Par 58 ?
Category: Other Chat
Forum Name: Lighting Talk
URL: https://forum.speakerplans.com/forum_posts.asp?TID=72080
Printed Date: 26 March 2026 at 8:17pm
Topic: Par 58 ?
Posted By: Stray-Sounds
Subject: Par 58 ?
Date Posted: 29 October 2012 at 8:54pm
I had some pre cut Par56 gels delivered....they were too small...
I sent them back explaining that they didnt fit my Par56.
They sent me replacements and told me that I was using Par58.
Does a par 58 can exists?
Posted By: csg
Date Posted: 29 October 2012 at 10:50pm
no, par 64 is probably what they were referring to, being the only par lamp larger than a 56.. par 16/20/30/36/38/46/56/64 are the options.
Date Posted: 30 October 2012 at 11:28am
Interesting... As the Par64 gels they supplied me fitted my Par56 perfectly. And were *just* big enough to fill a Par64 frame.
Par58 doesnt exist....so they're just silly billys!
Posted By: James Tengo
Date Posted: 30 October 2012 at 1:41pm
Do you have pulsar Par 56's by any chance? They made parcans which took both sizes of lamps, which had a par 64 sized frame. Most companies will cut a roll of gel so they can get the most cuts out of it, with par 64's (255mm x 255mm) you can just squeeze 5 cuts out of the width of a roll (1220mm) if you under-size the cuts slightly
Date Posted: 30 October 2012 at 4:52pm
They're 'Thomas' and not big enough to use with a Par64 lamp
Posted By: The Garglebard
Date Posted: 30 October 2012 at 5:16pm
Did you get them from e-bay?
I have recently bought some long-nosed Thomas par 64s (x6) and I've yet to lamp and gel them.
I'm planning on putting 500w lamps in them - hope they'll fit. Is the issue the diameter of the lamp being too large to fit?
These are the ones:  http://www.jamesthomas.co.uk/jte/lighting/par64-56-46.aspx" rel="nofollow - http://www.jamesthomas.co.uk/jte/lighting/par64-56-46.aspx
edit - added link.
Date Posted: 30 October 2012 at 7:26pm
The Thomas cans are what we mostly stock, sounds like whoever you bought the gels from sent you the wrong cuts, and only sent you the right ones after spinning you a yarn. For the most part Par 64 frames are 10" square (255mm x 255mm) par 56 frames are 7.5" square (190mm x 190mm) and par 46 I've had to look up, but are 6.24" square (158mm x 158mm) We cut our par 64 sized cuts at 244mm x 244mm, which means you can cut 5 across a roll with no waste. The gel covers the hole in the frame but doesn't reach the edges of the frame. Measure yours and tell us what size gels you were sent
Date Posted: 30 October 2012 at 7:44pm
Garglebard - the available par 64 sized 500w lamps are CP 87 - Narrow spot and CP 88 - Medium Flood. You can also get raylight reflectors but I find them to be fairly rubbish - splodgy output and tend to burn through any gel you place in front of it in record time
Date Posted: 30 October 2012 at 9:30pm
Thanks for that James - for a minute there I was thinking that I'd struggle to get lamps to fit.
Good link too - not a bad price (although it will be expensive as I need 6 plus a spare) Ouch
Cheers
Posted By: Pete
Date Posted: 12 December 2012 at 1:48pm
Pretty sure you can get a CP86 too which is a 500w vnsp
Posted By: Preacher
Date Posted: 12 December 2012 at 6:01pm
http://forum.speakerplans.com/lighting-basics_topic22773.html" rel="nofollow - forum.speakerplans.com/lighting-basics_topic22773.html
From lighting basics thread, fifth post down all about PAR cans and PAR types, and indeed no thing like a par 58.
Wink
It's all about the music & the vibe, so enjoy it while you can.
