Measuring Scoop response.
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=87268
Printed Date: 20 April 2024 at 10:33am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Measuring Scoop response.
Posted By: TONY.A.S.S.
Subject: Measuring Scoop response.
Date Posted: 16 June 2014 at 2:44pm
Rather than let this get lost in the rest of the Razmataz, I thought it would be better to start again. There has been quite a lot of talk regarding how Scoops are measured and what counts and what doesn't. I would imaging that most of us, if not all, are mainly interested in how our particular Scoops fare against others, whether we make them of just buy them for our own systems. The last set of tests I did were on my new 21's and when The Scoop was tested against the Horn cab, it was then time to test with the matching cabs that a customer was going to put underneath them. This was also completed, and quite definite comparative results were easy to read. You may recall I used my Iasys unit for signal and measuring, and the cabs were measured in 5hz steps from 20hz to 120hz. This could be 1hz steps if so desired, but 5hz seems ok. So, this post/thread is all about making this facility available and to see whether it is possible to organise a time in which as many different cabs can be brought together and tested. It doesn't take long to do, so a lot can be done in a few hours. This is purely a frequency response test and there is no music involved. This test would give everyone a good starting point to understand what their particular cab is doing. Everything is recorded, for our records and we each end up with a copy of results for all the cabs tested. This offer may turn out to be a no go, but at least I am trying to do something positive. Feel free to comment.
------------- http://www.facebook.com/tony.rossell.3" rel="nofollow - http://www.facebook.com/tony.rossell.3
Posted By: Earplug
Date Posted: 16 June 2014 at 2:48pm
Sounds good Tony. Let´s see if it can happen.
------------- Earplugs Are For Wimps!
Posted By: jammin75
Date Posted: 16 June 2014 at 2:51pm
------------- feel the vibes !!! "Who Feels it Knows it" Strong like Lion
Posted By: Pasi
Date Posted: 16 June 2014 at 3:29pm
I'm all for it and can do the same measurements to any box that what i do in commercial R&D to give full specs on any cabinet.
Posted By: burningbush
Date Posted: 16 June 2014 at 4:10pm
If someone could plot impedence against frequency, I would be eternally grateful. A really good idea Tony, might stop the he said/she said and give everyone a baseline/bassline they can work from.
------------- music is the message
Posted By: Pasi
Date Posted: 16 June 2014 at 4:16pm
I can do impedance, impedance with phase, THD, waterfall, Impulse response, Phase, Group Delay, Frequency Response. You name it :)
Date Posted: 16 June 2014 at 4:24pm
Keep talking dirty, Pasi, I'm loving it.
Date Posted: 16 June 2014 at 5:52pm
All we need is time and place, I personally don't care where it is. I know this won't happen next week, So we will a consensus on where and when.
Posted By: bee
Date Posted: 16 June 2014 at 7:03pm
sounds like a great idea, and will show what cabs actually do what... and will debunk hype, with actual truth.....
------------- https://www.elements-audio.com
Posted By: KidCreole
Date Posted: 16 June 2014 at 7:30pm
| no no no! we don't need the skies filled with black smoke from all the peeps burning their scoops
Just a simple sweep (hopefully not with a broom)
------------- Mykey Wattco
Date Posted: 16 June 2014 at 7:32pm
| Get ready for some serious excuses from so called builders and why they can't make it
if you can't make it yours scoops are shit
Posted By: Pasi
Date Posted: 16 June 2014 at 7:35pm
Ha ha :p
Which bring to the good point though. Which measurements should be done and with what parameters?
I'd say half space frequency response at 4m distance with 2.83V input and maybe then at 110dB level for THD and larger signal behaviour. Impedance and phase also at 2.83V
I think that would give pretty good comparison points to most of the modern datasheets on pro audio side as well.
Date Posted: 16 June 2014 at 7:39pm
I'd say 2 meters mic touching the floor
most peeps stand 2 meters away from scoops. 4 meters away from SOME scoops you get nothing
Posted By: Pasi
Date Posted: 16 June 2014 at 7:40pm
Oh you...
Make it 2m then, i'm not fussed. As long as it's agreed in advance and everyone is happy with it.
Date Posted: 16 June 2014 at 7:47pm
I'm up for bringing my DubSub (scoop) and my S7 scoop
so put me down
Posted By: bee
Date Posted: 16 June 2014 at 8:04pm
so true, im happy to bring a 24" an 18" even may be able to bring a new neo 18" driver ...
