A sub that's 1460mm or more in length. :)
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86230
Printed Date: 27 March 2026 at 8:46am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: A sub that's 1460mm or more in length. :)
Posted By: KonanSS
Subject: A sub that's 1460mm or more in length. :)
Date Posted: 10 April 2014 at 6:45pm
As above
1460mm long, by 580mm deep,
Twin 18" if possible, any ideas welcome :)
------------- KSS - Devon based always wanting to learn more
Posted By: GekoMusic94
Date Posted: 10 April 2014 at 6:47pm
A big reflex ;)
------------- https://soundcloud.com/dj-uber
Posted By: bass*en*mass
Date Posted: 10 April 2014 at 7:01pm
Ask PauliePaul, they had some huge double 1850s reflex back in the days... Remember some pics on here but cant tell you which thread etc..
Stretched BPHs might be easy to calculate/adopt aswell?
Posted By: flinnt45
Date Posted: 11 April 2014 at 1:56pm
Hey, Take a look at the Decware imperial, uses double 15,s but could be adapted for 2 x 18,depends on the vas of the driver, its about the right size
Posted By: studio45
Date Posted: 11 April 2014 at 3:45pm
Build a double Rhino or other mini-scoop? From what PauliePaul told me that would be more like what his 2x18's were, they were more complicated than a reflex. A double mini would be a beast of a box SPL-wise and they're usually around 700 tall so the double would be around 1400 wide laid on its side. Probably a bit deeper than 580 though, more like 650.
------------- Studio45 - Repairs & Building Commotion Soundsystem -Mobile PA
Posted By: KonanSS
Date Posted: 11 April 2014 at 5:37pm
Sme good ideas comming up here. Idealy if it helps I need a fast reacting sub, as it will be used for psytrance and jungle, house techno and live bands :)
Posted By: Mark James
Date Posted: 12 April 2014 at 1:48am
can you pm me a link for your b&c drivers i will get siming in a 6th order bandpass and also in a larger bandpass sub if that would be suitable? working on same principle as the em15 just tuned alot lower longer horn etc would that interest you? could make it modular so easier to move or maybey walts module horn modified might suit what you are looking for? take it this is to go with the em15s and the selenium tops yes????? the band pass horn idea would probably be a bit like the wo
------------- insert silly sentence here
and i doubt a scoop will suit you tbh :_]
Posted By: BeDome
Date Posted: 07 August 2014 at 6:49am
Just saw this, but you have to understand that most Decware plans are created for home use and not so much professional use.
------------- Let there be sound. Oh, and lights if you care.
Posted By: Meat
Date Posted: 07 August 2014 at 6:58am
Double Rhino build in a 2x18 reflex style. Do it. That thing'll rock.
------------- Don't test the champignon sound
Posted By: flinnt45
Date Posted: 07 August 2014 at 7:48am
Hi Understood that the majority of Decware designs are for home or car use, the exception is the imperial, if you read the articall on the site you can find reference to nightclub installs etc, the original imperial with a single 15 was used by king tubby in Jamaica, good enough for me, if you see the response chart this speaker kills all scoops stone dead.
Date Posted: 07 August 2014 at 3:04pm
or just do a modified x1 type 6th order band pass? singles could easily be 700 and something millimeters so two side by side would dstack well???? i mean like a letter box style shouldnt be too hard to design tbh
Posted By: mini-mad
Date Posted: 07 August 2014 at 3:11pm
...2 of these?
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: corell
Date Posted: 07 August 2014 at 5:30pm
Selenium HB1805C1, just build the two 18" symmetrical side by side like USB etc and not one above the other like in the plan.
http://hornplans.free.fr/hb1805c1.html
perfect chassis for this : BMS 18s450
Posted By: Meat
Date Posted: 07 August 2014 at 5:54pm
You need to talk to Lee in Montreal about his scoop...
Posted By: mini-mad
Date Posted: 07 August 2014 at 7:03pm
...or speak to Tony about a 21" scoop and lay it down on it side. That will make ya eyes wobble!!
Posted By: Sheggy
Date Posted: 07 August 2014 at 8:49pm
flinnt45 wrote:
Hi Understood that the majority of Decware designs are for home or car use, the exception is the imperial, if you read the articall on the site you can find reference to nightclub installs etc, the original imperial with a single 15 was used by king tubby in Jamaica, good enough for me, if you see the response chart this speaker kills all scoops stone dead. |
Kills all scoops stone dead huh? Talk like that has been known to light the blue touch paper here. Any link to these response graphs you mention?
S
Posted By: T-Bone
Date Posted: 09 August 2014 at 6:28am
Would love to see those graphs for the Imperial's. They've used the double 15 Imperials in clubs with Bertha's underneath with great success.
------------- BASS, how low can you go!
Posted By: Sheggy
Date Posted: 09 August 2014 at 8:50am
Hearsay so. Don't see why you'd need a scoop over a Bertha.
Posted By: Meat
Date Posted: 11 August 2014 at 6:59pm
Rich Ind St. built 6 imperials and they sounded good.
You're after a long port double 18 reflex though right? Something like the transmission line subs that Open Mind use?
http://hornplans.free.fr/openmind.html
Posted By: Enzo1234
Date Posted: 25 August 2014 at 9:34am
hi would like to build a 18" mini scoop but have no measurements to build it could some1 please help me wid this.I'm new at this
Posted By: Daniel S
Date Posted: 25 August 2014 at 11:41am
Sheggy wrote:
Hearsay so. Don't see why you'd need a scoop over a Bertha. |
Not really needed, but it's been done plenty of times. Used more as a kick bin I guess.
------------- Distortion is evil
Posted By: KonanSS
Date Posted: 25 August 2014 at 12:38pm
That looks awesome!
