Sound Project
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=82312
Printed Date: 27 March 2026 at 5:15am
Topic: Sound Project
Posted By: Sloth69
Subject: Sound Project
Date Posted: 27 September 2013 at 12:55pm
Hello to all!
I would like some advice on the right choices ...
I currently have 2x 1850 folded hord
2x hd15 horn
I took the plans and built these speakers a tight squeeze ..
For hd I'm going to put the pd 154 ...
For 1850 I would opt for the P.Audio 18w2000
http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=306
Among my amps I also 2x peavey CS4000 ...
I thought maybe I could use their 4kw @ 4ohm to greatly increase the W cones ...
I thought then to build 2x es18bph with P.Audio SD18 1700n ...
My concern is to build a balanced sound ..
How could I combine these speakers?
Should I build two more in 1850?
I should make two 186 horn?
Build 15 other hd??
Or build these es18bph with cones 1700w?
Looking at the list of compatible cones I saw that there are also
18NLW9600 who 1800w!
Although in reality as frequencies are not particularly suited as the P.Audio
http://forum.speakerplans.com/drivers-for-1850-186_topic68912.html
So ... how should I proceed with the construction of my sound?
Thank you all!
Posted By: AM55
Date Posted: 27 September 2013 at 2:23pm
If you already have 1805s then build two more. Don't get bogged down with all the choice out there, just stick with what you have.
https://diy-disco.co" rel="nofollow - Audio Visual Equipment Hire Service
Posted By: b grade
Date Posted: 27 September 2013 at 3:48pm
+1. Stick with the 1850s. Don't mismatch several different types of bass bins.
Posted By: ape3435
Date Posted: 27 September 2013 at 3:59pm
+1..and also keep either HDs or ES18, preferably HDs as more punchy in my opinion
Posted By: Sloth69
Date Posted: 29 September 2013 at 6:00pm
thanks to everyone for the feedback!
For 1850 so I should put P.Audio 18w2000 or 18NLW9600?
How can I make the most of peavey CS4000?