Posted By: bee
Date Posted: 16 June 2014 at 8:12pm
as long as all cabs are measured the same, no eq, etc...
with raw response and a 1/3rd smoothing response....
Posted By: bee
Date Posted: 16 June 2014 at 8:14pm
but would probably be better if all scoops used the same driver... to make all readings mean something.
Posted By: MarjanM
Date Posted: 16 June 2014 at 8:19pm
with raw response and a 1/3rd smoothing response.... |
But you are missing the point. No scoopist use them that way. They include some magic in it that no instrument can measure.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Date Posted: 16 June 2014 at 8:26pm
bee wrote:
but would probably be better if all scoops used the same driver... to make all readings mean something. | Use the driver it was designed for
Posted By: bee
Date Posted: 16 June 2014 at 8:50pm
true, but then your get the x driver sounds better excuse.... maybe use the 1850 as standard driver...
Date Posted: 16 June 2014 at 8:58pm
OK I'm up for that
PD can pay for the venue and lashings and lashings of jam and ginger beer
Posted By: bee
Date Posted: 16 June 2014 at 9:06pm
lol, could use the b&c100 or any other driver v1000, tmax 1500I,
Posted By: Pasi
Date Posted: 16 June 2014 at 9:27pm
MarjanM wrote:
But you are missing the point. No scoopist use them that way. They include some magic in it that no instrument can measure. |
Mate, please. Not in this thread. Not even as a joke.
Posted By: Pasi
Date Posted: 16 June 2014 at 9:30pm
bee wrote:
true, but then your get the x driver sounds better excuse.... maybe use the 1850 as standard driver... |
Up to you guys. I would say use the driver what the box is designed for, just like in reflex or horn loaded cabinets. If someone prefers different sound, it doesn't change the measurement. This is all about what the line on the screen says, not how it sounds like as that is down to personal preferences and nothing can measure those.
Just raw responses, and everyone can draw their own conclusions from them with any refrerence to real application they may or may not have.
Posted By: bee
Date Posted: 16 June 2014 at 9:37pm
im cool with what ever people decide. but we would need a big venue with little reflections or an outdoor location.
Date Posted: 16 June 2014 at 11:17pm
Random Thoughts.
Outdoors would be fine but then dependent on weather.Golden Palace can be hired, but costs £50-75. per hour depending on who's asking. A cab in the middle of the floor wouldn't be so bad at GP due to the size of the room. People will want to compare their own scoops with others, so what ever speaker is in the cab should be it. Decide on the Amp to be used. Not so critical as it will be a level playing field for all cabs. No point in general pink noise across the range as it won't tell where the good bits are. Mic at ear level as it's the only part of your body that will be listening. ( who's ear, you may ask). Scoops of all sizes to be compared. I guess a Sunday would be the best time. Has anyone got a big garden facing a field? My initial idea was a repeat of what I've done already, but a more comprehensive test would perhaps inform people why the cab performs the way it does. If this does happen, and it's up to all interested parties to make it happen, there would have to be a cutoff date for people wanting to turn up, otherwise we will never finalise the testing date. There's probably more, I've got a couple of bottles of Scotch and a couple of JD I can throw in. Perhaps at the end we could all have a Custard Pie fight.
Date Posted: 16 June 2014 at 11:56pm
Outside yours Tony? I can supply the PG/milk and digestives?
Date Posted: 17 June 2014 at 12:31am
Mic at ear level means it will not be comparable to other cab measurements though.
Posted By: bitSmasher
Date Posted: 17 June 2014 at 12:39am
That'd give a consistent null too, wouldn't it?
Date Posted: 17 June 2014 at 12:42am
I have always favoured ear level mic because I think it's important to relate to what we see in the measurements, and we only do that at ear level. The same as you would do at a Gig.Don't forget, this is only supposed to be a comparison test with one cab against another. At the end of the day, that's what people ill want to know. Don't forget, we are talking about the Scoop Bin community.
