15" DOUBLE SCOOPS
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=8239
Printed Date: 27 March 2026 at 11:04am
Topic: 15" DOUBLE SCOOPS
Posted By: craig34
Subject: 15" DOUBLE SCOOPS
Date Posted: 16 January 2007 at 11:13pm
just want to know if eminence kappa pro 15a will work in these cabinets.thanks
Posted By: Tom Umney
Date Posted: 17 January 2007 at 1:18am
It will work, but won't last long as Kappa Pro 15 xmax is only 3.2mm, and the xmech only 13.2mm.
Better to choose a different driver.
Posted By: craig34
Date Posted: 17 January 2007 at 12:40pm
what about using eminence omega pro 15a. or what would be the best eminence to put in the  15" double scoops tanks
Date Posted: 17 January 2007 at 3:16pm
Eminence Kappa Pro 15 LF as it has the biggest xmax and xmech out of all the Eminence drivers.
Posted By: Tekasis
Date Posted: 17 January 2007 at 4:26pm
I didn't know that Toxic, is that only in the 15'' range or also for the Kappas in the 18'' range ?
What is the xmax and xmech for the Eminence Kappa Pro 15 LF driver ?
Cheers
Date Posted: 17 January 2007 at 5:08pm
Kappa 18 ain't made anymore[discontinued]. Eminence Magnum series is also not made anymore[ discontinued].
Eminence Kappa Pro 15 LF  xmax is: 6.7mm, xmech is 18.0mm.
Posted By: Tekasis
Date Posted: 17 January 2007 at 7:05pm
Cheers Toxic. I knew about the Eminence Magnum but not about the Kappa 18's.
Hope they've got replacements coming out.
Date Posted: 18 January 2007 at 5:33am
Yeah theres the Eminence Definimax which is out now.
Eminence Definimax 4018LF, Definimax 4015LF,Definimax 4012HO.
Posted By: Static Age
Date Posted: 18 January 2007 at 6:20am
i presume you are looking at eminence as you are on a restricted budget? if thats the case have a look at P Audio http://www.proaudioparts.co.uk/paudio.asp - http://www.proaudioparts.co.uk/paudio.asp  i would chose P Audio over eminence for bass drivers.
Posted By: craig34
Date Posted: 18 January 2007 at 9:25pm
WHICH P-AUDIO 15 " WOOFER  SHOULD I USE IN THE 15" DOUBLE SCOOPS
Posted By: login4
Date Posted: 18 January 2007 at 10:23pm
mybee p.audio's jbl 2226 looking jobies
CELTIC SUBSONIC SOUND SYSTEMS
Posted By: craig34
Date Posted: 19 January 2007 at 9:01pm
can u give me the model number of the p-audio that i need for the double 15" scoops
Posted By: login4
Date Posted: 22 January 2007 at 1:17pm
p.audio p150
http://www.p-audio.co.uk/products/foto/fotobig_p150_2226.jpg - http://www.p-audio.co.uk/products/foto/fotobig_p150_2226.jpg
the jbl that this is a copy of sounds nice in scoops
Posted By: twinpaul
Date Posted: 22 January 2007 at 2:12pm
kappa 15lfs great drivers got 16 of them no probs
i told you
