MT 122 BACK PANEL
Forum Name: Feedback Forum
Forum Description: How Your Projects Perform
URL: https://forum.speakerplans.com/forum_posts.asp?TID=801
Printed Date: 26 March 2026 at 6:55pm
Topic: MT 122 BACK PANEL
Posted By: MIKEY SOUL
Subject: MT 122 BACK PANEL
Date Posted: 27 October 2004 at 12:29am
I looked at the top view of the removable back panel and noticed that the widest dimension is on the side that is facing the inside of the MT 122.  As the exterior sides of the box is tapered how can one assemble the back panel as per drawing?
I also note no cleats (battens) adjacent to the back panel.
Posted By: Fushion Julz
Date Posted: 27 October 2004 at 10:11am
My Mt 122s have a back panel that is full length and fit the outside dimension...otherwise you couldn't get them in!
I used battens around the top, bottom and sides of each rear chamber and the dividing shelf is also a "batten" to which the back panel is screwed. To ensure a good air-tight fit I use a silicon sealer (bath seal) around all the joints.
FUSHION SOUNDSYSTEM
http://www.fushion.org.uk - www.fushion.org.uk
Date Posted: 27 October 2004 at 12:14pm
Hey Julz: Much thanks.  The drawings need to be amended.