Date Posted: 17 June 2014 at 1:23am
Maybe, but would it not be better to do an inclusive event that gives measurements that are beneficial to everybody? Unity and all that
Posted By: smoore
Date Posted: 17 June 2014 at 2:27am
As a suggestion I think it would be better to use recommended drivers... Because different drivers produce different SPL's and different sound qualities in different boxes. But then at least you know if you pay £100 more for a driver and it produces more SPL and sounds better you know your paying for that difference. And the tests may well show that cheaper drivers produce better results in the better designed cabinet.. Just my two pence! Also the cabinet will perform as its designer aimed it to
Date Posted: 17 June 2014 at 6:23am
The original idea was to take the measurements one step further than the results that were seen on a previous Graph. People are to bring their cabs with the speaker that they normally use. The cabs would be tested at 5hz intervals and SPL logged. range 20hz-120hz. Each cab done under identical conditions. Depending on how many cabs and time, other things can be done according to what equipment is available. I'm open to anything, as I'm sure everyone is.
Posted By: Pasi
Date Posted: 17 June 2014 at 7:23am
TONY.A.S.S. wrote:
The original idea was to take the measurements one step further than the results that were seen on a previous Graph. People are to bring their cabs with the speaker that they normally use. The cabs would be tested at 5hz intervals and SPL logged. range 20hz-120hz. Each cab done under identical conditions. Depending on how many cabs and time, other things can be done according to what equipment is available. I'm open to anything, as I'm sure everyone is. |
Why not do it with pink noise which gives you the whole response and the SPL numbers? Depending on FFT size you get different resolutions, and for example in normal use i keep it at 0.34Hz or 0.17Hz. This way you can see all the differences in response and maybe see some things which will explain the different sound on different cabinets and drivers.
Posted By: audiomik
Date Posted: 17 June 2014 at 7:41am
would generally agree with Pasi's approach on this in terms of measurement methodology, but using say a minimum 500 line FFT analysis of a maximum of one decade (20 to 200Hz range?) tracked source then a single sweep can be undertaken to acquire: Frequency Response Distortion Phase, both Acoustic and Electrical Impedance ~ using a Current Probe and Constant Voltage drive or to fulfil provision of a suitable Test Amplifier: http://www.bksv.com/products/transducers/acoustic/sound-sources/measurement-power-amplifier-2735?JsEnabled=0
Power Factor of the DUT A four input analyser is easily capable of this.
Given this the testing time for each item is substantially reduced whilst all relevant parameters are acquired
Mik
Edit; add link to test amplifier
------------- Warning! May contain Nuts plus springs, washers, screws, etc, etc.
Posted By: imageoven
Date Posted: 17 June 2014 at 8:57am
As there are a number of people offering testing kit, why not set mics at ground level and at ear level and have two sets of measurements - this wouldn't take any longer to do if there are two operators and it might help to prevent percieved bias when it comes to the post results slanging match. It could highlight intersting differences too.
------------- Keep pushing on, things are gonna get better.
Date Posted: 17 June 2014 at 9:20am
TONY.A.S.S. wrote:
The original idea was to take the measurements one step further than the results that were seen on a previous Graph. People are to bring their cabs with the speaker that they normally use. The cabs would be tested at 5hz intervals and SPL logged. range 20hz-120hz. Each cab done under identical conditions. Depending on how many cabs and time, other things can be done according to what equipment is available. I'm open to anything, as I'm sure everyone is. | Seems antiquated and will take longer
Posted By: Pasi
I got 3 mics, 2 systems so can do multiple points as well ;)
Posted By: rish
Date Posted: 17 June 2014 at 9:30am
I wish I was on that side of the pond to participate. Pasi, i do think Tony wants to use his testing gear to run the tests. Rish
Posted By: Pasi
Date Posted: 17 June 2014 at 9:39am
If he wants, by all means. Nothing stops us from using multiple systems, his and mine for example. If something like this happens, it's worth documenting all the things people want on the same time.
My main measurement takes only 2.5 seconds so plenty of time for the others :)
Posted By: rish
Date Posted: 17 June 2014 at 9:51am
Point taken. I think thats fair. This could be a wonderful opportunity for those participating to expand their knowledge and if the results are posted on here it will give us who are not able to attend an insight as to how the cabs performed. Damn I wish i was near you guys. Rish
Posted By: Nitz V1505
Date Posted: 17 June 2014 at 9:53am
Will music be played? It's all fun running sine waves but a test track played at the end of sweep tests will give indication how each cab sounds. All settings being the same. The methods of conducting the test sound good. If we want more scientific results we'll have to conduct the tests in a anechoic chamber.
