TDA MT121 - HR Plots
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=77536
Printed Date: 26 March 2026 at 11:31pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: TDA MT121 - HR Plots
Posted By: levyte357-
Subject: TDA MT121 - HR Plots
Date Posted: 28 March 2013 at 11:40am
http://forum.speakerplans.com/simplified-mt121-plans_topic16270.html" rel="nofollow - http://forum.speakerplans.com/simplified-mt121-plans_topic16270.html
levyte357 wrote:
For those of us who weren't aware they were here.
Three-Bee wrote:
Attempted plot from TDA MT121 plan,
Comments?
------------- Global Depopulation - Alive and Killing.
Posted By: Dref
Date Posted: 28 March 2013 at 12:51pm
Hi Lev
There will be a front chamber (Vtc) because of the shape of the cone. Making the rear chamber smaller will improve the response. Try and play around with the directivity function. (Ctrl+R)
------------- A proper build subwoofer will be the only thing in a room that is not shaking.
Date Posted: 28 March 2013 at 3:16pm
Dref wrote:
Hi Lev
There will be a front chamber (Vtc) because of the shape of the cone. Making the rear chamber smaller will improve the response. Try and play around with the directivity function. (Ctrl+R) |
Cheers for that.
Really trying to sim TDA MT121 as is, to get realistic plot of how cab performs with various drivers.
So, what would suggested refinements to above input values be, for existing design?
Posted By: DiscernAudio
Date Posted: 28 March 2013 at 3:27pm
Is not hornresp only accurate up to a certain freq? If so what is that "cutoff"?
Posted By: boots-hifi
Date Posted: 28 March 2013 at 10:05pm
I've just loaded mine with BMS 12N610's and 4550's on RCF HF64 horns if you fancy toying with that combo. Gonna try and get some smaart plots over this weekend incase your interested.
Posted By: Dref
Date Posted: 29 March 2013 at 12:22pm
I think the rear chamber volume should be less than 20 L. As far as I can calculate from the dimensions, the rear chamber is 15.7 L in its empty state. So try with 8-10 L.
Also the constant directivity option is very unfair for such a narrow dispersion horn. Try to make an on-axis(0 degree) plot with an 8 L rear chamber and lets see how that looks.
Date Posted: 29 March 2013 at 12:45pm
Also the constant directivity option is very unfair for such a narrow dispersion horn. Try to make an on-axis(0 degree) plot with an 8 L rear chamber and lets see how that looks. |
Will be interesting to see real plot vs HR sim, to identify the inaccuracy.
Trying to identify best drivers for cab, then where eq will be needed to flatten response. Some of us need exceptionally flat 200-500hz response.
Date Posted: 03 April 2013 at 11:47am
Done
Does this seem a little too optimistic ?
Posted By: MarjanM
Date Posted: 03 April 2013 at 2:36pm
Yes it does.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Date Posted: 03 April 2013 at 2:40pm
MarjanM wrote:
Yes it does. |
Hmmm..
Trying to find well suited driver, simming with parameters first..
But if sims not accurate, what then..
Some of us can't afford testing with conveyor belt of driver purchases.
Date Posted: 03 April 2013 at 2:45pm
Possible to purchase test and return? I know Parts Express here lets us do that
Posted By: Dref
Date Posted: 03 April 2013 at 3:05pm
Something went wrong with your sim?
Here is my sim:
Try to find a driver with a lighter cone. If it has to be a Kappa then go for the non Pro version.
Date Posted: 03 April 2013 at 3:14pm
Dref wrote:
Something went wrong with your sim? |
Indeed.. Somehow I had "incorrect" Driver Sd in T/S parms...
Cheers Dref.
EDIT:But please explain Lrc value?
Posted By: MarjanM
Date Posted: 03 April 2013 at 3:34pm
Lev, the TDA version will not be much different then the original. Difference will be in order of 1 db here and there. So whatever suits the MT will also suit the TDA version. People have used lot of different 12 inches with various results but none was actually too bad. The main question is what will the HF driver be and how low it can go. Using a bit eq on the top part of the 12 inch response will not be too bad thing.
Date Posted: 03 April 2013 at 3:44pm
Have used quite a few drivers in TDA/Standard MT121, with good results.
Trying to identify drivers, with better low mid response.
Posted By: MarjanM
Date Posted: 03 April 2013 at 4:00pm
You can not go wrong with 4550 man.
