Martin Destroyer x250 not working
Category: Other Chat
Forum Name: Lighting Talk
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86224
Printed Date: 27 March 2026 at 11:09am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Martin Destroyer x250 not working
Posted By: wangbag
Subject: Martin Destroyer x250 not working
Date Posted: 10 April 2014 at 10:48am
have 2 of these units, both are powering on one has light on the other doesn't, both gobo wheels move on startup but then stop and both mirror wheels have no movement at all but resistant to being turned when plugged in as if the motor is on but just not moving, any ideas to a fix or should i send them for repair?
------------- Gwarn me some of dis.
Posted By: wangbag
Date Posted: 10 April 2014 at 11:29am
poked around and sorted it, turns out one bulb had a loose connection and the other one i think the mic is screwed 'cus it works in master/slave (being slave) but not sound to light. yay
Posted By: lgosdset
Date Posted: 10 April 2014 at 6:24pm
get a dry soft paintbrush and clean the little electret mic. I have found that this restores the sound to light function on my destroyers.
If the stepper motors go on these, it is pretty much game over as I can not find them new anywhere, you can try and loosen and wiggle the housing around, or buy old broken destroyers/punishers that have a problem with the PCB/lamp and nick the stepper motors out of them.
Posted By: lgosdset
Date Posted: 10 April 2014 at 6:25pm
just found this!
http://www.ebay.co.uk/itm/MARTIN-DESTROYER-GOBO-COLOUR-STEPPER-MOTOR-robo-scan-scanner-/121149312291?pt=UK_Sound_Vision_Other&hash=item1c350fcd23" rel="nofollow - http://www.ebay.co.uk/itm/MARTIN-DESTROYER-GOBO-COLOUR-STEPPER-MOTOR-robo-scan-scanner-/121149312291?pt=UK_Sound_Vision_Other&hash=item1c350fcd23
woo. I can now get all of my destroyers working, but the cost of this motor is about the value of the fixture! so not really worth it.
Posted By: col_b
Date Posted: 24 April 2014 at 1:26pm
Got steppers for these in stock also, both new and used motors.
------------- AV, Sound and Lighting and Laser Hire, Sales and Service. http://www.klsuk.com" rel="nofollow - www.klsuk.com
