SMT 212 building
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86007
Printed Date: 27 March 2026 at 2:16am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: SMT 212 building
Posted By: Fabianm_be
Subject: SMT 212 building
Date Posted: 26 March 2014 at 6:35pm
Hello All,
After a few weeks working on various projects since I finished the first pair of 186 horns I built for my son: http://forum.speakerplans.com/newbie-building-186-horns-finished_topic84892.html" rel="nofollow - http://forum.speakerplans.com/newbie-building-186-horns-finished_topic84892.html , this is time to be back in the workshop to start building the tops.
My choice is to build a pair of SMT 212 to fit 2 pairs of 186 horn.
I modified a bit the design to add handles, a curved grid like the one I used for the 186 and D rings, just in case of we need them to flown the tops from trussing.
As drivers, I selected these components:
- 4 Beyma 12MI100 http://profesional.beyma.com/pdf/12MI100E.pdf" rel="nofollow - http://profesional.beyma.com/pdf/12MI100E.pdf - 2 Compression P Audio BM-D750 Serie 2 http://www.p-audio.co.uk/pdf/BM-D750.pdf" rel="nofollow - http://www.p-audio.co.uk/pdf/BM-D750.pdf - 2 Horn P Audio PH-3223 http://www.p-audio.co.uk/pdf/PH-3223.pdf" rel="nofollow - http://www.p-audio.co.uk/pdf/PH-3223.pdf
Once fully finished, the system will look like this:
Here is my cut sheet for 3 square panels of 15mm 11 ply:
4 hours of workshop work Today:
Create template for the grid round section:
Cut the parts:
Prepare holes for D rings:
Use template for the round part:
A first fast cut with jigsaw:
And finished with router:
Holes for D-Rings finished:
A few parts ready for assembly and all the templates in the background:
Next workshop time will be on Friday
Posted By: erikp74
Date Posted: 26 March 2014 at 7:07pm
Posted By: Gfoster
Date Posted: 26 March 2014 at 7:21pm
Posted By: Danny A
Date Posted: 26 March 2014 at 10:05pm
Good work, are your CAD drawing made with sketchup?
Date Posted: 27 March 2014 at 3:53am
Yes, Sketchup.
Thanks for your comments.
Posted By: Gfoster
Date Posted: 27 March 2014 at 11:04pm
I really need to learn sketchup.. I did a little visualisation in illustrator
Date Posted: 28 March 2014 at 5:32pm
Today was a good and productive workshop day :-)
Someone asked me what kind of saw I'm using. Here is:
Just pictures of Today without comments:
Posted By: dlyxover
Date Posted: 28 March 2014 at 6:50pm
Looking really good
------------- Lignum_ww@icloud.com GNKaudio@icloud.com
Posted By: TONY.A.S.S.
Date Posted: 28 March 2014 at 6:55pm
Excellent job so far, looking very neat.
------------- http://www.facebook.com/tony.rossell.3" rel="nofollow - http://www.facebook.com/tony.rossell.3
Posted By: Timebomb
Date Posted: 28 March 2014 at 11:59pm
Nice
------------- James Secker facebook.com/soundgearuk James@soundgear.co.uk www.soundgear.co.uk
Posted By: bitSmasher
Date Posted: 29 March 2014 at 12:09am
Nice work space! Might have to look at making a table like that - is it sacrificial (designed to be cut through)?
Date Posted: 29 March 2014 at 5:56pm
bitSmasher wrote:
Nice work space! Might have to look at making a table like that - is it sacrificial (designed to be cut through)? |
Yes, this is a sacrifical design and this is very easy to work on it. You can also screw by the bottom.
Date Posted: 29 March 2014 at 6:01pm
Today's work. The cabs are now ready for painting.
Here is the second one:
And both are back at home:
Tomorrow, I will drill the holes and insert the nuts for the drivers, feet, ...
