New Leco Amp modules 650W/8R-1200W/4R
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=84281
Printed Date: 27 March 2026 at 8:25am
Topic: New Leco Amp modules 650W/8R-1200W/4R
Posted By: DjLeco
Subject: New Leco Amp modules 650W/8R-1200W/4R
Date Posted: 01 January 2014 at 2:28am
Some improvements compared to the previous version:
6 output devices per rail.
Triple deep darlington configuration, full simmetrical from in to out.
Offset adjustment.
Faster transistors on differential and VAS stages, with lower Cob capacitance.
Double feedback pre-post L-R out filter.
Improved output shortcircuit protection with faster transistors and lower Vce saturation.
Improved randament regarding passing from AB class to B class above 60 celsius degrees, with dinamic bias.
Some specifications:
Supply from +/- 70 to +/- 115Vdc,  output power 650 watts 8 ohms and 1200 watts 4 ohm at +/- 115Vdc.
Damping factor >1000/8ohms/100Hz.
Rise rime/fall time 2,5uSec, tipically 2,18uSec measured at 10Khz/8 ohms.
Freq response 15Hz-20Khz -1db at extremes, 5Hz-30Khz -3 db at extremes internally limited.
Some pictures:
http://postimg.org/image/9rpevluof/" rel="nofollow">
http://postimg.org/image/p1pa2sq6n/" rel="nofollow">
Some movies and tests:
Presentation:
https://www.youtube.com/watch?v=STP1g9luils" rel="nofollow - https://www.youtube.com/watch?v=STP1g9luils
Classical bias class AB:
https://www.youtube.com/watch?v=eyx1gNlNC0Y" rel="nofollow - https://www.youtube.com/watch?v=eyx1gNlNC0Y
dinamyc bias passing from AB class to B class when temperature rises:
https://www.youtube.com/watch?v=CysVsbNnvGM" rel="nofollow - https://www.youtube.com/watch?v=CysVsbNnvGM
Rise and fall times:
https://www.youtube.com/watch?v=40tmueYkMqo" rel="nofollow - https://www.youtube.com/watch?v=40tmueYkMqo
Max out 8 ohm:
https://www.youtube.com/watch?v=tJkwmLvt5UI" rel="nofollow - https://www.youtube.com/watch?v=tJkwmLvt5UI
Max out 4 ohm:
https://www.youtube.com/watch?v=Lcl-gFMOFkw" rel="nofollow - https://www.youtube.com/watch?v=Lcl-gFMOFkw
Maximum RMS current preset for 4 ohms during 2 ohms load:
https://www.youtube.com/watch?v=KfW4R9Pr5v0" rel="nofollow - https://www.youtube.com/watch?v=KfW4R9Pr5v0
Happy new year!
Posted By: TRE4U2NV
Date Posted: 01 January 2014 at 2:42am
Clap as usual well done sir
Posted By: all bass
Date Posted: 01 January 2014 at 9:16am
My hat's off to you sir!
Posted By: Nitz V1505
Date Posted: 01 January 2014 at 10:13am
Truely inspirational!!!! Hats off Sir. Id love me a few of those.
Posted By: DjLeco
Date Posted: 01 January 2014 at 11:30am
Thank you all for nice words, I want to wish you all, HAPPY NEW YEAR!
Me too, I like the results of new version, especially how protection WORKS.
I have 10 pieces (without heatsink) for sale, but I don't know how to proceed with transport from Romania, to you...
Maybe someone can help for that, with some opinions.
Posted By: Tan-2
Date Posted: 01 January 2014 at 8:08pm
impressive....Clap
Logic will get you from A to B. Imagination will take you everywhere.
Posted By: Earplug
Date Posted: 02 January 2014 at 9:05am
Nice. What sort of price range are we talking (trade, of course)?  Smile
Posted By: ArthurG
Date Posted: 02 January 2014 at 9:13am
Leco,
Seems a nice design. congrats mate Clap
What are the output transistors ?
Posted By: TONY.A.S.S.
Careful, don't get the man thrown out for selling.
Posted By: Earplug
Date Posted: 02 January 2014 at 1:46pm
Just a friendly question! And a PM would avoid any misunderstanding!  Smile
Posted By: DjLeco
Date Posted: 02 January 2014 at 4:55pm
All discussions are friendly, no problem gentlemans!
In the new year we must be more good, more understanding, more maleable.
Output devices are MJW21195+MJW21196, very robust if not exceeding SOA curve.