------------- LET THE BASS ROLL LIKE THUNDER
Posted By: audiomik
Date Posted: 17 June 2014 at 9:59am
oops, forgot to include Impulse and Two-Tone IMD tests
Mik
Date Posted: 17 June 2014 at 10:05am
Nitz V1505 wrote:
Will music be played? It's all fun running sine waves but a test track played at the end of sweep tests will give indication how each cab sounds. All settings being the same. The methods of conducting the test sound good. If we want more scientific results we'll have to conduct the tests in a anechoic chamber. | You're missing the point
A sweep will give a read out as a starting point for what the scoop can do
You don't need a anechoic chamber. You just need each scoop in the same place every time
If you want to hear a scoop playing you need t get down to GP
If there are buyers attending then I suppose it will need a track being played but will also open up a can of worms as far as what the day/half day is all about
Posted By: snowflake
Date Posted: 17 June 2014 at 10:28am
Mik |
if you used pink noise band-limited to one octave i.e. 40-80Hz wouldn't all the inter-modulation distortion show up as noise below or above this band.
Posted By: pfly
Date Posted: 17 June 2014 at 12:30pm
Anechoic chamber that works between 10-100hz or so needs to have some massive structures. Much, much, much easier would be to go in the middle of a field with no walls or other obstructions closer than 30 meters or so and just work in half space with the speaker and the mic on the ground. Lifting the box and the mic with big crane to 30-40 meter height would work nicely, if full space measurements were required.
Posted By: Teunos
Date Posted: 17 June 2014 at 1:20pm
snowflake wrote:
Mik |
if you used pink noise band-limited to one octave i.e. 40-80Hz wouldn't all the inter-modulation distortion show up as noise below or above this band. |
Yes it would, you will however not be able to properly assess if the products you are seeing are products of IMD or something else. Band-limited pink noise can't be generated infintely steep without ripple. It will also not be possible to assess if the out band peaks are caused by IMD or peaked response of a crossover or the cabinet itself. The easiest way to precisely test for THD, IMD or any other quantity is to do a sweep like pasi suggested. It will reveal THD,IMD, impulse reponse, frequency response, acoustical phase and indeed if a current probe is used electrical impedance as well as electrical phase.
Just make sure the length of the sweep across the band is long enough so that enough samples can be collected for a precise FFT resolution. Just setting the FFT length of your analyser to an exact amount of samples does not mean the result wiil be accurate to this resolution if the number of samples in the input is not adequate.
Would be totally worth it to measure at 2.83V as well as at let's say 110dB at 4m and then compare measured quantities in an overlay.
I have adequate programming skills to quickly write up a few Matlab scripts to post process the results if I were given them in xls, csv or text files or any other comparable extension.
------------- Best regards, Teun.
Posted By: Pasi
Date Posted: 17 June 2014 at 1:46pm
FFT size can be adjusted on the system tuning program i use, but the actual R&D hardware works on different approach and is capable of giving all we need in 2 sweeps without anything extra. Built in amp, senses the impedance via amp out etc. Clever bit of kit.
Posted By: levyte357-
Date Posted: 17 June 2014 at 9:17pm
Nitz V1505 wrote:
Will music be played? It's all fun running sine waves but a test track played at the end of sweep tests will give indication how each cab sounds. |
How dare you request music played through Scoops, to hear how they sound !?
------------- Global Depopulation - Alive and Killing.
Posted By: jammin75
Date Posted: 17 June 2014 at 9:40pm
Date Posted: 17 June 2014 at 11:02pm
I've been in Comunicado since the early hours, and have only just got back to this. As regards testing, I'm up for anything that will give us some relative info. I could only talk about my own testing method, which is enough to show you what the cab is doing Frequency wise at 5hz intervals (or any interval). When this was last done, conclusive comparisons were obtained. I can understand the Boffins suggesting more and that is understandable, but whatever makes it worth while and gives us info we can all relate to. A word about the music, or two actually, not necessary.
Date Posted: 17 June 2014 at 11:13pm
TONY.A.S.S. wrote:
A word about the music, or two actually, not necessary. |
Date Posted: 17 June 2014 at 11:16pm
I only want to hear a kettle whistling, a few pink noises and a bit of piece and quiet
Date Posted: 17 June 2014 at 11:21pm
No Pink Noise I'm afraid, only sine wave. Not staying for the custard pie fight after it's all done then.