Date Posted: 03 April 2013 at 4:13pm
MarjanM wrote:
You can not go wrong with 4550 man. |
HF already sorted mate.. I only use 2" in MT121s.
Need 12" driver that is flatter in response 200hz-400hz.
Posted By: MarjanM
Date Posted: 03 April 2013 at 4:16pm
There will be a peak at about 400Hz no mater which driver you use.
Date Posted: 03 April 2013 at 4:30pm
MarjanM wrote:
There will be a peak at about 400Hz no mater which driver you use. |
Assuming Dref plots are realistic, flattening peaks around 200/400 are not a problem.
Problem is hornloaded kicks are mostly no good for low mid, so it's either get low mid from MT, or reflex kick cab. (For use on Scoop systems).
Date Posted: 03 April 2013 at 4:37pm
BMS 4550 and BMS 610N are the best combo for an MT.
Thats what I loaded the MTs I bought from you with Lev and they play almost flat with no eq apart from that little dip at 500hz. Ill load up some plots from Smaart a bit later if you like?
Date Posted: 03 April 2013 at 4:45pm
Thats what I loaded the MTs I bought from you with Lev and they play almost flat with no eq apart from that little dip at 500hz. Ill load up some plots from Smaart a bit later if you like? |
Would be great... Cheers.
Date Posted: 03 April 2013 at 4:54pm
When in constant directivity mode, is hornresp aaveraging the response within the angle of the horn?
Date Posted: 03 April 2013 at 5:06pm
Or is it averaging from 0 - 90deg off axis?
Date Posted: 03 April 2013 at 5:10pm
Just modeled the B&C 12PE32, that many rage about, and it doesn't seem so hot 200-400hz.
Date Posted: 03 April 2013 at 10:21pm
Lev little test myself and Bee ran yesterday in the sun! TDA MT loaded with...
BMS 12N610 and BMS 4550.
HPF 150 - BW 24 LPF BW - 12 HPF - 1K BW 24
No eq, Pink noise simed. This may or may not be of any interest to you.
Posted By: bee
Date Posted: 03 April 2013 at 10:34pm
best sounding hf i have heard in an mt by a long way.... the 12 is on par with the b&c 12ndl76, which is my fav, Boot's combo defo sounds sweet....... on axis there is not alot of differance in the standard mt to the tda one, off axis the original is better..... The dip at 500hz is not the driver or cab but something in the way we set up the rta stuff..... very strange..... plotts where taken at 5m mic was leval with 12"..... pink noise was used..... a wall was within 2m of the right of the stack and my workshop was 15m infront of stack, so not ideal testing area, but good enougth for what we was doing..... next time we will do a full sweep signal of cab, and calibrate (spl) on mic..... there is a topic on hear where i posted up actual sweep test's on both mt121 and tda mt121, both loaded with same drivers.... ill see if i can find plotts, these where taken at 2m, sweep, calibrated mic, input 2,83v...... so the plotts are spot on......
------------- https://www.elements-audio.com
Posted By: MarjanM
Date Posted: 03 April 2013 at 10:54pm
Bee which horn is that?
Date Posted: 03 April 2013 at 11:15pm
This is actual Smaart plot with 12" run downto 150hz !? And BMS 4550 without Eq? With which 1" horn mate ?
Have you tried running MT with approx 400W power input down-to 150hz?
Cheers for info, Lev
Posted By: bee
Date Posted: 03 April 2013 at 11:47pm
this is the mt121 half of the roger mogule mt122 design Marjam, not sure on make of the hf horn not a plott Lev an rta reading of cab... i.e. played pink noise through cab and recorded info in to pc via a rta mircophone via smaart..... no eq just xover only...... blue is the 12" section red is the 1" on horn.... both 12" and 1" was tra'd on it own and combined.... the dip at 500hz is a cause of reflection from a wall less than 2m to the right of the cab ignor spl readings, these are not correct........ the reading with a 10 second average looks alot smoother..... the signal being picked up below 60hz was to do with the mixer output or sound card not sure, need to re check all settings and outboard gear 1 piece at a time..... to find where it was coming from.....
Posted By: MarjanM
Date Posted: 04 April 2013 at 12:42am
The HF shows a very strange graph for the 4550. So i guess the horn is quite small. It start going down at like 1.5Khz and it has too much of the very high frequencies. This later not bad at all actually.
Posted By: MarjanM
Any picture of the box?