Posted By: sn95
Date Posted: 29 March 2014 at 6:08pm
Posted By: rhuet99
Date Posted: 30 March 2014 at 5:35am
Neat and Tidy. Well done.
Posted By: PinHole
Date Posted: 30 March 2014 at 5:01pm
WOW! Really nice woodwork.
------------- Signature is important. So I always write something in this dedicated field.
Date Posted: 31 March 2014 at 9:45am
Hello All,
even on Sunday, I worked a few hours to drill all required holes, insert all nuts, paint one cab and finish it. Thanks to Warnex paint to dry very quickly
I worked very fast and didn't took many pictures. I tested one cab this morning and the result is not bad at all. At least at 30% Master in my garage
Posted By: GekoMusic94
Date Posted: 31 March 2014 at 12:46pm
Nice work! but, aren't the handles the wrong way round?
------------- https://soundcloud.com/dj-uber
Date Posted: 31 March 2014 at 1:34pm
GekoMusic94 wrote:
Nice work! but, aren't the handles the wrong way round? |
Good catch  . I preferred to put them reverted because, in the right side, I was not able to insert the driver and screw it.
Posted By: cravings
Date Posted: 31 March 2014 at 2:22pm
carrying them upside down probably won't be a problem hehe. looks great. i have single 12" of these, i should have put grill mounts like you.. i've always felt like mine needed bracing of some kind in the front.
they look great though. good job.
Date Posted: 04 April 2014 at 8:36am
Hello All,
Finished the second cab a few days ago but didn't get time to took pictures.
Here is a test I made in the garage. The system sound great even with the Behringer stuffs into the rack.
Last step for next week will be to paint and fix the grids.
Have a great week-end
Date Posted: 04 April 2014 at 10:34am
id be wanting a proper processor asap!! Once you get your delays etc sorted, the whole rig will come truely alive! add some more ampage on top, and you will be shocked!!
Great work
------------- ''Remember that the object of a subwoofer is to enhance the output of your main speakers, not overpower it''
Date Posted: 04 April 2014 at 2:26pm
Processor will be the next step.
What can you give as a guidance?
I guess this is like the amp, this is better to get an used Driverack 260 than a new PA+ or Behringer Omnidrive.
What is the alternatives in the 500 Euros range (new or used)?
Date Posted: 04 April 2014 at 2:31pm
in honesty, id just get a Behringer DCX - the extra money spent makes very little difference up to XTA/Lake kind of standards.
There are very favorable reviews of the DB mark units, which in the UK are distributed by member 'Bee', not sure if they can be had your way or not. If you were fancying getting an import, look at the SAE amplifiers Bee also has, they also have received brilliant reviews, and at the prices they are, are brilliant value for their spec.
Date Posted: 04 April 2014 at 2:32pm
It has to be said real top quality/clean wood-work here!
real nice top marks!
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Posted By: corell
Date Posted: 04 April 2014 at 3:09pm
yeah just get a behringer DCX, its almost magic for that price
Posted By: all bass
Date Posted: 04 April 2014 at 3:49pm
| +1
One of Uli's rare gems. Even for double the money there is not much improvement available.
Date Posted: 10 April 2014 at 10:30am
Just a little update because I finally got time to paint the grids and screw them.
These tops are now officially finished
Posted By: catalin
Date Posted: 10 April 2014 at 12:18pm
Nice!!
Posted By: Mark James
Date Posted: 10 April 2014 at 1:01pm
------------- insert silly sentence here
Posted By: Porky
Date Posted: 10 April 2014 at 2:03pm
Posted By: njw
Date Posted: 10 April 2014 at 6:10pm
They look loud!
Posted By: ermita
Date Posted: 10 April 2014 at 7:44pm
nice work mate...like the curve grill
Posted By: mooreb
Date Posted: 10 April 2014 at 8:21pm
Seriously nice, I have some but it looks like I may be rebuilding them after seeing these!