Posted By: Mark James
Date Posted: 18 June 2014 at 1:12am
take it this is only open to scoops? r would people at a later date be up fr a similar sesion with other types of cabs? i could bring the modded lab18 if anyone wants t measure it should have a few soon
------------- me so horny me love you long throw horn loaded for her pleasure
Date Posted: 18 June 2014 at 7:13am
If there are buyers attending <img src="smileys/smiley3.gif" alt="Shocked" title="Shocked" /> then I suppose it will need a track being played but will also open up a can of worms as far as what the day/half day is all about
The anechoic chamber bit was a sarky suggestion. This is why I said if you wanna get more scientific about it. Capiche. Mykey I'm not missing the point as hearing the same tune on each cab will tell us how the cab sounds. Which just happens to be the fundamental point of a speaker cab. Graphs and data are all good but how many times have you seen figures for a speaker which look great but in reality sounds shite?
Date Posted: 18 June 2014 at 7:16am
levyte357- wrote:
<img src="http://4.bp.blogspot.com/-D8p49RtVx0Y/T2KdfBLjgJI/AAAAAAAAPg8/fJW1wEkMVeo/s1600/Old%2BFart%2B01.jpg" height="480" width="484" />
How dare you request music played through Scoops, to hear how they sound !? <img src="http://forum.speakerplans.com/smileys/smiley36.gif" alt="LOL" title="LOL" />
Posted By: pfly
Date Posted: 18 June 2014 at 7:46am
While it is true that in the end it is the sound we hear that matters, I would see the point of this possible session to be getting as much of pure data as possible. Listening to the boxes brings many new questions (played with midtop? upper bass? processing? mating to those other boxes?) and will take time, or then it isn't done in a way that satisfys anyone. Purely "scientific" way is the way forward here. Listening session some other time. Or that's the way I see things at least.
Tony as much as I respect you, I would not bother taking out your machine. Maybe as a backup yes, but Pasi obviously has system that makes pretty much everything that's needed and more, and his gear will make it really, really fast and more accurate.
Date Posted: 18 June 2014 at 7:53am
if you read about what the Iasys does, you will realise that for my original suggestion, this would be as accurate as anything else, and it's what I use, and have done for a number of years, but on these Forums we can't expect things to be accepted at face value can we. Nothing seems to be that simple.
Posted By: Pasi
Date Posted: 18 June 2014 at 8:53am
Seems to work again...
Yes, wrote a loong reply and then this stupid forum software did it's trick and didn't allow to post it...
Tony: I don't mind using your Iasys as well. I just thought it would be beneficial to do same measurements than what i do on everything else as well, to give wide range of info and comparable results and future additions are then easy and reliable.
And why not pink noise?
FR with pink noise:
Another sub, sine sweeped response:
THD on one top cabinet @ 110dB SPL
And decay times...
In my view any kind of cabinet is welcome to this measurement session. More the merrier and wider database for the future. And to some "wise guys", no we are not trying to "see how it sounds". Pure technical measurements to show the differences between technical aspects on different designs and loading techniques.
Date Posted: 18 June 2014 at 10:06am
Pasi, my friend, as I said a while back, I am happy for anything that with advance the cause. I suggested this event because I thought it would help. I don't see it as my Gig, but I will do what ever it takes to help make it happen. The next stage is to agree on a venue and if everything else goes to plan we will need to know who's coming and what to do about cost for the venue if applicable. This could take a little time, but we have to make a starting point, otherwise nothing will get done.
Posted By: pfly
Date Posted: 18 June 2014 at 10:16am
TONY.A.S.S. wrote:
if you read about what the Iasys does, you will realise that for my original suggestion, this would be as accurate as anything else, and it's what I use, and have done for a number of years, but on these Forums we can't expect things to be accepted at face value can we. Nothing seems to be that simple. |
I've been looking at it earlier and while I would personally love to have that tool at my disposal, in this application I'd prefer computer based systems that can output graphs into digital realm more easily, such as Systune, Smaart, Fuzzmeasure or the system Pasi uses that seems to collect quite an amount of data in a very short time.
While Iasys seems to be quite nice machine, have I understood correctly that to get frequency response measurement you need to do a series of sine wave measurements and build graph out of them? So the accuracy of those measurements depend on how much time you want to put into doing them? When doing a series of measurements like this (10? maybe 20 boxes?), the difference of spending 5 minutes or 5 seconds per box listening to test tones comes somewhat substantial.