Posted By: bee
Date Posted: 04 April 2013 at 12:44am
sure give us a sec and ill find one.....
Posted By: bee
Date Posted: 04 April 2013 at 12:47am
 top cab is the mt bottom left is a turbo sound bhp115 bottom right is my new prototype bhp115
Posted By: bee
Date Posted: 04 April 2013 at 12:52am
the plot may be due to xover position, the 12" was crossing out a bit above where the 1" was crossing in. this where it sounded best, not where the driver could be xover at....
Posted By: MarjanM
Date Posted: 04 April 2013 at 12:54am
That is fine, i am a bit puzzled by the response 6Khz and above. That is the RCF H64 horn and i have measured that one with 4550 and my results were not even close to what you have there. What kind of mic you are using? Is it calibrated?
Posted By: bee
ill ring boots in the morning and see if he had a combined reading, im sure i saved a snapshot....
Posted By: bee
Date Posted: 04 April 2013 at 12:59am
yes but, was not calibrated for spl.... soundcard and mic calibrated, but there was a small issue somewhere as it was picking up a signal below 60hz which was due to something in the signal chain post mic but this noise was not effecting the higher frequancys..... but in saying this there was alot of top end shine from this driver above 6k infact it is one of the best combo's ive heard yet in the mt... there may of been a bit of reflection going on, due to a wall 2m to the right of the cabs, but not that would aid the hf.... my ears say the plott is correct....
Posted By: bee
Date Posted: 04 April 2013 at 1:12am
this is another plott taken at the same time of a turbo bhp115 and my new prototype bhp 115, this shows no added noise in the hf region just a small amount of background noise..... hope this helps....
Posted By: MarjanM
Date Posted: 04 April 2013 at 1:35am
What i was asking is the mic calibrated? Calibrated as factory calibrated to be flat.
Date Posted: 04 April 2013 at 7:04am
MarjanM wrote:
What i was asking is the mic calibrated? Calibrated as factory calibrated to be flat. |
Berry ECM mic Marjan, RCF horn and no the mic hasnt been calibrated since it came out of the shop. These were just readings all done just out of intrest as Id just loaded the drivers into the cab. At the time we were A/B Bee's new kicks against my Turbo's and as I had the MTs in the van we thought why not have a play with them too. Lev all settings were just a rough guess, where would you cross the 12" at? Bearing in mind ill be running 2 a side from a PL 4.0 so there be getting more than 400w. I think the plots came out quite well, although there is an increase above 6k this sounded good and isnt a bad thing as Majan mentioned. Im quite happy to bring a loaded cab out for more testing if your imtrested lev?r
Date Posted: 04 April 2013 at 9:47am
boots-hifi wrote:
Lev all settings were just a rough guess, where would you cross the 12" at? Bearing in mind ill be running 2 a side from a PL 4.0 so there be getting more than 400w. I think the plots came out quite well, although there is an increase above 6k this sounded good and isnt a bad thing as Majan mentioned. Im quite happy to bring a loaded cab out for more testing if your imtrested lev?r |
If the 12" is happy playing down to 150hz at gig levels, will give vocals serious bit of warmth, not many 12s in MT121 would be happy doing that. Was told MT122 is good down to about 140hz. I Usually bring MT121 12" section in, about 180hz.
Also natural increase above 6K from Horn & comp, would also be a plus in my book.
Posted By: bee
Date Posted: 04 April 2013 at 10:52am
Lev ive allways run my mt's down to 150hz a gig volume, never been an issue, driver in my old mt's was the 12ndl76, i cant say other drivers sound good down at 150hz but boots's combo sounds sweet. The sound card was calibrated via smaart, the ecm mic is not the best but is not that far out to the £300 pluss mics, there may of been somthing going on to get it that good above 6k, but it was not eq... im sure boots would be happy to re run test when we get a good weather day again, ill bring my laptop next time and do measurments using both laptops, to see what variance there is from both measurment setups...... ill try and do the tests in a more open area too.....
Posted By: Dref
Date Posted: 04 April 2013 at 11:57am
This is what I found in the help file: Also, horn flare directional characteristics are not taken into account when calculating the constant directivity SPL response. This means that the actual upper frequency rolloff for a cone type drive unit coupled to a straight-axis horn can in some cases be more than one octave higher than the predicted value.
Lev: Lrc = Rear chamber average length (cm). Don't worry to much about it here.
