MT-130 doubt
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=74546
Printed Date: 23 April 2024 at 8:17am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: MT-130 doubt
Posted By: superspunk
Subject: MT-130 doubt
Date Posted: 17 December 2012 at 5:04pm
Anybody knows the dimension of D??
Posted By: JR.junior
Date Posted: 17 December 2012 at 5:11pm
71-(4x1,8)
------------- Support the scoop technology, larger mouth plays louder!
Date Posted: 17 December 2012 at 5:18pm
I dont understand your answer... (4x1,8??)
Date Posted: 17 December 2012 at 5:30pm
Date Posted: 17 December 2012 at 5:35pm
1.) 1,8cm thickness of panel. (chipboard, mdf): 71,7-7,2=64,5cm 2.) 1,9cm thickness of panel (ply): 71,7-7,6=64,1cm
Posted By: mini-mad
Date Posted: 17 December 2012 at 5:45pm
JR.junior wrote:
1.) 1,8cm thickness of panel. (chipboard, mdf): 71,7-7,2=64,5cm 2.) 1,9cm thickness of panel (ply): 71,7-7,6=64,1cm |
should the baffle not be 30mm ofset from being flush with the front of the cab?
------------- If it sounds like a gorilla is trying to escape, turn it down.
Date Posted: 17 December 2012 at 6:19pm
Another way for the question...
D1 and D2 ??
Date Posted: 17 December 2012 at 6:35pm
whatever!
Date Posted: 17 December 2012 at 7:05pm
Ok, so you suppose that x = 2 x 1,8.. Why?
Posted By: kevinmcdonough
Date Posted: 17 December 2012 at 7:49pm
hey
The short answer is that it doesn't matter.
Compression drivers, being sealed drivers by default, dont need to worry about the size of the chamber they are in, they dont need any particuluar volume to work. So you can set the baffle that the horn screws into wherever you want really.
As people have said you'll probably want it back 30 or 40mm from the front so that you can get a grill on if you plan to use one, but other than that you can decide yourself.
k
Date Posted: 17 December 2012 at 7:50pm
Posted By: mini-mad
Date Posted: 17 December 2012 at 7:54pm
JR.junior wrote:
looks good to me.... being 2x18mm should make leveling out the baffle much easier
Posted By: _djk_
Date Posted: 18 December 2012 at 6:48am
None of those dimensions are critical, use whatever works.
------------- djk
Date Posted: 18 December 2012 at 12:32pm
My real question is about the position relative to the other driver. They dont have to be aligned? Or it must be processed with delays?
Posted By: cravings
Date Posted: 18 December 2012 at 12:53pm
they'll have to be aligned anyway, yes.
Date Posted: 18 December 2012 at 1:04pm
I rephrase the question: Which is the distance relative between the 2 drivers??