I am sorry if I am offending you in any way I am sure Iasys works for you really nicely, I am just thinking of conveniency of measuring and data publishing. Then again, it is quite likely I won't be there so it doesn't really matter that much what I say...
Posted By: pfly
Date Posted: 18 June 2014 at 10:28am
Distortion and waterfall figures will tell us quite a lot about box performance and why it sounds like it does. Those would seriously interest me. Impedance figures would tell us about loading, tuning and would answer questions about amplifier matching.
Date Posted: 18 June 2014 at 11:01am
No one offends me, it's not actually a matter of life or death is it. I only look and listen with interest.
Posted By: Pasi
Date Posted: 18 June 2014 at 11:04am
So, when and where? I guess somewhere close to London as that's where majority of the cabinets to be measured might be? Open field or a parking lot would be the best place or a massive old factory hall.
Date Posted: 18 June 2014 at 11:11am
| Whats this cab then ?
Date Posted: 18 June 2014 at 11:15am
Another thread should be called , with response graph
'Name That Cab'
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Posted By: Masai
Date Posted: 18 June 2014 at 1:51pm
Bloody hell!!! Why does something like taking some measurements seem to be made more complicated by people who just want their egos massaged?!?!?
Mr A.S.S already stated he had start AGAIN so we (you lot) can get on with the simple task of taking some audio measurements of scopes - simples! Instead we have grown men (?) saying don't bother bring your measuring equipment because my one is better, put the mic hear and not ear , to pink or not to pink should not be the ultimate question and music..... Remember that?
Imagine a group of car enthusiasts testing their chipped up, quad exhaust complete with steroid injected body kitted cars and testing them out on a rolling road - then towing their pride n joy back to it's parking space - without getting behind the wheel and driving it!! Madness!!
Why don't you just all:
* Agree on a venue * You can bring your own test equipment - Whether that comprises of an old Realistic SPL meter, an AP rig or a laptop with some Prism converters (remember those lovely old Bruel & Kjaer units?) is up to you. * Post up results stating the conditions of the test, what cab and which speaker was used. Obvious I know but this is Speakerplans after all... * Music! I know the mjarity of people who posted here have said nay but just think about it.... If you are the cabinet builder it would give you a chance to add the ideal mid and tops combination (stick to 3 way as would it be fair to say a bass cab should be able to show what it can do in this format?) The music selected should be down to the cab builder to show what their system can do. With their permission others can bring their music material and 'test' the boxes with source material they are use to so that they can evaluate for their use by the old fashion method - listening. The proof of the pudding is in the eating after all..... The cab builder should bring their own amp rack to show off their cabs.
Yes I know the music is the X factor that can upset the apple cart because you all just want to record some data about scopes so maybe you will leave it out.....
If this all goes well you could conduct the tests in field somewhere in the future. These are just my suggestions of course. I hope this isn't throwing the cat among the pigeons but I think some of you need to take a deep breath, count to ten - and if it makes you feel better - click your heels three times. I know that this is meant to be a scientific sound off but with out that much effort you lot can do so much more if just stop bickering like my daughters! In fact you're worse then them!!
I'm just so glad I don't encounter this on the pre-amp forums!! We are a much more civilized bunch
Just don't get your y-fronts in a twist. It's only speaker cabs.
Over to you in the SP stuido!!
------------- Facebook: Masai Judah
Date Posted: 18 June 2014 at 1:54pm
not so smart on the pre-amp forums then?
Posted By: Pasi
Date Posted: 18 June 2014 at 2:29pm
Masai wrote:
I know that this is meant to be a scientific sound off but with out that much effort you lot can do so much more if just stop bickering like my daughters! In fact you're worse then them!! |
See that's your problem right there. This is not a sound off. Totally different thing, not interested in a slightest sense in this occasion how something would sound because it would end up to hell of a lot of excuses thrown in to all directions. Just reading these threads makes that so plain obvious.
Again, back to the point.
When & Where?
Posted By: audiomik
Date Posted: 18 June 2014 at 4:04pm
Pasi To quote Pfly: "Impedance figures would tell us about loading, tuning and would answer questions about amplifier matching."