------------- FB LS AUDIO SYSTEMS
Posted By: cravings
Date Posted: 10 April 2014 at 8:22pm
yeah i feel like i should do my single ones properly.
Posted By: mooreb
Date Posted: 10 April 2014 at 8:24pm
As well as the cutting list do you have the dimensions? Thanks
Date Posted: 10 April 2014 at 9:29pm
Thanks for your comments. For the cut list, I need to leave now for a few days but here is what I printed to use in the workshop.
Enjoy
Date Posted: 10 April 2014 at 9:39pm
Just forgot. All angles are 22.5° and wood is 15mm.
Posted By: mooreb
Date Posted: 10 April 2014 at 10:04pm
Thank you very much!
Date Posted: 10 April 2014 at 11:10pm
Again, more great work! Thanks for showing and sharing
Posted By: crossed
Date Posted: 11 April 2014 at 3:50am
I'm putting the finishing touches on my current build, and am going to post some build pics when I get it complete, but when I see pictures like these it almost makes me ashamed to post them.
Posted By: ivan2912
Date Posted: 02 June 2014 at 11:00am
Can you also share the frequenty response plot? I may be also interested in building this speaker.
Grtz
Posted By: T-Bone
Date Posted: 02 June 2014 at 1:21pm
That's a Great job an inspiration for us here in the US and not using a CNC machine even makes it challenging with that nice Festool saw. Cutlist is nice too, just a thought if I had to build these I would consider putting BMS 4592 on tops just my $.02. Very nice job man!
------------- BASS, how low can you go!
Posted By: Audio_Stash
Date Posted: 12 June 2014 at 11:21pm
Wow this build looks absolutely perfect! good job!Are you a fine carpenter by trade or does Festool just bring out the best in you?  But once again, fantastic job. Well done
Date Posted: 13 June 2014 at 7:45am
I'm not carpenter by trade at all, I'm working in information technology. This was only the second pair of speaker I was building. So we will say Festool helped me a lot ;-) Thanks for your comments.
Date Posted: 13 June 2014 at 7:46am
Grtz
Sorry, I didn't simulated these speakers and I don not have any measure system.
Posted By: RemyK
Date Posted: 02 May 2016 at 1:20am
Behringer DCX are you guys serieus ? He was talking about a DBX 260, way beter in sound then the Behringer! DBX 260 sounds beter then the DBX driverack PA, Or a BSS omnidrive or BSS 366T is a good option for around 350 Euro in Belgium (anno 2016)
Posted By: Teunos
Date Posted: 02 May 2016 at 9:00am
You are the one who should be wondering if you are serious. Behringer DCX is the best processor money can buy unless you are willing to part with Xillica money... which is a step up of 3 to 4 times the price of a DCX. There is a lot of documented information on here regarding this topic. You are free to introduce your personal opinion, but dont present it like facts. Facts are widespread both on the web and here as well. Try for instance: http://forum.speakerplans.com/inside-compared-bss-9088-dbx-pa-dcx2496_topic25538.html?KW=2496+compared%20" rel="nofollow - inside/compared BSS - 9088 / DBX - PA / & DCX2496 - Speakerplans.com Forums - Page 1 Also, this topic is over two years old now, i think the TS has found a processor by now.
------------- Best regards, Teun.
Posted By: Shortrope
Date Posted: 02 May 2016 at 9:55am
Great first post!!
------------- My Tinnitus is coming along nicely!!
Posted By: kevinmcdonough
Date Posted: 02 May 2016 at 12:56pm
Teunos wrote:
You are the one who should be wondering if you are serious.Behringer DCX is the best processor money can buy unless you are willing to part with Xillica money... which is a step up of 3 to 4 times the price of a DCX. There is a lot of documented information on here regarding this topic. You are free to introduce your personal opinion, but dont present it like facts. Facts are widespread both on the web and here as well. Try for instance: http://forum.speakerplans.com/inside-compared-bss-9088-dbx-pa-dcx2496_topic25538.html?KW=2496+compared%20" rel="nofollow - inside/compared BSS - 9088 / DBX - PA / & DCX2496 - Speakerplans.com Forums - Page 1 Also, this topic is over two years old now, i think the TS has found a processor by now.