Modules are just for selling, not exchanges. Smile
Someone on other forum tryed to throw dirty on my work, saying the amp will not survive playing sinewave in shorted output, at variable signal level, because sensing transistors of protection, cannot act so fast...
I laught and I offered him his video, to chill itself...
Also shared to all of you:
https://www.youtube.com/watch?v=9m1sVXeFgck" rel="nofollow - https://www.youtube.com/watch?v=9m1sVXeFgck
Comments are welcomed!
Posted By: ArthurG
Date Posted: 02 January 2014 at 5:33pm
Those are very good transistors ! But why did you choose 21195+21196 over let's say 21193+21194 that have even higher SOA in a smaller package ?
Posted By: Marko
Date Posted: 02 January 2014 at 6:17pm
Great video, especially the crazy part at 05:00 min...
I would also like to know the price, please PM
Posted By: DjLeco
Date Posted: 02 January 2014 at 6:57pm
Price will ve 150 euros without heatsink, just 4 pieces are with heatsink, wich are reserved deja by one customer.
MJW21195,MJW21196, have same SOA as MJL21193,MJL211194 just package is a little smaller for MJW (TO247 vs TO264), that's why I have used MJW, because smaller package same SOA, also I cannot fit 12xTO264 on that heatsink+2x TO3P prefinals, not enough space to fit'em..
Posted By: ArthurG
Date Posted: 03 January 2014 at 4:11am
oh misunderstanding, I was talking about NJW21193G + NJW21194G, which are TO-3P, slightly smaller than MJL TO-247 (by a very small margin, in real life it doesn't make any difference on pcb/heatsink size). But SOA on NJW21193G is a bit better than the MJL you use. At 100V it takes 4A for 100msec vs 3.5A on MJL.
In fact, NJW21193+21994 has the highest SOA of ON Semi bipolar range and it's the pair of choice of Lab.Gruppen class TD amps Thumbs Up
Posted By: SMP
Date Posted: 03 January 2014 at 7:13am
please explain why you wish to change class with temp? surely class AB is fine and no real need to change bias coz of heat? I have never found any need to change biasing due to a temp change. incidentally I use 4281/4302 for a class AB I develop here
Posted By: DjLeco
Date Posted: 03 January 2014 at 9:17am
I bought some time ago 125 pairs of MJW21195+21196, and I must to use it.
Also I have couple tens of pairs of NJW21193-21194, as I will use it.
When heatsink is cold, on AB class will pass just bias curent in idle mode, with classical superdiode.
During high curent passing on output devices the heatsing temperature will grow, superdiode trying to compensate (decrease bias) until official value, but the bipolar transistor have negative coeficient temperature, and will have tendancy to increase current colector same time with temperature, because slow compensation of superdiode circuit, when teatsink is hot (70 degrees above), the bias will be higher in idle mode, and dissipate more heat, existing risk to thermal avalanche, if bias are a little higher than one predefined value.
Thats's why , On Semi, developed THERMAL TRACK trannies, with indide bias diode (5 pins).
Also, I used smaller heatsink for mine application, and B class amplifiers have bigger randament than AB class amplifiers.
So why is that I prefear to slow bias untill B class, when heatsink temperature increases, I raise up a litlle randament, also higher compensation of negative coeficient temperature of bipolar transistors.
Also, LabGruppen, uses B class amplifiers on their design, eben in TD class amplifiers, bipolar part of it is B class, that's why also they uses small heatsinks
Posted By: SMP
Date Posted: 03 January 2014 at 10:34am
I see you are using "Amplified Diode" to generate bias..I do not use such an arrangement as temperature co-efficiency is an issue. "differential PD" does not give such issues slightly less stable but is only small not so significant and bias can remain class AB always.
Yes TD is a class B Topology aids in efficiency but does little to sonic ability always an issue were differential driver circuits are used also in class B. I use pure class A drive run hot but sonics much better than Cascoded drive which require higher component count as they need more CCS's to operate effectively and have too many PN Junctions in  signal path which can cause non-linearity at high signal swings and inferior transfer function.
But each to their own I guess and we each do our own thing
Posted By: Tan-2
Date Posted: 03 January 2014 at 6:37pm
We sure do... But it's also interesting to see different designs..
Posted By: M4trix
Date Posted: 03 January 2014 at 11:37pm
Leco,
your dummy load is dying! If the dummy load had ability to speak it would say... please, hook me off cuz I can't stand this torture anymore! LOL
Posted By: DjLeco
Date Posted: 04 January 2014 at 12:36am
Originally posted by M4trix M4trix wrote:
Leco,
Yes I know that.
