carpet on HD 15
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=856
Printed Date: 27 March 2026 at 12:39am
Topic: carpet on HD 15
Posted By: philip banyer
Subject: carpet on HD 15
Date Posted: 05 November 2004 at 11:34am
Can I use carpet on the of HD 15 inside and outside of the cabnet.
Will this effect the sound?
Many thanks PBanyer
Posted By: loophole
Date Posted: 05 November 2004 at 3:51pm
outside no, inside yes
don't carpet the inside, it looks silly and will affect the sound. to what extent, im not sure, but just don't do it, because there's no reason to. stevek (check the readers projects page) has the right idea - if you must carpet, just do the outside, and paint the inside normally.
Posted By: Andrew
Date Posted: 05 November 2004 at 4:44pm
If the carpet is thin and dense you may get away with carpet on the inside, to match that of the outside.  Try a piece inside the horn to see if it makes any difference before you glue any down.  Even if it does make a small change to the sound, it may benefit from looking better, whilst still sounding pretty good.
Posted By: loophole
Date Posted: 05 November 2004 at 6:00pm
looking better?! i think we come from two very different schools of thought andrew ;)
Posted By: Andrew
Date Posted: 05 November 2004 at 9:16pm
If the punters think it looks good, they are more likely to think it sounds good.  You can have the best system in the world, but if it looks shodily made (with Philip's profession I'd expect it to be meticulous), that will be the impression people make.
