Comp driver strain on waveguide/horn
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=78701
Printed Date: 26 March 2026 at 11:31pm
Topic: Comp driver strain on waveguide/horn
Posted By: macca
Subject: Comp driver strain on waveguide/horn
Date Posted: 10 May 2013 at 8:59am
Hi, i'm half way through my 1st mt121 build (pics soon), and i have just received my p-audio 2723 horns and bmd750 mk2 comp drivers in the mail, and have just realised how damn heavy these 2" drivers are.
My question is: do i need to make a bracket to hold the comp driver in, or will the horn be strong enough to hold it, and not break when the speakers are moved around to parties/gigs?
I've been scouring the forums for build pics that show something of the sort, but with no luck.
If i do need to make a bracket of some sort, could someone please suggest a design, or show some pictures of what they have rigged up?
Thanks.
Posted By: Adam_Iron_Horse
Date Posted: 10 May 2013 at 9:09am
We have a brace across the tops that also supports the horn.
The horn may support the driver but I would be inclined to shove a support in anyway just so if it gets knocked or a harder hit its not likely to break.
I would get a bit of wood as wide as the box and wider than the driver then cut a circular hole the size of the driver in it and put that in the box around the driver :)
Posted By: macca
Date Posted: 10 May 2013 at 9:14am
I might do that, i'm using 21mm birch for the outside box, so 1 piece should get a nice surface area.
Thanks.
Posted By: njw
Date Posted: 10 May 2013 at 11:36pm
  Here's one of my top boxes, 2" Cerwin Vega and Fane 1", all you need is a bit of material around the driver to stop it going anywhere, simples!;
  http://s1095.photobucket.com/user/njw1/media/005.jpg.html" rel="nofollow">
  Heres a pic from the front;
http://s1095.photobucket.com/user/njw1/media/006.jpg.html" rel="nofollow">
