Porn Horn skeleton
Category: Plans
Forum Name: Po rn Horns
Forum Description: Discussion / Questions about the Po rn Horns
URL: https://forum.speakerplans.com/forum_posts.asp?TID=8583
Printed Date: 27 March 2026 at 2:16am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Porn Horn skeleton
Posted By: Bob@DAE
Subject: Porn Horn skeleton
Date Posted: 07 February 2007 at 7:21pm
Hi I would like to know if the new Porn Horn can be use as a skeleton. The idea would be to hang the horn in a metal frame or fix the front of the horn to the frame and hang the speaker with chains or cables. a drawing to understand my vision of the frame. http://img254.imageshack.us/my.php?image=horncadrezp1.jpg
Thanks for any advices and sorry for my (poor) english.
Posted By: norty303
Date Posted: 08 February 2007 at 6:15am
With the forthcoming Porn Horn MkII you should have no problem having a skeleton frame, as it has its own integral rear chamber. The MkI didn't have this chamber so would've made things a bit more complicated as you'd need to fabricate a rear chamber for it.
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: Bob@DAE
Date Posted: 12 February 2007 at 6:12am
Ok, thanks for the answer. I think i'll do a steel frame with square tubes. I was also wondering how much watts amplifiers should i use. How many watts the P.Audio can hold ???
Posted By: login4
Date Posted: 17 February 2007 at 6:43am
probly about 500 odd
------------- CELTIC SUBSONIC SOUND SYSTEMS
Posted By: odc04r
Date Posted: 17 February 2007 at 2:14pm
I know its a pain to weld compared to steel but would an Al frame not be better on the whole weigth wise?
Posted By: COWFOOT
Date Posted: 18 February 2007 at 10:30am
Aluminium is lighter no doubt but you're gonna be using a small amount of metal so the weight difference shouldn't be material unless you're a weakling to begin with.
Posted By: Bob@DAE
Date Posted: 05 March 2007 at 6:20pm
At last, i won't build it in a skeleton. I'll use birch plywood. Does anyone know when the Horns (12" + 1") will be available ???
Posted By: Bob@DAE
Date Posted: 10 May 2007 at 6:36pm
Now that the porn horns are supposed to be available, i can see on P.A.P. website that they are available complete ready build. Can someone tell me if there is a passive Xover in the cabinet or is it build to be bi-amplified.
Posted By: unclejam
Date Posted: 30 May 2007 at 2:14am
bi amped cross over points are given too
