RCF L18P300 in scoops?
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=8183
Printed Date: 26 March 2026 at 9:25pm
Topic: RCF L18P300 in scoops?
Posted By: Static Age
Subject: RCF L18P300 in scoops?
Date Posted: 13 January 2007 at 8:42am
would it work well or not? i have used them in T18's and the sound very good.
spec here http://www.usspeaker.com/rcf%20-%20L18P300-1.htm - http://www.usspeaker.com/rcf%20-%20L18P300-1.htm
Posted By: levyte357
Date Posted: 13 January 2007 at 9:48am
Have heard lots of good things about this driver in the past, in different types of boxes.
But the stated Xmax is only 7.8 , the voice coil is < 4in,  fs/qes is <100, and Vas is only 226.
Personally, I guess it would be very efficient in carefully sized reflex, not overdriven, but only ok in a scoop. I place it in my group 3 driver list.
Group1:PD1850, V18-1000
Group2:PD186, Top Level B&C's, Volt, B-line
Group3:FANE XB, L18P300, Top Level Eminence, Decent JBL 18,Beyma
I have seen it for a little less than a PD186, but the Fane XB is much cheaper, is proven in scoops, just cant handle  high power levels in big cabs like PD186, V18 or 1850.
Date Posted: 13 January 2007 at 2:42pm
i use fane 18xb's in my scoops at the moment & have a pair of RCF L18P300 lying around spare so i might drop one into a scoop and give it a test. though i think the difference beween the Rcf & fane will only be very small.
