What's a suitable 400/300w driver for a HD15?
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86719
Printed Date: 16 April 2024 at 8:44pm
Topic: What's a suitable 400/300w driver for a HD15?
Posted By: Daily Crisis
Subject: What's a suitable 400/300w driver for a HD15?
Date Posted: 11 May 2014 at 1:01pm
Hey,
I was wondering what a suitable 300/400w driver would be for a HD15? This is going to be my first ever speaker.
I have ordered a TA2400 MK-X (x2 1200w/4ohms) and as the clipping system isn't great on it apparently I don't want to blow my drivers with DJs going in the red etc. so I want 300/400w drivers to allow enough headroom (1.5x/2x).
I want to go with the Kappa 15LF but it's 600w and I want to daisy chain 2 HD15's together and also allow enough headroom.
Is there a good driver for a HD15 that is 300 or 400w?
Cheers
DAILY CRISIS
Posted By: RUS
Date Posted: 11 May 2014 at 1:50pm
Posted By: Timebomb
Date Posted: 11 May 2014 at 6:56pm
Kappa 15LF might say 600W on it but eminence are a bit optamistic with that number,  300-400W is about right for the kappa 15LF, they will run fine and you wont be over stressing the amp or the drivers.  PD154 will take a bit more power and go a bit louder if you like, but they dont sound as good as the kappa though (IMO).    I would look at the fane offerings also, the sov 15-600LF and the sov pro 15-600LF are both fairly similar to the kappa, ive not tested them though.
Posted By: njw
Date Posted: 11 May 2014 at 10:25pm
  You don't have to use an amp that is more powerful than your drivers even though it is good practice, as long as the amp is kept out of clip you'll be fine (if you've got djs playing on the system then you WILL need a good limiter!). For instance, my HDs were loaded with Eminence Omegas which are rated at 800w but the amps I was powering them with was feeding them 600w, I ran the system like this for years without a single issue.
Date Posted: 12 May 2014 at 11:37am
Great info thanks everyone.
I'm getting a Behringer UltraDrive Pro DCX2496LE. Does that have a good limiter on it?
DAILY CRISIS
Posted By: njw
Date Posted: 12 May 2014 at 12:55pm
  Don't know about the 'LE' version but I've always found the limiters on the normal Ultradrive very good.
Posted By: fat_brstd
Date Posted: 14 May 2014 at 3:42am
limiters on the LE are the same as the normal version
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