Just to make sure people are aware, back in 2009 when the post you linked to was written, the Berry DCX was a great processor and great value for money. Think most people would now agree that these days, the db Mark line of processors is a good improvement on the DCX for similar money. The db Mark XCA range is a wee step up and a few more features, but then yeah, your really up to processors in the £1000 mark to see big improvements, and the Xilica in particular as you end up with FIR processing and all pass filters.
K
Posted By: Teunos
Date Posted: 02 May 2016 at 4:00pm
All good and all, the dbmark may be a good unit, but is not available widespread outside the uk or this forum whilst a dcx you can buy on every corner of the street in every country around the globe. So as good as it may be, i dont consider it a serious competitor actually for the time being.
Posted By: rish
Date Posted: 02 May 2016 at 8:26pm
Teunos wrote:
All good and all, the dbmark may be a good unit, but is not available widespread outside the uk or this forum whilst a dcx you can buy on every corner of the street in every country around the globe. So as good as it may be, i dont consider it a serious competitor actually for the time being. |
Agree. DB mark not so widely available. Also I don't think in any way it's a competitor.
Date Posted: 02 May 2016 at 8:43pm
Hey
Yeah agree about the availability. While everyone agrees it's a noticeable improvement in sound quality (most posts on here give that opinion of you have a search) it's not quite as widely available it's true.
Should help now that Blue Aran stock them though, so should see quite a few more out and about
K
Posted By: corell
Date Posted: 03 May 2016 at 2:33am
Monacor DSM 48Lan is an upgrade (and imo the "first" really worth it) over Behringer DCX as it has: + 4 ins 8 outs + allpass filters + crossover filters on the inputs + peak limiter and compressor for better driver protection + more processing power (10 PEQs per in and out channel) + a good software (ipad, mac or pc) + 4 different access levels with seperate passwords + the SUM signal is changed when an input channel building the sum is changed (! on a DCX, SUM is treated as a "seperate input channel" !) + it can be adjusted while playing without making a sound!
- no DEQ - settings on the unit itself (without the software) are not that intuitive - not many around - 650€ (thats still a bargain!)
Its an AllDSP unit.
For dry hire where 3/6 is sufficient, there is simply NO competitor to the DCX. Name a DSP with dynamic EQs. Is it 4000€+? No? Is it 1500€+ ? No? Its a DCX then
Posted By: MarjanM
Date Posted: 03 May 2016 at 8:51am
I wish Uli comes up with a updated model.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Date Posted: 03 May 2016 at 9:25am
I've got two for sale...anyone want em?! 😁😁
Posted By: rish
Date Posted: 03 May 2016 at 11:37am
Its an AllDSP unit.
You are comparing a 650 euro unit to a 280 euro unit. Good comparison Corell, keep it up.
Posted By: all bass
Date Posted: 03 May 2016 at 12:15pm
Corell called it the first real upgrade step from DCX. Upgrade in performance, but not at the same pricepoint.
------------- https://www.instagram.com/my_modular_journey/
Posted By: corell
Date Posted: 03 May 2016 at 5:15pm
Its an AllDSP unit.
You are comparing a 650 euro unit to a 280 euro unit. Good comparison Corell, keep it up. |
being sarcastic? if so, sorry for posting information. Im sure you know every single DSP around and what are its pros and cons? yes, i am comparing a 280€ unit to a 650€ unit. I have not hidden this fact. I own 3 DCX and i love them. where is the problem? If not sarcstic, ignore this.
Posted By: unclejam
Date Posted: 27 November 2016 at 1:35am
Not to be a Grave digger but how are you enjoying these?Getting 4 built atm and I am currious as to what your prolonged opinion of these are.
