Analog loudspeaker management devices
Category: Other Chat
Forum Name: Golden oldies
URL: https://forum.speakerplans.com/forum_posts.asp?TID=87244
Printed Date: 26 March 2026 at 11:31pm
Topic: Analog loudspeaker management devices
Posted By: Turo
Subject: Analog loudspeaker management devices
Date Posted: 14 June 2014 at 1:28pm
Sorry for my english. I don't know if the subject is misleading.
I am asking for older, proven to be good, FOH gear they don't have to vintage. They can be even "lo-fi" but robust and reliable. Is it called FOH: eqs, x-over and time correction etc? Particulary relating to loudspeaker management and they should be analog. This is not a wanted topic. I'm asking for help from those who know about this stuff. I don't have that kind of knowledge, yet..
I have been thinking about replacing my berry dsp with an analog system. I don't know if it makes any sense. At least i would look cooler : D lots of 1U gadgets.
I've had for a while now a dream of vintage rig with all analog system.
Is BSS TCSs analog? Is there some analog time correction units? Should i make them myself, i know there's most of what i need in ESP-pages.. : ) the sound quality might not be that good hah.
Best Regards -Turo
swaeg.net
Posted By: TONY.A.S.S.
Date Posted: 14 June 2014 at 2:22pm
You will find that most all in one units are digital, and you won't find Analogue delay units that are adjustable across the range.
Posted By: audiomik
Date Posted: 14 June 2014 at 2:32pm
Re: "you won't find Analogue delay units that are adjustable across the range"
You can, although they are somewhat few and far between these days.
The Klark Teknic DN 34, used in delay only mode, is a good example. It has dual "Bucket brigade" delay elements in differential mode to reduce noise.
The BBD IC is the SAD1024, datasheet available here:
http://www.datasheetarchive.com/SAD1024-datasheet.html
Otherwise there are numerous Analog crossovers capable of having added EQ
Mik
Edit: add IC type and link
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Posted By: shagnasty
Date Posted: 15 June 2014 at 3:43am
The Berry DSP (I assume DCX) lay waste to most analogue kit the moment you need any delay, Yes a FDS-360 sounds amazing on a physically time-aligned rig, but a TCS is no use for aligning drivers, they were made to align stacks of drivers, a TCS-804/803 was great for rigging delay towers but tag stripping a couple into a fds-360 would make me buy a Soundweb/Omnidrive in seconds...
I have never seen an anoluge LMS, the Turbo LMS-760 was basically 2 FDS-360s and a TCS-804 in box, you could wind the subs off the Flash, but the rest was fixed...
A digital upgrade from a DCX is 10x the cash, a viable Analogue upgrade would be 30x the cash!
Posted By: audiomik
Date Posted: 15 June 2014 at 11:45am
Turo
it appears that the SAD1024 IC is very difficult to find, however a replacement which is available could be the MN3007.
Some useful info here: http://music-electronics-forum.com/t23353/
Good luck with constructing something based on these delay ICs. I did some designs and built a number of delay units based on the SAD1024 back in the 1970's, so PM me if you'd like assistance although my memory of some details may be missing!
Mik
Posted By: Turo
Date Posted: 15 June 2014 at 10:55pm
Thanks for the replies! The quest for analog time correction unit seems really tuff. I have to look into this BBD IC if it's worth a shot. After reading a few posts about it it doesn't seem to have a good reputation about the sound quality. I understand the difficulties of analog time correction and using such with precision : )
Can you name one? Here's what i was looking about: http://sound.westhost.com/project09.htm
of course it doesn't have to be a DIY.
Also analog limiters are of interest and i think this could be easily done as a DIY? 6in 6out limiter unit?
And one more thing how hard is analog phase adjustment?
I'm starting to realize how much these 1U DSPs can do! : D
swaeg.net
Date Posted: 15 June 2014 at 11:00pm
BSS FDS-360 takes EQ cards (eg CD Horn) as well as Frequency cards...
I stand by my comment, Analogue crossover, great, analogue LMS, gonna be a mess!
Posted By: opus jody
Date Posted: 15 June 2014 at 11:11pm
Opus crossovers have delay card slots, & up to 4 parametric eq sections per side.
Old DDA crossovers sound really nice, imo, for very little money.
This guy can't sell it for £100, probably because of the strange crossover point - 14KHz (?!?)
but it's easy to change the components to something more sensible.
http://www.ebay.co.uk/itm/DDA-Audient-DD500-2-Way-Stereo-4-Way-Mono-Active-Electronic-Crossover-/261506745419?pt=UK_Musical_Instruments_Outboards_Effects_MJ&hash=item3ce304444b
Improvised Hardware Music http://vimeo.com/user9389813/videos
Posted By: Turo
Date Posted: 19 June 2014 at 3:22pm
Is Klark Teknik devices good quality?
swaeg.net
Posted By: imageoven
Date Posted: 19 June 2014 at 4:09pm
yes
Posted By: burningbush
Date Posted: 19 June 2014 at 4:10pm
Generally yes, bit better than most. I'm bidding on the £78 one, the two cheaper units are good aswell but Im not on those.WinkLOL
Posted By: Turo
Date Posted: 19 June 2014 at 6:10pm
I'll leave that one alone then : >
Thanks
swaeg.net
Date Posted: 20 June 2014 at 10:40am
Somebody outbid me, so on you go - you battle for it.Thumbs Up
Posted By: Turo
Date Posted: 20 June 2014 at 3:22pm
I was bidding on the DN 70. I thought it could be used as time correction but it wen't for double what i had in mind.
swaeg.net
Date Posted: 20 June 2014 at 3:27pm
The DN34 went for £190 with the postage.  Bit much as it was tatty. If I spy another I'll pm ya, bro.
