12" bass horn
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=7749
Printed Date: 26 March 2026 at 11:31pm
Topic: 12" bass horn
Posted By: login4
Subject: 12" bass horn
Date Posted: 13 December 2006 at 2:32pm
Here is something i came up with tonight, iv been thinking of trying to design something easy to make, here is a pic of a ruff scetch, i was also thinking of making it quite narrow:
What do you think?
CELTIC SUBSONIC SOUND SYSTEMS
Posted By: TDA-Audio
Date Posted: 13 December 2006 at 5:01pm
EM - quak
Posted By: Nigey-C
Date Posted: 13 December 2006 at 5:57pm
Punisher!
Posted By: djstefanos
Date Posted: 13 December 2006 at 11:02pm
add another piece and it will be a billfitzmaurice cabinet
Posted By: login4
Date Posted: 14 December 2006 at 8:34am
its based on a ciare design but with an extra fold at the begining, just a scribble at this point tho...
Posted By: odc04r
Date Posted: 14 December 2006 at 1:22pm
Fairly modellable design, access to the securing the driver might be a problem. Flip the piece of wood that the driver is mounted on and extend it and you pretty much have a punisher on your hands.
Posted By: login4
Date Posted: 14 December 2006 at 4:04pm
ye i see your point access will be a big problem
Posted By: jethrocker
Date Posted: 14 December 2006 at 5:22pm
Just change the dimensions a bit around the throat area and an access panel on the front flare section should be possible so you can drop the driver into its chamber from there.
Rear chamber looks huge on this sketch though?
Posted By: COWFOOT
Date Posted: 15 December 2006 at 8:11am
Couldn't the access panel/ panels be located like the ones for the Labsub or Punisher?
Posted By: login4
Date Posted: 17 December 2006 at 12:47pm
ye the plan was to have a side access pannel, but ye the rear chamber is way to big
Posted By: DJ Vencenzo
Date Posted: 07 June 2007 at 6:22am
What do you think?
that looks like u used Autodesk Inventor....nice.
Posted By: Disco Stu
Date Posted: 07 June 2007 at 12:36pm
Hi I designed something similar to this but it looked like this
The cab is 600mm high and 762mm deep
I experimented with different widths and it seems that about 500mm is OK but the wider you can go the better for extension to 40Hz being the goal - I tried the Ciare 12SW and Delta12LF drivers - it has a fair amount of wobble in the frequency response - and a high compression ratio 1:4 or thereabouts
If you use a 10" driver the horn actually works better - lower compression ratio - you could also give the horn extra length to try and get higher efficiency - like so
All you need to know is:
My acts:
Posted By: login4
Date Posted: 08 June 2007 at 3:15am
i like the first diagram it looks to solve a few problems like the huge rear chamber and the side access would be alot better now,
Posted By: Gledz
Date Posted: 15 February 2012 at 1:31pm
Posted By: Gledz
Date Posted: 15 February 2012 at 1:59pm
