15" reflex cab
Category: Plans
Forum Name: Ported Enclosures
Forum Description: Post all your reflex and bandpass and 'other' boxes with holes in stuff here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=72392
Printed Date: 27 March 2026 at 6:53am
Topic: 15" reflex cab
Posted By: GAZ.
Subject: 15" reflex cab
Date Posted: 09 November 2012 at 2:32am
Looking to build or maybe buy some cabs for fane 15XB's to use on smaller venues.
What's going to be my best option? Fane constructor Cab? B&C sub 15? Or something else?
Need to be as compact as possible without affecting performance.
100% Earth Moving Bass
Posted By: basshead2012
Date Posted: 09 November 2012 at 11:28am
sub15 all the way!
Posted By: dlyxover
Date Posted: 09 November 2012 at 5:47pm
I've recently build some reflex cab for 15xb's.
They sound great but in my opinion the box need is not that compact (i went for 140l gross cab) and there are other drivers that can give more output in a smaller cab but cost more ££!!
But they do sound good, i use 2 of them as drum fill subs at the moment and drummers seem very happy.
Lignum_ww@icloud.com
GNKaudio@icloud.com
Posted By: GAZ.
Date Posted: 10 November 2012 at 5:43pm
I prefer the look of the sub 15, might end up building those.
Posted By: hmaudio
Date Posted: 10 November 2012 at 6:12pm
what about the rcf sub15
built 20+ of these for forum members and everyone's been more that happy
Posted By: GAZ.
Date Posted: 10 November 2012 at 7:05pm
That could be a possibility too, you got any pics of built ones?
Posted By: trentp
Date Posted: 13 December 2012 at 8:32pm
will a kappa pro work in this box?
Posted By: t.geessounds
Date Posted: 03 February 2013 at 6:29pm
i have 4 rcf lf15p200ak that i want to used them for low mids over scoop is it ok to build this box for the l12p200ak an play them about 60 to 160 or is it best to build a cab that tune highter ???
Date Posted: 03 February 2013 at 6:35pm
Hey guys i was looking for a 15" reflex plans for kick bin
an found these i have 4 of the L15p200ak is it best to build this same cab an run them as low mids over scoop like around 60/70 to 160 or its best to build a box with a highter tunning ????
thanks
Date Posted: 03 February 2013 at 6:48pm
Posted By: Ras Loud
Date Posted: 03 February 2013 at 7:22pm
thanks
I asked the same questions once and TonyA.S.S. responded that the tuning frequency does not matter at all if you run them higher. Above my scoops I use the L15P540 (but in a different box) from 90 to 200 and they sound fine.
When I was looking for kick bin designs, I could hardly find anything with much higher tuning frequencies, because usually all these boxes are supposed to be subs as well, but can also be used as kicks above other subs.
But what is actually the difference between the tuning frequency and the LF limit? I always thought boxes should not be played lower than the tuning frequency.
Date Posted: 03 February 2013 at 7:27pm
thanks
Posted By: pk1964
Date Posted: 28 July 2013 at 9:30pm
How high will this play 200 hz ?
http://www.paulkellyevents.co.uk" rel="nofollow - My Link
Posted By: mini-mad
Date Posted: 28 July 2013 at 11:01pm
depends on the driver really.......
i dont know what i was thinking wen i wrote this most 15" drivers should play "ok" upto 800hz
...ya just wouldnt,  theres a few other cabs iv looked at too...
Posted By: pk1964
Date Posted: 14 December 2013 at 10:03am
Mini mad what would you recommend got to go upto 200 to meet my mid cabs, need to build next week help anyone ?
Posted By: charlynch
Date Posted: 14 December 2013 at 12:56pm
A reflex cab will easily go to 200.
If you list what the rest of your gear is, what music you play & how many peeps you want to cover you will get better advice.
Posted By: generalant
Date Posted: 03 January 2014 at 2:11pm
im after the same sorta thing a 15" relex cab to go above sccops, using fane collosus drivers. Is the sub 15 gona be a better bet than the Fane constructor then?
Posted By: Porky
Date Posted: 04 February 2014 at 2:08pm
The little rig I'm currently building is based on the DM2 plans but split into separate cabs so I can lift them on my own.
Design uses Kappa 15 LF crossed at 250 Hz. Iirc box is about 120 Ltr gross tuned to 46 Hz. Have the wood cut and ready to build so can't comment on what they sound like just yet.
Posted By: king david
Date Posted: 30 March 2015 at 9:54pm
are these plans for 20mm, 19, 18 or 15mm wood? thanks!
Posted By: Brother T
Date Posted: 30 March 2015 at 11:45pm
I have some newly built RCF sub 15s on the bay for sale at the moment.If anyone is interested pm me.Special deal for sp members.
peace and love
Posted By: Geoff
Date Posted: 06 May 2015 at 8:15pm
How much would it cost to have four made and could they be made from 22 mm birch ply
Posted By: Geoff
Date Posted: 06 May 2015 at 8:16pm
Posted By: MarjanM
Date Posted: 06 May 2015 at 8:51pm
Why 22mm? That is a bit overkill for a 15 inch sub.
Date Posted: 07 May 2015 at 12:01am
...i would still ask what is the thickness of the wood in those rcf plans, may build a pair...
Posted By: krazyneil
Date Posted: 07 May 2015 at 12:25am
18mm
GOD TOLD ME TO DO IT !!!!!
Posted By: stanley dj
Date Posted: 20 May 2015 at 8:51pm
all  all    i have  one   done      anybody  putting  wadding inside ?    and much  ?
Date Posted: 03 November 2015 at 1:53am
so i take it that this is the enclosure for the RCF L15PAK?
thanks
Posted By: bob4
Date Posted: 03 November 2015 at 8:54am
have to agree, higher tuning doesn't bring any benefit. I simulated single L15P200AK in a small reflex. if you high pass it BW 8th order  at 80 Hz, you can give it the stick until it runs into the thermal limit without exceeding xmax. With 1600 W (rated peak power) it will dish out 127 dB
Date Posted: 03 November 2015 at 7:42pm
hi all   i have  buil  one        did  anybody put  any wadding  inside   ?  and  much
Date Posted: 03 November 2015 at 10:53pm
you should deffo put wadding in, either eggshape the walls or stick wadding all the way round
Date Posted: 03 November 2015 at 11:02pm
thanks
that is rcf own plan, just use the different dimensions as listed for your driver , id hazard a guess they know what there doing with there own drivers lol
Posted By: Norseman
Date Posted: 12 December 2015 at 12:29am
i am looking to take the 15"s out of these cabs that i have:  http://www.bob-audio.com/en/FS252.php
and build something similar (single cab per driver)
i currently run these over top of two super scoopers, sounds good, but because the BOB cabinets are so tall it makes it a pain to set up by myself, also very heavy.
is anyone godo with designing things to a drivers specs?  i cutoff at 100Hz for the scoops and run these over top.  it also has a 2" compression driver in it with what i assume is an internal passive x-over
i will likely put these comp drivers in their own box with the passive x-over in it, or run them spereately with other tops off another amp in the future....
the quoted design above looks pretty good...i suppose it is a question of measuring the box they are currently in but it is trapezoid in nature and i am not so sure on how to calculate the port length and opening size as its a weird design inside from that perspective (shelf between comp driver and the lower part, ports on either side of the comp driver etc etc
any help would be awesome