Date Posted: 04 April 2013 at 2:39pm
Lev: Lrc = Rear chamber average length (cm). Don't worry to much about it here. |
That would lead me to believe that it averages the SPL response from 0 deg to 90 deg (the max deg off axis horn resp will calculate) since the horn angle is not taken into consideration
Posted By: Dref
Date Posted: 05 April 2013 at 11:00am
To be honest I am not sure. Best to ask David I would say.But still there is no point in including angles outside the dispersion angle of the horn.
Date Posted: 11 July 2013 at 12:13am
bee wrote:
Lev ive allways run my mt's down to 150hz a gig volume, never been an issue, driver in my old mt's was the 12ndl76, i cant say other drivers sound good down at 150hz |
Recently tried Paudio SN12Bs, and they started chuffing at 180hz.
Strange as they used to be recommended drivers for the cab.
Posted By: RealitySound
Date Posted: 21 August 2013 at 11:21pm
Comments?
I am trying to teach myself hornresponse............can you please tell me how you got Lrc- 17.00 and Atc- 519.00?
------------- When you gonna send me some $$ mate ?
Posted By: bee
Date Posted: 21 August 2013 at 11:26pm
vrc is 17.60 lrc is 14.80 vtc is 1108.00 atc is 615.75 lrc is the length of the rear chamber....
Date Posted: 21 August 2013 at 11:41pm
Thanks Bee. I have been using this as a guide- (http://www.freespeakerplans.com/forum/7-general-forum/13045-hornresp-newbie?start=10)
Assuming the piece of ply being used behind the driver is 18mm thick, wouldn't lrc be 13.0? (148-18?) http://s150.photobucket.com/user/ob1bda/media/1d6af7a0-abfb-4435-b9fb-a7fa5337cd75_zps2646ae89.jpg.html" rel="nofollow">
Posted By: bee
Date Posted: 21 August 2013 at 11:45pm
no 14.8 baffle to rear of cab, the plan is miss leading as it shows rear hatch batton... rear baffle to external rear of cab is 16.6 minus of 18 = 14.8
Date Posted: 21 August 2013 at 11:48pm
Ahhh, Ok. So it should look like this instead- http://s150.photobucket.com/user/ob1bda/media/0358916c-6d5c-45fc-aea8-6f9ed18c5413_zpse4b8e39b.jpg.html" rel="nofollow">
Date Posted: 22 August 2013 at 12:11am
Now I am trying to figure out how you got vtc - 1108.00..............?
Date Posted: 22 August 2013 at 4:21am
Vtc=Atc*1.8 (for 18mm spacing)
Posted By: Dref
Date Posted: 22 August 2013 at 12:23pm
But for a more realistic simulation you should find out the volume of the void arising from the speaker cone as it will be more than the 18 mm transition piece.
Nice that you have started learning Hornresp by the way. I am sure you are gonna love it when you get the hang of it.  And remember the build in help file  .
Date Posted: 22 August 2013 at 3:03pm
Dref wrote:
Hi Lev
There will be a front chamber (Vtc) because of the shape of the cone. |
you mean this Dref?
http://s150.photobucket.com/user/ob1bda/media/5af43d30-b299-490b-8f04-5bef073fccff_zps572f54e7.jpg.html" rel="nofollow">
Date Posted: 22 August 2013 at 7:49pm
RealitySound wrote:
Dref wrote:
Hi Lev
you mean this Dref?
The easiest way to calculate that volume is to measure the conical section and calculate its respective Volume, then subtract the (roughly) half sphere volume for the dust cover
Yes, and add that to the 1108 (for 18mm tranny)
Posted By: Teunos
Date Posted: 22 August 2013 at 8:05pm
Hornresp now has a front chamber volume estimation tool, works perfectly.
------------- Best regards, Teun.
Date Posted: 22 August 2013 at 8:34pm
Ahh yes! forgot about that
Date Posted: 23 August 2013 at 2:00am
18mm Tranny? Orange bit?