As well as Impedance vs Frequency plots, can you plot VI Phase Angle (electrical) vs Frequency which is also a very important part of Amplifier matching in terms of it's true load?
This relates directly to Amplifier Output Load lines
Mik
Posted By: Teunos
Date Posted: 18 June 2014 at 4:08pm
Normally this should be easily possible when using fft and a current probe. Again, if somebody would be collecting the data, i could do the post processing to make all the results viewable and understandable, if that is something people would like.
Posted By: Pasi
Date Posted: 18 June 2014 at 4:18pm
Mik |
Something like this?
Posted By: audiomik
Date Posted: 18 June 2014 at 4:33pm
Pasi looks familiar
Many Amplifiers are designed for worst case 45º VI Phase angles, some cope with up to 60º.
Looks from your graph that there might be 60º on your 'black trace' so a 0 to +/- 90º scaling would be really useful
Mik
Date Posted: 18 June 2014 at 6:19pm
Pasi I'm touched. A track called Pure and clean by Alpha and Omega played on each cab for 30 seconds will reveal if the cabs cut the mustard. You wouldn't even need mids n tops.
Posted By: Sypa
Date Posted: 18 June 2014 at 6:58pm
This all started from pd1850 cant do 40hz right ? Pure and clean lowest note is g1 49hz.
Date Posted: 18 June 2014 at 7:36pm
Nitz V1505 wrote:
Pasi I'm touched. A track called Pure and clean by Alpha and Omega played on each cab for 30 seconds will reveal if the cabs cut the mustard. You wouldn't even need mids n tops. |
Nitz!!! You again !? Already told you..
Stop recommending people play music thru Scoops, to hear how they sound.
That is only for Reggae & Scoop lovers.
Date Posted: 18 June 2014 at 9:52pm
Thought I'd put this up again to show the thinking behind all this. I had measured the 1850 cab which contained a PD1850 speaker. The results shown indicate what the difference was between them. This is what I thought people might be interested in when applied to their own cabs.
20 25 30 35 40 45 50 55 60 65 70 75 80
SLO21H +5 +6 +8 +9 +6 +3 +1 0 +1 +2 +2 +1 +1
SLO21S +11 +13 +13 +7 +2 -1 -3 -3 -2 +1 +2 +2 -1
Posted By: sn95
Date Posted: 18 June 2014 at 9:56pm
I personally love scoops.and have enjoyed the last two days reading on the topic.and would love to see so reading ,charts.now let me get back to listening to my scoops and enjoy the music
Date Posted: 18 June 2014 at 10:25pm
TONY.A.S.S. wrote:
Thought I'd put this up again to show the thinking behind all this. |
Tony, I gather some would welcome your objectives.
However the reality is, the vast majority of Reggae Soundsystems do not operate their scoops with no eq, they use pre-amps or some type of bass boost, and test Scoops with music.
They are not interested in cab response without eq, and tested with pink noise, because that's not how they'll be played. Seems strange the premier supporters of measuring Scoop responses, without eq, or want to see graphs, or are more interested in the theory, than the cab playing music, are people who don't go to Reggae gigs, or would ever operate a Scoop sound system.
Posted By: pfly
Date Posted: 18 June 2014 at 10:53pm
However the reality is, the vast majority of Reggae Soundsystems do not operate their http://rover.ebay.com/rover/1/711-53200-19255-0/1?toolid=10029&campid=CAMPAIGNID&customid=CUSTOMID&catId=293&type=2&ext=161339656242&item=161339656242" rel="nofollow - scoops with no eq, they use pre-amps or some type of bass boost, and test http://rover.ebay.com/rover/1/711-53200-19255-0/1?toolid=10029&campid=CAMPAIGNID&customid=CUSTOMID&catId=293&type=2&ext=161339656242&item=161339656242" rel="nofollow - scoops with music. |
I think there is quite a lot more in scoops than "just" this. I have used mine with success in vast majority of gigs. Most of them have been some sort of reggae/dub/dancehall whatnot, but I have done quite a lot of live stuff, even death metal with them and most people have been really happy with the results. The few times I've taken the rig out just for myself and friends to play on, it's been quite strictly only music originated from Jamaica. I'd say about half or two thirds of my record collection is some sort of reggae, more and more of dub.
