.
Date Posted: 06 September 2012 at 3:09pm
good plan i think the amp will need to go back when i get it anyway it has a channel down so i'd best get in touch with him.
Thanks for the advice
Posted By: jacethebase
Date Posted: 06 September 2012 at 4:08pm
I would seriously suggest changing the amp. Or send the amp back to matrix for a 2r update thingy.
All this messing about sounds like a Carnival float...
Posted By: colint
Date Posted: 09 September 2012 at 9:48am
Just what I was thinking. there's always the thing if the amp goes pear shaped you lose use of all the cabs too, (not good in a room full of punters) better in the long run to do it right the first time.
Either buy two amps or better still buy two amps and another pair of cabs and be safe.
