Proud owner of mini turbo scoop
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=7456
Printed Date: 27 March 2026 at 8:24am
Topic: Proud owner of mini turbo scoop
Posted By: Jamo supa powa
Subject: Proud owner of mini turbo scoop
Date Posted: 24 November 2006 at 3:57pm
i am the proud owner of 8 of those turbo scoops built and designed by mr ultimate in the west mids toppa top bassbox builder dis side of europe and believe me they sound how they look got rid of fane xb's and all now pd loaded ,stand to close and they stop you breath Ha Ha !!!!!!!!!!! check ebay for contacts peace.
J S P 1
Posted By: djstefanos
Date Posted: 25 November 2006 at 8:19am
pics
Date Posted: 25 November 2006 at 2:17pm
check ebay  under bass bins also check toxic
J S P 1
Posted By: james folkes
Date Posted: 26 November 2006 at 2:36am
i think he means http://cgi.ebay.co.uk/BASS-BINS-MID-TOP-CABS-BUILT-TO-SPEC_W0QQitemZ200049981587QQihZ010QQcategoryZ69967QQrdZ1QQcmdZViewItem - this chap.
jsp, could you explain what a mini turbo scoop is please?
james.
mardy hippy.
Date Posted: 26 November 2006 at 9:46am
the mini turbo scoop is a scaled down version of the rear horn loaded scoop with internal adjustments calibrated with a db meter and spectrum analyser in order to give you the close if not same high powererd deep bassline as the larger version of the box at a given frequency ie 30 40 50 hertz .Its a tuff box and can be nearly lifted up by one man check mr ultimate in west mids for more info he's good
J S P 1
Date Posted: 26 November 2006 at 5:07pm
most people here build their own boxes, but i'm sure that info will be of use to someone. i get the impression he'll take on whatever you need.
regarding scoops, i find the taller bins easy to get in and out of the van as i can rock them in and flip them so the weight is at the bottom at the same time, a one man job. heavy stubby things are a two man lift for me, my spine has suffered from this hobby and has aged prematurely...
anyway, some pictures of your little ones would be nice.
james.
mardy hippy.
Posted By: Insomnia
Date Posted: 27 November 2006 at 1:15pm
i read somewhere before- it hink a mykey post ,
that the Micro scoops that guy builds are just cut down Fane designs
Posted By: Tekasis
Date Posted: 28 November 2006 at 10:25am
Congratulations mate, U sound well happy with them.
Done the same thing, outed my XBs & got PD & Void instead.
Checked him already, have to agree, he is good. Will be collecting my order from him very soon. He will reads this.
Jamo supa powa, did you go for the 15'' or 18'' version ?
Date Posted: 10 December 2006 at 9:02am
GOT THE 18" VERSION BIGGER THE VENUE BETTER THE SOUND
J S P 1
Posted By: Tekasis
Date Posted: 10 December 2006 at 9:24am
True JSP.
I'll be trying the Void V-18 1000, PD186 & PD1850 in mine soon when I pop up there to see what I'm finally going to go with. I wonder what the PD neo 18'' would be like in them or any other Neo 18'' driver actually.
We tried the 18'' Volt driver in one last time but it wouldn't fit (rear chamber board too near)
I wanted to test them with my JTS pre-amp but it's in for service/upgrade at the moment. (It can play a bit lower then them mixers, you get me)
'Njoy them.
Laterz.
Posted By: Tekasis
Date Posted: 04 January 2007 at 5:53pm
JSP how's them cabs going ?
You rock down any where with them yet ?
Be up there this coming w/end I hope, as mine are finally finished. Will be bringing a couple different drivers with me to see what this scoop can really do & If they can drop as good as they look.
Catch up with you & the guys soon.
They look so criss loaded with the PDs...
Posted By: Tekasis
Date Posted: 07 January 2007 at 12:51am
4 of these should give us what we want.
Conclusion:
PD1850 run tings.
V18-1000 let me down big time!!! That's why it's parked up to one side.
Posted By: Tekasis
Date Posted: 20 January 2007 at 1:04pm
I used the Mini-Scoop I got from 'Ultimate Sounds' in the Midlands which was loaded with a PD1850 in a Community Center Hall yesterday, along with one of Shortman's full scoops loaded with a Void v18 at the other end of the hall.
I can tell you, I'd wasted my time bringing the rest of the scoops with me (well good for back-up), just the 2 of them was more than low enough on bass line.
The owner of hall had to tell me there's no way can I play the system like that all night, as the bass too heavy & would affect the neighbours & the local pub across the road.
Big up yourself Ultimate Sound, the Mini-Scoop sounds ruff.
Posted By: Tekasis
Date Posted: 20 January 2007 at 1:10pm
Moderators, took me ages to find this post, you think it's worth moving to the scoops dept ?
Date Posted: 20 January 2007 at 4:53pm
All done Tekasis!
Posted By: craig34
Date Posted: 20 January 2007 at 11:17pm
hello i live in the united states. where can  i get scoops from, are where can i get them made. looking for micro scoops or full scoops. thanks. im in louisiana,usa(337-594-1764)
Posted By: djpix99
Date Posted: 21 January 2007 at 4:11am
Im very intersested in these, could anyone tell me the rough external dimensions of these? Cause size is a big issue for me.
Thanks
Posted By: Tekasis
Date Posted: 21 January 2007 at 9:33am
If Jamo S P doesn't let you know, when I get them off the van, I'll let you know Dipix99.
Don't know where you're located, but the builder is in West midlands.
A builder in South London makes them too & his size are:
35'' high
30'' deep
23'' wide
Cheers.
Thanks for the move JBL.
Posted By: Tom Umney
Date Posted: 21 January 2007 at 4:42pm
35'' high
30'' deep
23'' wide
Cheers.
Not bad size at all.
Date Posted: 21 January 2007 at 4:49pm
Conclusion:
PD1850 run tings.
It's strange, as that looks bigger than Shortman's Mini scoop.
