X12 Port
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=75094
Printed Date: 27 March 2026 at 9:30am
Topic: X12 Port
Posted By: t.geessounds
Subject: X12 Port
Date Posted: 10 January 2013 at 1:24am
hey guys i want to do a pair of x12 but i want to know if i can keep the same design an port for a pair of
Selenium 12PW3-SLF
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-334
Posted By: DiscernAudio
Date Posted: 10 January 2013 at 3:31pm
I sim'd two of those drivers in an X12.
I did not account for the volume displace by the horn and CD,
If you give me a rough volume of those i will re run it.
See link....
http://img580.imageshack.us/img580/524/untitlghjed.jpg
Date Posted: 10 January 2013 at 4:07pm
It will work in the X12, but you will want to cut them around (roughly guessing) 175 Hz to avoid excessive cone movement and the power compression going on.
Otherwise it is pretty flat from 200-1000Hz
Date Posted: 10 January 2013 at 5:07pm
Just played around with the new PRV Audio 12W700
It works well in an X12, it plays much lower F3=62, no power compression.
Its in the same price range as te selenium, but less sensitive and requires more power.
And its cone stays within xmax all the way down to around 50hz
But I dunno its quality/reliability since its a new company