I will use it until it will be "open circuit".
I don't have place to put mine 1 ohm/1000Watts resistors(4 pieces/channel)...
http://www.digikey.com/product-detail/en/FSE100022E1R00KE/FSE1000-1.0-ND/270007" rel="nofollow - http://www.digikey.com/product-detail/en/FSE100022E1R00KE/FSE1000-1.0-ND/270007
http://www.vishay.com/docs/31849/fse.pdf" rel="nofollow - http://www.vishay.com/docs/31849/fse.pdf
Posted By: DjLeco
Date Posted: 04 January 2014 at 9:06am
SMP, no more technical discussion.
I said what I have to say, I showed what I have to show.
I don't want to be like other project(first one), where one "colleague" of mine, buyed prototype on test PCB, watched all discussion, tryed then to clone it, and het his self BIG, look mates, there's mine amplifier , and so on...
That colleague nickname is "Black", and he officially STOLE mine schematic and make another type of PCB, saying is HIS project...
http://www.diyaudio.com/forums/solid-state/185594-final-test-module-leco-vs-crown-powertech-series-amplifier.html" rel="nofollow - http://www.diyaudio.com/forums/solid-state/185594-final-test-module-leco-vs-crown-powertech-series-amplifier.html
Post 44 above
http://www.diyaudio.com/forums/solid-state/172617-class-ab-amp-made-me-5.html" rel="nofollow - http://www.diyaudio.com/forums/solid-state/172617-class-ab-amp-made-me-5.html
Here's that PCB that he buyed, stole the schematic and so on:
http://www.diyaudio.com/forums/solid-state/172617-class-ab-amp-made-me.html" rel="nofollow - http://www.diyaudio.com/forums/solid-state/172617-class-ab-amp-made-me.html
Sorry for puttin' links to other forum, but there was that discussion.
Posted By: SMP
Date Posted: 04 January 2014 at 9:15am
no offence intended I merely ask out of interest. I have no wish or need to "clone" or copy your design I have one or two of my own Class AB both BJT & MOSFET. you clearly believe your design is of commercial value. at present I have no desire to manufacture amplifiers. but when I do I will use my own designs. i merely wondered why there was a need to alter so drastically. as in normal use a class AB will migrate to single phasic conduction as the output voltage swings high. so I could not see any benefit to it. forgive me but I thought this is a forum where ideas and knowledge are freely exchanged guess it is not a forum at all. I could not understand your commentary as not English so I gained no useful exchange from it
Posted By: SMP
Date Posted: 04 January 2014 at 9:24am
I am also a DIY member as well "blueroom"
as the guy said without any topology your test video or results do not mean a great deal it is as you know customary on both DIy & Blueroom to show topology or it becomes pointless a little like showing photos of speakers or the items in physical sense with no sound pointless means nothing as it proves nothing and again circuit is no "Secret" a very simple topology class B is class B it has been done so often
Posted By: SMP
Date Posted: 04 January 2014 at 9:30am
and as you were told by other members on DIY forget it no schematic no value or interest academically
it is I believe not of any significant commercial value it is "Old Hat" nothing new be happy and be lucky will leave this pointless thread
Posted By: SMP
Date Posted: 04 January 2014 at 9:32am
I see your request for "Thread lock" given oh well would have been useful to us both maybe to exchange ideas but i do not think much for me to learn here leaving thread now
Posted By: MarjanM
Date Posted: 04 January 2014 at 10:54am
I think most of the members here are interested in what the amp can actually do, and could not care less about the topology.
Posted By: GEB
Date Posted: 04 January 2014 at 11:12am
+1
Posted By: DjLeco
Date Posted: 05 January 2014 at 6:32pm
After finishing those for selling, entire project will be for selling.
Cost will be 350 euros, and next owner will receive enitire documentation and gerber files to produce it.
Just give the files to an PCB manufacturer, and start to make it.
Posted By: Wiljj78
Date Posted: 03 April 2014 at 5:10pm
Hi leco,
What's the price each module?
Regards,
Posted By: DjLeco
Date Posted: 04 April 2014 at 12:19am
Price for one module is 150 euros, heatsink included.
Posted By: Mark James
Date Posted: 04 April 2014 at 12:35am
looks good to me [altho im a speaker man not an amp man lol] nice to see someone doing there own thing well done :-]
insert silly sentence here
Posted By: DjLeco
Date Posted: 04 April 2014 at 1:42pm
Thank you for appreciations, sir.
