help for reggae dub sound
Category: Other Chat
Forum Name: Roots n Culture Forum
Forum Description: Talk about speaker box with other sounds here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=8568
Printed Date: 27 March 2026 at 2:16am
Topic: help for reggae dub sound
Posted By: king david
Subject: help for reggae dub sound
Date Posted: 07 February 2007 at 10:40am
Posted By: Static Age
Date Posted: 07 February 2007 at 11:14am
why not use 4 18" single reflex boxes, i think they would sound better on the low notes than 15's.
Posted By: Tom Umney
Date Posted: 07 February 2007 at 1:03pm
Microscooper 15's [smaller than normal 15 inch scoops] on castors would be your best bet for a reggae sound.
They can easily be moved around on your own as long as your not carrying them up flights of stairs.
Or even 4 Punisher Horns are they are compact and light.
Posted By: Matthias
Date Posted: 07 February 2007 at 7:38pm
go for 5kw and i would advise you: 2x X1 with a recommended speaker for deep Bassline, 2x Hd 15 for kickbass and your tops. Be sure to give the X1 not too much power, lets say a 1000 watt driver not more than 1,2k because its a bandpass and will overheat. this should be a good set but for real vibes 150 people it is not that much. X1 is a heavy cabinet and gives you deeeep bassline but its not throwing the sound too far. for indoor supreme.
Posted By: Matthias
Date Posted: 07 February 2007 at 7:39pm
toms option is good too, the punishers are a fine enclosure...
lol, punishers are compact but not light...!!
Date Posted: 07 February 2007 at 9:01pm
Well light enough for 1 person to carry is what I meant.
Not a 2-3 man job like an 18 inch scoop.
Date Posted: 24 February 2007 at 10:05am
Posted By: mykey
Date Posted: 24 February 2007 at 11:21am
you have to have allot of them for dub music
2 double 18'' reflex will do you
......just all them hanging there like giant bananas.
Posted By: Tekasis
Date Posted: 24 February 2007 at 11:50am
You don't 3 people to carry a full size scoop, 2 is enough, even 1 person can roll it onto one end, then the side & so on & get it into a van without a tail lift.
Have you considered a Mini-scoop on wheels King David ?
Believe me, they do sound good, especially the 18'' ones. If they are built correctly, they do play & sound deep/low.
Posted By: ceharden
Date Posted: 24 February 2007 at 12:43pm
For portability and best all-round performance the single 18" boxes as Static Age suggested are your best bet.  B&C Sub18 design is a good example and the plans are on their website.  15" reflex boxes tend to be nice and punchy but can lack the real low frequencies.
Scoops will give you the classic reggae/dub sound but tend to be large cabs.
In terms of mid-tops S200 have a lovely sound to them but you have to be careful as they won't handle a massive amount of power and replacement diaphragms are getting more and more difficult to find.  If you've got them already then stick with them.
Some single 15" + 1" mid-tops (like X15 but you can make the box smaller than on the plans without sacrificing anything important!) are another simple but effective option. For the size of parties you're talking about, 12" +1" cabs would also be ok.
Date Posted: 02 April 2007 at 8:32am
Posted By: Matthias
Date Posted: 02 April 2007 at 12:10pm
if you have 200-300 (!) people on your sessions, dont think of doing it because you dont sound like a Soundsystem with 500 W reflex...double it and hornload your complete system because this is a big crowd...
I would still advise you to take something like X1 and punishers, but you must know that the X1 throw the sound not too far ( Bandpass ) but really loud and 2 of them with Void drivers will give a serious feeling in your chest. ( I have one too 1,2kw into driver, nothing but heavy)
as mykey said, if you only take punishers you will need min. 4 ( staying together with hornmouths ) to get 40hz but its loud then.
X1 give you 30-80hz(alone), thats the important bass for dub, because these frequencies are the ones you feel...and are the ones which the tunes are produced.
One love
Date Posted: 02 April 2007 at 12:48pm
Posted By: Matthias
Date Posted: 02 April 2007 at 2:11pm
100 people would be OK but not optimum. I bet 2x X1 with recomended driver would be louder and heavier than 2x double 500w Reflex. X1 is a small cab, good to lift. Maybe you are lucky and you can run your 15"1 tops down to 80hz sounding well then you have a nice set even with 2x X1
Date Posted: 03 April 2007 at 1:16pm
Date Posted: 03 April 2007 at 5:33pm
Originally posted by king david king david wrote:
got another chance now to get
2 double 18" reflex boxes, 1000w rms each, similar to the g subs on speakerplans.com, with wheels for easy transportation
2 15"+1" mid-tops, 350w rms each
powered by a crest 2x1000w on subs and another crest 2x400 on tops
i think it can be good for my parties (in clubs with capacity of 200-300 people), dont know if mid-tops are strong enough for those subs.
thanks for any feedback
one love
As double 18 inch boxes are very large, your better off building 4 18 inch super scooper 18's loaded with PD1850 or PD186 or Void V18-1000.
18 inch scoops will beat double 18's for loudness and chest kicking bass and go quite deep too.
Double 18 inch reflex will go deeper but will be about 4x quieter than 18 inch scoops, and lack any real chest kicking bass.Which most reggae sounds have.
Date Posted: 04 April 2007 at 4:06am
Date Posted: 06 April 2007 at 10:20am
