New horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=75903
Printed Date: 26 March 2026 at 7:42pm
Topic: New horn
Posted By: Steve_B
Subject: New horn
Date Posted: 04 February 2013 at 12:00am
I know you like looking at pictures, so here is one of a horn I am working on which came off the mould today. It is for a 2" exit drive unit and I'm hoping for a 60 x 40ish dispersion.
It is 32cm wide by 23cm high which was chosen as a direct fit in to a cabinet I already use. It is also similar to a few horns out there from other manufacturers.
I just need some reasonable weather to do some measurements now.
Posted By: mykey-
Date Posted: 04 February 2013 at 1:38am
Very nice Steve. My favourite colour too.
Can we have a profile picture?
Posted By: Steve_B
Date Posted: 04 February 2013 at 12:42pm
Yeh, I'll put one up when I get the chance, plus some on and off axis response curves.
Posted By: Timebomb
Date Posted: 04 February 2013 at 12:48pm
Nice, is the first section conical, then the second section a bit more curved?  Is it a kinda 2 stage constant directivity with the second section smoothed to the mouth termination?
Posted By: VECTORDJ
Date Posted: 04 February 2013 at 12:51pm
A+    How did you make the plug??  VECTORDJ
Posted By: Steve_B
Date Posted: 04 February 2013 at 8:08pm
Here is a side view
The apparent change in flare rate is an illusion caused by the light. There is a gradual curve as the round throat changes to the oval mouth.
The plug is hand made. I stack disks and use filler. Sanding and several templates then get me to the required shape. CNC or a 3D printer would be quicker and more accurate, but at this stage I don’t know if the design is viable and I have more time than cash.
Posted By: Lee In Montreal
Date Posted: 04 February 2013 at 9:01pm
Makes me thing of a good old JBL horn, as used on $35k Paragons or 2395 lenses. Just shorter.  Nice work BTW.
Posted By: Steve_B
Date Posted: 04 February 2013 at 9:47pm
I hadn't actually considered that, but you're right. I used to use some of the RCF horn/lens assemblies and they had an elliptical mouth. They sounded nice without the lens too.
Posted By: VECTORDJ
Date Posted: 04 February 2013 at 10:57pm
Hi, Does the slight curve cause beaming at the top end???  I looked into 3d printing and found it very $. Maybe I was looking in the wrong place.   VECTORDJ
Posted By: ceharden
Date Posted: 04 February 2013 at 11:28pm
Looks a lot like the 18Sound which I am a big fan of.  I think you might be onto a winner!
Posted By: Steve_B
Date Posted: 05 February 2013 at 12:12am
I'll let you know when I measure them. With a 2" throat the horn won't have much control above 8KHz.
I did these as a replacement to us in some cabs I already have which use a design similar to the BMS 2230. It seems to be a generic design as I've seen essentially the same thing done by a number of manufacturers. That obviously set the size of the mouth which is 32cm by 23cm.
If everything works to plan I'm looking at about 60 by 40 above 2KHz and a graceful widening (loss of control) as frequency drops down through the crossover frequency which is presently set at 1100Hz
Posted By: Steve_B
Date Posted: 05 February 2013 at 2:37pm
I managed to do a quick measurement this morning.
This was the set up:
The driver is a P.audio BM 750
First a freq response on axis with no eq:
These off axis plots were done with a 1.2KHz hp filter. I didn't measure the angles and just rotated the cab around on the stand.
The yellow plot is about where I was expecting the reasonable limit to be and the white plot is way outside  the coverage angle I'm aiming for.
I just need some warm weather now to start experimenting.
Posted By: Dref
Date Posted: 05 February 2013 at 2:51pm
Hi Steve
Looking good as always. What is the color code, looks almost identical to the color of my TVRTongue
The measurements actually looks quite good considering the setup and the driver used. It must be a nice sounding horn. Smile
A proper build subwoofer will be the only thing in a room that is not shaking.
Posted By: Steve_B
Date Posted: 05 February 2013 at 6:41pm
The colour is just one of the standard pigments they stock where I get my supplies from. It is called golden yellow. I’ll have to check on the can to see what the code is. I was using it to make a sledge a couple of weeks back and thought I’d try it on the horns.
With regards the response graphs, the most noticeable anomaly is the dip in response between 2.5KHz and 3KHz. I suspect that this is caused by reflections off the edge of the cabinet. The flange thickness is slightly less than the horn the cabinet originally used so it sits back a little. The width of the cabinet is such that the cross width corresponds to 1.5 wavelengths at about 3KHz. The ripples in response on the white graph look close to higher harmonics which would confirm my belief.
When I get some suitable weather I’ll pack the horn forward slightly so it is flush and also measure the horn without a baffle. I don’t remember the rising response above 6.5KHz on previous measurements with this drive unit so that is something else I need to recheck.
Ignoring the dip in response the coverage seems pretty consistent between 2 and 10KHz.
Posted By: ceharden
Date Posted: 05 February 2013 at 8:27pm
Plots look pretty good to me. The big question is how does it sound?
Posted By: Dref
Date Posted: 05 February 2013 at 9:04pm
Don't worry about the color code, it was mostly a joke. I wouldn't be able to tell a specific shade of yellow from a photography. I just like the color of your hornSmile
What were the distance from the shed? On the picture it looks quite close, but that might just be an illusion.
Posted By: Steve_B
Date Posted: 06 February 2013 at 1:34am
Quote Plots look pretty good to me. The big question is how does it sound?
A quick listen using just the left channel from an mp3 player wasn’t ideal, but it wasn’t bad.
The plots are important to me, because the fun part is understanding how these things work. A lot of this would go un-noticed by just listening.
Quote What were the distance from the shed? On the picture it looks quite close, but that might just be an illusion.
It is about 2m. I’ve got quite a big garden so there is nothing behind the microphone and I usually move further away from the shed especially when measuring lower frequencies. The weather wasn’t great today though.
Posted By: Steve_B
Date Posted: 17 February 2013 at 3:06pm
Just to update.
I've slightly reworked the throat and packed the horn forward so it is flush with the front edges of the cabinet.
Plots are at 10 degree increments off axis the yellow is the live plot so is the same as the green
