X12 or??
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=77701
Printed Date: 27 March 2026 at 4:54am
Topic: X12 or??
Posted By: crystal.a
Subject: X12 or??
Date Posted: 03 April 2013 at 5:42pm
need some advice looking for a budget reflex loaded mid tops was thinking about X12 style loaded with
eminence delta 12 16 ohm
eminence H2 EA 2" horn
P.audio SD63BF-2 2" C.D
or possibly going with a pair of JBL JRX 125 or similar it is to be used over 4-6 reflex loaded 15" subs and possibly 2 15" and 2 half G subs want to build up 1 stack then another to match over time all cabs must be singles except the tops as i'll mostly be moving it around on my own.
hell is just a word, the reality is much much worse!
Date Posted: 03 April 2013 at 6:16pm
the eminence delta 12's will do you fine, quite loud and don't sound that bad considering the pricetag - will outperform the JBL thats for sure... for compression driver however i would look for something higher quality and possibly used to bring the price tag down... something 1.4" will do you, 2" is a bit harsh and not necessary when crossing to a 12" mid section [old fashioned by all accounts nowadays].
i like the RCF N850, often selling on the cheap on ebay!
Date Posted: 04 April 2013 at 1:17pm
thanks mate that exactly what i wanted to hear just had a look for the RCF you mentioned can only seem to find it in 2"?
Posted By: CritikalMass
Date Posted: 30 August 2013 at 2:03pm
Same here
Posted By: Tony Wilkes
Date Posted: 30 August 2013 at 2:17pm
BMS 4550 on Faital LTH102 horn, no problem keeping up with any double 12 crossing around 1K
Tony