http://s150.photobucket.com/user/ob1bda/media/f314badd-3d6e-40c5-a283-48cdb590fcfb_zpsf63161f9.jpg.html" rel="nofollow">
http://s150.photobucket.com/user/ob1bda/media/854e98d8-7101-4d63-84bc-feabce72e3b7_zpsc46b2676.jpg.html" rel="nofollow">
Date Posted: 23 August 2013 at 2:21am
Except the orange extends the full 280mm
Date Posted: 23 August 2013 at 2:24am
Right.......of course. http://s150.photobucket.com/user/ob1bda/media/24334cb9-ce72-43ea-8d2a-a7b34ab5f663_zps2e53455e.jpg.html" rel="nofollow">
Posted By: Dref
Date Posted: 23 August 2013 at 3:00pm
Yep, except the red part is a bit misleading because it doesn't look that conical ;)
It sound like there has be quite a few updates since my current version of hornresp. I think its time that I update
Date Posted: 23 August 2013 at 3:05pm
It sound like there has be quite a few updates since my current version of hornresp. I think its time that I update  |
Well, its difficult drawing with a mouse LOL The red bit I was drawing is the area above the cone. That correct?
http://s150.photobucket.com/user/ob1bda/media/2c49473a-2324-442b-814f-fae09ba9f83d_zps752753ea.jpg.html" rel="nofollow">
Posted By: Dref
Date Posted: 26 August 2013 at 1:59pm
Much better. It was just to be sure no one misunderstood.
Date Posted: 26 August 2013 at 2:08pm
So Vtc would be the orange bit plus the red bit?
Date Posted: 26 August 2013 at 2:21pm
Plus the black bit between the red and the orange pits in that last pic
Date Posted: 26 August 2013 at 2:24pm
Of course. The black bit just being the 'basket' outline. What do you guys calculate it to be? You just ball parking the area above the cone?
Date Posted: 26 August 2013 at 4:02pm
get some measurements and Use hornresp cone volume calculator tool
add it to 1108 + plus the volume of the space added due to the thickness of the gasket (after compressed)
Date Posted: 16 September 2013 at 1:35am
anybody mind simming this driver for me?
- Impedance: 8 Ohms
- Power capacity: 1400 W Peak 700 W Program 350 W Continuous
- Sensitivity: 98.5 dB / 1 W 1 m
- Usable freq. range: 60 Hz ~ 3.5 kHz
- Cone: Kevlar® impregnated cellulose
- Voice coil diameter: 4.0" / 100 mm
- Voice coil material: Aluminum ribbon wire
Polyimide-impregnated fiberglass former Nomex® stiffener Solderless
diffusion welded OFHC copper leads
- Net weight lb. / kg: 16 lbs. / 7.3 kg
- Znom (ohms) 8
- Revc (ohms) 6.52
- Sd (Square Meters) 0.052
- BL (T/M) 19.60
- Fo (Hz) 57.4
- Vas (liters) 66.3
- Cms (uM/N) 172.8
- Mms (gm) 44.40
- Qms 4.84
- Qes 0.270
- Qts 0.257
- Xmax (mm) 2.60
- Le (mH) 0.37
- SPL (1W 1m) 98.5
- No (%) 4.49%
- Vd (cu. in. / ml) 16.5 / 270
- Pmax (Watts pgm.) 700
- Disp (cu. in. / ml) 109 / 1797
- 12"
Posted By: bee
Date Posted: 16 September 2013 at 7:29pm
  didn't sim too well.....
Date Posted: 16 September 2013 at 9:47pm
Posted By: hmaudio
Date Posted: 30 December 2013 at 10:06pm
could eny one sim this driver in a mt121?
see if it would work well or not.
Resonance frequency:
62 Hz
DC resistance:
5.2Ω
Mechanical factor:
4.1
Electrical factor:
0.29
Total factor:
0.27
BL Factor:
18.8 T · m
Effective Moving Mass:
50 g
Equivalent Cas air load:
52 liters
Effettive piston area:
0.053 m²
Max. linear excursion (mathematical):
3.5 mm
Voice - coil inductance @ 1kHz:
1.25 mH
Half-space efficiency:
4.12%
------------- Nottingham based cab builder. https://www.facebook.com/HMAudio-154352667920145/?ref=bookmarks This account is used by 2 people.
Date Posted: 02 January 2014 at 8:33pm
Date Posted: 02 January 2014 at 9:53pm
Would be interesting comparing actual measured plots, against HR sims.
But then, 'lil eq, will make many compatible drivers, sound decent in MT.
Date Posted: 03 January 2014 at 5:41am
Sorry my plot was for orig MT not TDA vers
Posted By: Avatron
Date Posted: 12 February 2014 at 11:57pm
On the previous pages, VTC was 1108 for the MT 121.
615,75 (ATC) x 1,8 = 1108
But in the plan the baffle is 12mm, from where do come the 1,8?
