Advice on new 15" Horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86205
Printed Date: 27 March 2026 at 12:52am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Advice on new 15" Horn
Posted By: corell
Subject: Advice on new 15" Horn
Date Posted: 09 April 2014 at 3:43pm
I wanted to design a basshorn doing 40Hz in a stack of 4 but also be usefull in singles or double stacks (lacking the "dip" in response). The driver i choose is the 18sound 15LW2400. Due to beeing a 15" i guess it will play quite high up and be fast and punchy. Its rated at 1200w and has 10mm xmax. I see no disadvantage compared to a 18" in a horn.
Anyway, here is what i came up with: 90x 50x 90 cm (405l), so way smaller than WSX etc...
http://www.audiofotos.eu/display-i1917b7rapn.html" rel="nofollow">
The driver is reverse loaded to minimize power compression losses. It can handle the full 1200 w RMS till xmax is reached. also, it has a lot of 90° and 45° angles, which should make it easier for DIY.
Plot in 2 and 0,5 pi :
http://www.audiofotos.eu/display-i1918b0e58i.html" rel="nofollow">
its not "flat" in 2pi, but with the right Low pass filter, its 103db/w/m 43-150Hz -3db. surely, if you only ever use single bass bins, you wont go for a horn, so see it as a compromise (as allways...).
edit: it can be made totally flat in singles by making it 10cm higher and 5cm deeper and leave the rest as it is. (475l)
Please share your thoughts!
If anyone is interested in confirming my simulations, please write me and i will send you the sketchup file ;)
Will post all the dimensions to build it for private usage after im sure it works the way it should!
Posted By: Timebomb
Date Posted: 09 April 2014 at 4:31pm
Looks good, i like the layout, it seems there a big step in expansion at the 180 degree bend though? Or is that just me?
------------- James Secker facebook.com/soundgearuk James@soundgear.co.uk www.soundgear.co.uk
Posted By: corell
Date Posted: 09 April 2014 at 4:42pm
it is and thats the whole point to get the respons smooth in singles ;)
Posted By: ape3435
Date Posted: 09 April 2014 at 5:43pm
Like it, been working on a dual 15" folded horn myself. Not as good with the technical stuff like you though.
Posted By: snowflake
Date Posted: 09 April 2014 at 6:21pm
without seeing the sim inputs it's hard to say for sure but I'm a bit suspect of your 'flat' response. it does look like there is no dip but I suspect this is because it isn't reactance annulled so there is no peak at 45Hz. 102dB 1w/1m @ 60Hz is ok but nothing special.
what happens if you move the back panel in 10cm? does sensitivity and excursion at 60Hz get worse or does it just make response at 45Hz better?
Posted By: corell
Date Posted: 09 April 2014 at 6:34pm
snowflake wrote:
without seeing the sim inputs it's hard to say for sure but I'm a bit suspect of your 'flat' response. it doesn't look like there is no dip but I suspect this is because it isn't reactance annulled so there is no peak at 45Hz. +- 0,2db difference if masked
102dB 1w/1m @ 60Hz is ok but nothing special. i know, for me there is nothing special in bass cabs at all ;) its all about finding the best compromise in size/low end/ SPL/ size of stack...
what happens if you move the back panel in 10cm? does sensitivity and excursion at 60Hz get worse or does it just make response at 45Hz better? it "adds" a little between 45 and 70hz, so 103db flat ;)
thanks for the input !
Posted By: Mark James
Date Posted: 09 April 2014 at 6:39pm
interesting design :-] should think stack of four/six will do some damage :-]
------------- insert silly sentence here
Posted By: Keen
Date Posted: 10 April 2014 at 2:45am
corell, please pass on that sketchup file if you'd like some feedback on sims.
younghealthandfitness at gmail dot com
Cheers, Simon
Posted By: DanielIt
Date Posted: 10 April 2014 at 6:12am
I would like to sim your cab with another 15" driver that i have laying arround.Could you pass the info on bassmnc80 at yahoo.com. Thank you, Daniel
Posted By: all bass
Date Posted: 22 April 2014 at 7:57pm
Any new developments in this project?
Posted By: corell
Date Posted: 23 April 2014 at 12:41am
Im afraid im Not able to build a proto in the Moment,sorry. Simon confirmed my simulations but i would still be happy to get some feedback about the reverse loading etc.
Rcf 15x401 also looks really promising in this one
Posted By: T-Bone
Date Posted: 23 April 2014 at 4:48am
Nice design corell I would like to build some but I am looking to build an 18" version that would go a little lower and beat the pants of the WSX or even a Startec type folded 18". Can you maybe make it a little taller and a little longer to fit a cheap Eminence 18" woofer like Omega or a Faital 18" neo to make it lighter cab? Looks good though I'd like to build some in 15 mm but in 18" version? Thanks!
