2*1" comp,1*8" and 1*12"
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=86940
Printed Date: 26 March 2026 at 10:04pm
Topic: 2*1" comp,1*8" and 1*12"
Posted By: Father-Francis
Subject: 2*1" comp,1*8" and 1*12"
Date Posted: 24 May 2014 at 9:43pm
this is more for Mikey , building a cab with you 8" horn and the 12" horn would it be a waste of money ,or should one go for it ?
cause nuff designs that have or are still good are based on 8", 10", 12"
meyer MSL3
OHM HD-MH
Stasys 3 mk2
and many more !
Posted By: levyte357-
Date Posted: 24 May 2014 at 9:49pm
Sometimes, simple is best.
Expensive 12", on phase "bunged", long wide flare, with expensive Neo 2", will remove need for 8"/1" drivers.
Know someone in UK with just this setup, and shames many more complex systems.
BSS LMS & Quality amps, of course. Wink
Date Posted: 24 May 2014 at 9:56pm
so you mean using like the meyer horn and redoing the bong to match the 12" being used would just do the job with a go 2"neo,
Date Posted: 24 May 2014 at 10:00pm
Actually, mean something like the Porn Horns.
Learnt from hearing different systems, when you spend over certain budget on 2" drivers, they both go low and high. Shocked Big smile
Date Posted: 24 May 2014 at 10:13pm
Pm me some info I can read Bro Cry
Posted By: geoSal
Date Posted: 24 May 2014 at 10:14pm
Msl3 uses a 4''inch jbl comp which goes down to 1050hz if used with its original crossovers.So the two 12'' with the huge plug can meet each other quite easy.
Although nowadays it is quite common to use 8'' drivers to cover the gap between 12'' or 15'' and 1''-1.4'' comps, I doubt if meyer can achieve that kind of spl with low wattage drivers and old amps by choosing inserting a small cone driver between mid and hi.Maybe two 8'' drivers in horn with another phase plug could do the job but as mentioned above simple sometimes is much better.
I find the coax comps solution to be the best way.
Date Posted: 24 May 2014 at 10:31pm
Here you go... Big smile
Fiber glass phase bunged 12" horn, with matching driver.
Perfectly matched, expensive Comp & comp horn.
Quality LMS programmed to perfectly align & eq above.
Pro, quality amps, mixer.
Simple really.
Rest of us mortals have to make do with MT121 & Berry DCX.
Posted By: geoSal
Date Posted: 24 May 2014 at 10:42pm
Sometimes ι wonder if it is worth all the extra money to reach the same outcome if were using
simple ways from the start to achieve things that already work fine all these years.
Of course it is so much easier when you have the money to try new stuff.
Date Posted: 24 May 2014 at 10:46pm
Yes boss heard you loud and clear Wink
Posted By: KidCreole
Date Posted: 25 May 2014 at 1:37pm
15 + 8 + 1''
12 + 6.5 + 1''
12 + 1.4''
10 + 1''
Date Posted: 25 May 2014 at 2:06pm
These 2 belong to Josh 'Dea D'beat'
he picked 2 more up yesterday and now has 4 in his new stack
Flipside uses a 1'' above his SP12's
Date Posted: 25 May 2014 at 7:28pm
Mykey, whats approx freq range of your 12" horns, & with which suggested drivers ?
E.g., can they work with PD123, PD121, Eminence Kappa Pro, Fane 12MB?
Date Posted: 25 May 2014 at 7:58pm
Mikey do you have a 6.5" horn to go with the 12" ????
Date Posted: 25 May 2014 at 8:25pm
I have a design I'm working on that has a 12 + 6.5 + 3x1'' all in one cab to sit above a kick and K1
Date Posted: 25 May 2014 at 8:31pm
130 - 2k
yeah any of those. Just depends on how you like the sound of those drivers
PD121 was never a favourite on mid
Posted By: Avatron
Date Posted: 25 May 2014 at 9:18pm
How would B&C 12PE32 perform in SP12 horn?
Date Posted: 25 May 2014 at 9:21pm
Originally posted by KidCreole KidCreole wrote:
130 - 2k
Clap
Will 90x40 2" flare be compatible ?
Whats HxWxD (mm) ?
Date Posted: 26 May 2014 at 12:16am
yes it's a bit more brighter than the 121 that is a bit on the dull side
Date Posted: 26 May 2014 at 12:35am
130 - 2k
Clap
Whats HxWxD (mm) ?
SP12 is 60 - 30
556mm W x 432mm H
Date Posted: 27 May 2014 at 9:10am
that sounds cool Mikey let me  know how far you get with it might just take you up on that one bro
Posted By: boots-hifi
Date Posted: 27 May 2014 at 11:53am
I use BMS 12n610 + BMS 4550's although I'm going to upgrade the 1" to BMS coaxial.
Date Posted: 27 May 2014 at 12:05pm
very nice
Posted By: corell
Date Posted: 27 May 2014 at 6:21pm
i want to either use BMS4550 or 4590 aswell, could you comment a little bit on why you are changing? ;)
Posted By: knet94
Date Posted: 27 May 2014 at 6:43pm
BMS 4590s are the dogs danglies. 2" easily reaches down to meet 12" cone and 1" gives you all the chio and sparkle you'd ever need.
Date Posted: 27 May 2014 at 7:32pm
I've heard the 4590, good, and maybe enough sparkle for a PA rig, but there's something special about the sound of a 5 way system, with 2446/DE85/CP750 and 4x CP25s above each 2".
Posted By: corell
Date Posted: 27 May 2014 at 9:52pm
so does the BMS 4550 ;)
im aware of both drivers and their pro and cons, i just wanted to ask boots-hifi if he thinks the extra headroom /spl is worth the money , or why he is changing in general ;)
18sound HD1480 would be the compromise between them both...
Posted By: knet94
Date Posted: 28 May 2014 at 12:21am
I'll let Boots give his own opinion but we've both heard both sets of comps together and the 4590s are imo head and shoulders above the 4550.
Date Posted: 30 May 2014 at 4:11pm
BMS 4550 will run down to 800hz, however this is a traid off as it requires to my ears and others involved in my sound system allot of EQ up the top end and fails to reproduce that magical chipping hence the introduction of CP25's etc to the 2" that Lev mentions. The 4590 has the best of both worlds and more, if you have the money invest in a pair otherwise your end up doing what I'm doing and buying twice to upgrade....I may have a few 4550's for sale soon though Wink
Date Posted: 30 May 2014 at 10:05pm
Can't wait to hear it Boots
Date Posted: 30 May 2014 at 10:55pm
Not this side of xmas I haven't got a few spare grand to spend on comps atm!
