scoops with amps modules?
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=79020
Printed Date: 26 March 2026 at 11:31pm
Topic: scoops with amps modules?
Posted By: UpComingSound
Subject: scoops with amps modules?
Date Posted: 21 May 2013 at 3:41pm
powersoft is now selling amp modules for stand alone speakers, do u think scoops will be speakers to turn active ?   http://www.powersoft-audio.com/en/products/amp-modules.html" rel="nofollow - http://www.powersoft-audio.com/en/products/amp-modules.html
Date Posted: 21 May 2013 at 3:43pm
for 12 15 18 and 21 inch woofers
Posted By: mini-mad
Date Posted: 21 May 2013 at 4:34pm
...active scoop/hog with built in DSP?..... mmmmmmm.....
Posted By: mini-mad
Date Posted: 21 May 2013 at 4:35pm
...daisy chaining just got a whole lot easier....
Posted By: studio45
Date Posted: 21 May 2013 at 5:27pm
where would you put it? all the air space inside a scoop is active, you can't stick an amp module in the horn path without messing up the expansion, or in the rear chamber without reducing its volume. You'd need a lump sticking out the back of the box and that's not going to look good, or be practical for truck packing.
Posted By: shagnasty
Date Posted: 21 May 2013 at 5:38pm
most scoop designs have quite an ideal dead space for the module, behind the scooped bit near the bottom...
Posted By: TONY.A.S.S.
Date Posted: 21 May 2013 at 5:41pm
All the Amp Modules I've seen so far haven't been very big, so providing the power needed is achievable, it could go behind the scoop section whether it be round or staggered straight pieces. It could be mounted within the framework that perhaps supports the curve and an access panel could be made.
Posted By: Sypa
Date Posted: 21 May 2013 at 6:30pm
http://www.highlite.nl/silver.econtent/catalog/highlite/entertainment_products/dap_audio/speakers/touring_series/lt_18hl
Dont know if its relevant but il leave this here.
edit:Fail that is a passive one,http://www.finesound.nl/verkoop/product_info.php?products_id=477
Posted By: darrell
Date Posted: 27 May 2024 at 11:26am
Very late to this but check out Stakx Solutions.