------------- BASS, how low can you go!
Posted By: b grade
Date Posted: 23 April 2014 at 7:40am
You probably don't want 15 mm playing super low. you want rigid heavy wood so you don't lose energy to vibration. I know BFM uses 15mm in his folded horns, but then they are pretty extensively braced to make up for it. Personally I would take the weight, and still brace intelligently.
Posted By: bitSmasher
Date Posted: 23 April 2014 at 8:45am
12 mm actually, and that's based around relatively low powered drivers
Posted By: TONY.A.S.S.
Date Posted: 23 April 2014 at 9:25am
My only observations about this Design, is that it is more or less follows the path of a Scoop Bin, with the exception of how the Speaker is loaded. So to me it looks like a scoop without the Direct radiating part. Do you think there will be an extra advantage with this design over and above the normal Scoop design. Due to compression loading, I realise it would sound different from a Scoop, but just wondering how they would perform side by side. Looks like an interesting Mod though.
------------- http://www.facebook.com/tony.rossell.3" rel="nofollow - http://www.facebook.com/tony.rossell.3
Posted By: all bass
Date Posted: 23 April 2014 at 9:43am
It can be used as a one way bass solution. It doesn't have that inevitable dip that scoops have where the horn and the direct radiator are 180 degrees out of phase.
Date Posted: 23 April 2014 at 9:56am
And to give the full picture, where that dip happens, is usually outside of the Sub range. It is in mine anyway.
Posted By: corell
Date Posted: 23 April 2014 at 4:44pm
Must say for my kind of music (techno) i have never been interested in scoops at all, so did not think about it yet. My major design goal was a one-way bass hitting 40Hz. next one was to make it as flat as possible in singles without losing the smooth graph in a stack of 4. Then i thought : why not cooling the magnet?! The folding also enables you to put wheels in the lower corner and handles in the upper one to push/pull it. My questions now would be what you guys would change and if and why you would prefer this one to WSX and similar. I really want it to be an interesting option for DIY builders, so i ask for your help as your obviously part of them. If i would make it for myself to earn money, i wouldnt do so^^
Posted By: T-Bone
Date Posted: 23 April 2014 at 6:57pm
Ok my previous post maybe a little too far fetch, I understand what the cab's purpose by rereading your first post. I am just curious have you simulate this design with another 15" cheaper woofer readily available here in the US like Eminence or even Dayton Pro woofers available through MCM Electronics? Just curious corell so I can build one and measure it? Thanks!
Posted By: corell
Date Posted: 23 April 2014 at 8:32pm
send me the TSP of your intended woofer and i will check it ;)
RCF 15X401 seems to be pretty cheap for its specs i think, but if thats not available, i will check others. we will have a chat via FB ;)
Posted By: T-Bone
Date Posted: 24 April 2014 at 7:27pm
Oh yeah I have always wanna try Eminence Impero 15A OR Faital Pro 15FH 1020 : http://www.eminence.com/speakers/speaker-detail/?model=Impero_15A
And
http://www.faitalpro.com/en/products/LF_Loudspeakers/product_details/index.php?id=201060110
http://www.eminence.com/speakers/speaker-detail/?model=Kappa_Pro_15LF2
15LF2 is now on sale at $152 each parts-express.com
Thanks corell it would be great to start something new here in the States, take care!
Posted By: tda-audio_2
Date Posted: 02 May 2014 at 12:25pm
to CoreLL
good job!
my version front loaded -invert driver
92x92x49 . 68kg . dr. ciare1200sw
Posted By: KidCreole
Date Posted: 02 May 2014 at 1:24pm
copying again
your copied version
Date Posted: 02 May 2014 at 1:30pm
\\\your copied version\\\\
my version -change chamber!
to corell - used ciare 15.00sw!
Posted By: T-Bone
Date Posted: 02 May 2014 at 1:35pm
Holy Geez, talk about Great minds TDA and corell you guys have something here I'd like to build 2 X 15" of you plans is there a way of enlarging or just build it double in one cabinet? Thanks guy's!
Date Posted: 02 May 2014 at 1:41pm
He has a great mind because he copies?
Date Posted: 02 May 2014 at 6:07pm
to Kid you want to win get oldschool ?
Posted By: tv00
Date Posted: 18 November 2015 at 11:25pm
Where's the hornresp input at?
Still a big box! I love the sound of FLH But I like the deep end & rear cancellation of TH Not sure what to build next!
------------- www.facebook.com/babysoundsystem
Posted By: BP1Fanatic
Date Posted: 24 November 2015 at 9:05pm
Can you post the HR input screen?
