whats the angle & cut list
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=72772
Printed Date: 27 March 2026 at 8:46am
Topic: whats the angle & cut list
Posted By: nuclearbass
Subject: whats the angle & cut list
Date Posted: 20 November 2012 at 8:01pm
probably a real simple answer
but whats the angle on these cuts
one life - have fun!
Force fusion pro audio
Posted By: Muckerbarnes1
Date Posted: 20 November 2012 at 8:57pm
45 or 135, depends which way you pass through the saw. So 45 deg.
The drw still mkes a triangle when you move the 382mm  up to the 470 sides. The back corner is 90 deg. A triangle has 180 deg. The remaining 90/2 = 45..
Billy Dawg.
Posted By: George C
Date Posted: 20 November 2012 at 9:15pm
wont be 2x 45 degree angles as the two long sides are not equal....  ie 430 and 470
however I'll be damned if I can remember how to work it out exactly but I'm sure there's some trigonometry required and I'm far to long out of school for this one... sorry  Cry
happiness is a ticked off list
Date Posted: 20 November 2012 at 9:44pm
jurys out on this one then lol
Posted By: cravings
Date Posted: 20 November 2012 at 10:17pm
i did make some of these.. can't remember the working out though. thought i had drawn them up in cad but i don't seem to have..
Posted By: cravings
Date Posted: 20 November 2012 at 10:19pm
Angle: 139.236395°
Angle: 130.763605°
Posted By: cravings
Date Posted: 20 November 2012 at 10:20pm
left first, right second, as i've listed them...
Posted By: George C
Date Posted: 20 November 2012 at 10:24pm
Angle: 139.236395°
Angle: 130.763605°
don't quite know how you did it but sounds good, better than 2x 45 degree   Smile
Date Posted: 20 November 2012 at 10:43pm
im a simpleton,
red =
green =
black =
purple =
Posted By: cravings
Date Posted: 20 November 2012 at 10:55pm
what i gave you is the angles between the 2 lines, the 180mm line, and the 382.
when it comes to cutting wood, pick something doable on the saw, and good to join up...
did it in cad quickly...
Posted By: Jez_3phaze
Date Posted: 20 November 2012 at 11:01pm
Ah, yeh got you, cheers mate
Date Posted: 20 November 2012 at 11:03pm
Jez that's spot on Thankyou :)...
Have you built this?
What have you loaded this with if so?
Date Posted: 20 November 2012 at 11:14pm
No mate. I'm just used to Google Sketchup.
It don't half help when your checking measurements. ;-)
Date Posted: 20 November 2012 at 11:22pm
Ah right, cheers. First time I've gear if that
Date Posted: 21 November 2012 at 1:38am
Just looked at this with my glasses on!
Oooh, eck. There are two sides of the Pentagon different!
From a constuction point of view why the heck make hard work. Make both the subs same.
A pentagon has 540 deg internal. Therefore; 90+90+90= 270. 540 - 270 =270. Therfore 270/2 = 135 or 45 on a saw bench. However the substrates are different lengths and the Google sketch is correct.
So to compose a completion.. 540 -270=270/2=135. Correct for a regular Pentagon (polygon) for this application where the subs are different the remainder of 270 deg is divided into 2 different angles. From Cravings and Jez cheating Google sketch 270- 49.2-40.8=180. Flip the timber over 180 and that is nulled. So External cuts= 49.2 and 48.8 deg. WTF!. Just cut it at = lengths, have a beer and enjoy a simple life.
Billy Dawg.
Date Posted: 21 November 2012 at 8:45am
If I cut it at equal lengths it wouldn't be a floor wedge then would it
Date Posted: 21 November 2012 at 9:02am
A door wedge? it would be 45 deg.  Many are at 45. EAW for example have 45, 30 etc.
It's quite steep as it is at 40 deg.
Billy Dawg.
Date Posted: 21 November 2012 at 9:43am
yeh i supose your right, ive not realy had a scout round, ill see if i can find s more stable wedge
Date Posted: 20 December 2012 at 1:29pm
right then, seems im going to have a go at this then.
would this cut list be right ??
baffle = 434 x 714
bottom = 470 x 430
top= 470 x 430
left side 430 x 714
then the smaller angled from right to left
1 = 180 x714
2 = 418 x 714
3 = 162 x 714
i know there sa few angles and the top and bottom will need cutting to shape, but am i right with these cut sizes?
Posted By: odc04r
Date Posted: 21 December 2012 at 12:27am
Save yourself the grief of thinking and draw it in sketch up Big smile
Date Posted: 21 December 2012 at 7:53am
Date Posted: 21 December 2012 at 10:30am
I've got google sketch up now but couldn't fathom out how to use it lol
