inuke 6000
Forum Name: Advanced Discussion
Forum Description: Advanced discussion area for higher lifeforms
URL: https://forum.speakerplans.com/forum_posts.asp?TID=85883
Printed Date: 26 March 2026 at 10:55pm
Topic: inuke 6000
Posted By: PDH
Subject: inuke 6000
Date Posted: 20 March 2014 at 2:28pm
I bought a NU6000 and do not have the crossover putting out any low freq. Has any one ran in to this issue?
Posted By: discosucks
Date Posted: 20 March 2014 at 2:34pm
You will have to expand on your question .
Posted By: patryk1305
Date Posted: 20 March 2014 at 2:54pm
I think he means the amp is not putting out any lows?
I assume its a 6000DSP version. Did you buy it new or used?
If used then maybe someone had it set up to power mid tops
Posted By: Goodvibetribe
Date Posted: 20 March 2014 at 3:01pm
Have you even contacted Berry about this yet?
George c - www.gorilla-audio.co.uk facebook.com/gorillaaudiohire
Date Posted: 20 March 2014 at 3:06pm
And how do you do that with them dont know the amps really , have thay got dip switch's ? internal x/o?
Posted By: PDH
Date Posted: 20 March 2014 at 3:08pm
This is a new unit. I set my input with two XLR from my mixer board to the A/B amp inputs on the amp. Set the stereo/mono swithch to stereo and the full range/crossover switch to crossover. manual says 1ooHz and below outputs from channel B. That is not happening. I am still getting full range with the switch in either position. Bi-amp diagram shows 1+and1- is for top cabs and 2+and2- is for sub freq. rewired a spekon connector to the 2+2-to 1/4" configuiration and the channel had no output. I am using a two wire spekon to 1/4" for my outputs. Confusing with the biamp configure pic on the A channel. The way the manual reads the amp should have output A for tops and B output for subs but that is not what I am getting.
Posted By: oldskool
Date Posted: 20 March 2014 at 3:37pm
Would this not be better off in the newbie discussions rather than the advanced?
Politics is the art of looking for trouble, finding it everywhere, diagnosing it incorrectly and applying the wrong remedies
Posted By: Requiem
Date Posted: 20 March 2014 at 4:22pm
Set it to full range then use an active crossover inbetween, the built in ones are shabby anyway
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
Posted By: PDH
Date Posted: 20 March 2014 at 4:34pm
I have a crossover and it will work that way, allready tested that, Will have to use that for now. Cannot get any solid answers from the factory or the retailer. Back to old school! Thanks to all for the replies.
Posted By: kedwardsleisure
Date Posted: 20 March 2014 at 6:45pm
If you're connecting a sub to output speakon ChB you should be wiring to +1 -1
The +2 -2 is if you want to bi-amp a single speaker with a 4-core speakon lead in which case you use ChA outlet.
This is explained on the back of the amp panel.
North Staffordshire
Posted By: PDH
Date Posted: 20 March 2014 at 6:58pm
Yes that is on my list, Thank you. I am going to use A input in mono with the crossover switch on and see if that works. Thanks for the reply! I do have an external crossover to use but trying to cut back a little equipment on the stage. I hope that this amp will respond as I expect.
thanks again!
Posted By: Swampgas
Date Posted: 25 August 2014 at 10:53pm
Hello, I recently purchased a 6000DSP. My plan was to Bi-amp using the internal crossover (subs in channel A/Highs in channel B) with 2 pole Speakon cables but it didn't work in BiAMP 1. If you do that in BiAMP 2 it works great! I ran my setup all day in 100 degree weather, in the sun without a wimper.
