Hi every body. I woundered if anybody would be kind enough to do a driver frequency simulation for me for a mt121. This would be a massive help and i would be very grateful!! I already own 2x fane sovreign pro 12-500's and i am planning on building a pair of mt121's. I currently have no comp drivers in mind. I just want to know if these drivers are suitable for said cab? I know its a bit cheeky but it would be very helpfull if some one helped out. Thanks, Tony Driver specs Mounting / Shipping Information: Overall Diameter 12.36' / 314 mm Baffle Hole (Front Mount) 11.3' / 287 mm Flange Height 0.393' / 10 mm Mounting Hole Diameter and Quantity 8 x 7mm dia /8 x 0.275" dia Mounting Hole P.C.D. 294 mm PCD / 11.5" PCD Overall Height 5.7' / 145 mm Nett Weight 7.5 kg Shipping Weight 8kg Packing Carton Dimensions 165 x 330 x 330 mm
Electro Acoustic Specifications:
Nominal Chassis Diameter 12' Impedance 8 O Impedance 8 O EIA 426 Power 500 w Program Power 1000 Peak Power 6dB Crest Factor 2000 Frequency Range -3dB 40 Hz - 3.5 KHz Sensitivity 1w - 1m 97.5 dB Magnetic Gap Depth 0.39' / 10 mm Coil Diameter 3.0' / 76.2 mm Flux Density (Tesla) 1.1 Coil Winding Length 0.78' / 20 mm
Thiele Small Parameters:
FS Hz 46 Hz RE Ohms 5.4 O Qms 6.19 Qes 0.42 Qts 0.39 Vas Ltr 107 Vd Litres 0.237 CMS (mm/N) 0.233 BL T/m 13.81 Mms (grms) 50.98 Xmax mm 4.8 Sd cm2 569.8 Efficiency % 2.4