"pure" frequency response combined with waterfall plots, impedance plots, distortion plots, phase plots and all that would give us more solid foundation on how this rather interesting deviation of horn loading behaves, why and how it does what it does and for example why it is such a difficult load for amplifiers in some cases.
Measuring pure data of boxes themself with no processing what-so-ever does not mean they should be used in such manner. Measuring pure data is to proggress, help people to understand things and phenomena that our "tools of trade" are based on. Measuring pure response is only one piece of the whole picture, but quite important at that, at least for me.
I base my interest on pure admiration of this design, how suprisingly complex it is, how it performs, how it sounds and also on my admiration of the cultural context it is most used. My point of view is just being curious on how things work. Scoop bin is quite easily the most fascinating bass box for me.
edit: I missed the sound of those stupid boxes so much I had to drag two out of our storage pile to the other end of lockup to replace my 12" reflex proto on our lockup system I'm still working on our MT121s here btw...
Date Posted: 18 June 2014 at 11:58pm
Lev, the whole point of this is to show how good the cab is, not what kind of sound a person might prefer, or music for that matter. It's a question of suppling the tools for the job. If other things get introduced regarding music, eq, preamps etc, the test would be about those items or methods, and wouldn't tell you much at all about the cab. Whether a person needs or wants to crank up 6-9db at 40hz would be of little interest at this stage. There are a lot of suspect sounds around, bass thats gets overloaded, mids that aren't very clear etc. I think this happens because don't understand what is happening, or the short falls, if any, of their cabs. what you mention already happens at GP. So what would be the point.
Date Posted: 19 June 2014 at 12:09am
They are not interested in cab response without eq, and tested with pink noise, because that's not how they'll be played. | Art and Science should coexist, and you can have greater appreciation of one by understanding the other
Date Posted: 19 June 2014 at 12:22am
Before you can power slide or drift in a car you need to know what the car is capable of.....e.g. maths
Posted By: MarjanM
Date Posted: 19 June 2014 at 12:39am
Lev, wouldn't knowing exactly at which frequency you can safely apply eq help in getting YOUR sound out of the scoop? People that knows how to read graphs dont actually need to hear the box to have an idea what the box can or cant do.
Date Posted: 19 June 2014 at 12:41am
MarjanM wrote:
People that knows how to read graphs dont actually need to hear the box to have an idea what the box can or cant do. | well i didn't want to say it without being shot down or being told i'm out of order
Posted By: MarjanM
Date Posted: 19 June 2014 at 12:47am
Well i am called many names so why not risk it again :-)
Date Posted: 19 June 2014 at 7:47am
Sypa wrote:
This all started from pd1850 cant do 40hz right ? Pure and clean lowest note is g1 49hz. <img src="http://forum.speakerplans.com/smileys/smiley4.gif" alt="Big smile" title="Big smile" />
Ever heard of harmonics? Also the bass drum drops low.
Posted By: Joe Grime
Date Posted: 19 June 2014 at 8:01am
http://djfrobot.blogspot.co.uk/2010/04/eq-frequency-chart-for-instruments.html
Posted By: +/-3dB
Date Posted: 19 June 2014 at 9:59am
In
this case, there are at least two groups of stakeholders - designers (tony,
pasi, marjan, mykey etc) and end-users/customers (soundsystems).
R&D
people will probably use different criterias to evaluate whether a product
under development is fit for purpose,
while the end users will judge if the finished product is fit
for use based on other criterias.
One
should understand what purpose and which party the measurements can serve.
Date Posted: 19 June 2014 at 11:26am
Surely the purpose of measuring the scoops without eq is to help ascertain any areas where cabinets are lacking in frequecy response to allow design improvement of the scoop. This would help negate the need for additional eq boost, and improve system efficiency to suit the style of music being played.
Date Posted: 19 June 2014 at 11:30am
Nitz V1505 wrote:
Ever heard of harmonics? Also the bass drum drops low. |
http://i.imgur.com/hhVEFCt.png" rel="nofollow">
More detail:
http://i.imgur.com/JJFcaf4.png" rel="nofollow">
Date Posted: 19 June 2014 at 11:35am
Joe Grime wrote:
Surely the purpose of measuring the scoops without eq is to help ascertain any areas where cabinets are lacking in frequecy response to allow design improvement of the scoop. This would help negate the need for additional eq boost, and improve system efficiency to suit the style of music being played. | Yep. One that is good at 40hz and doesn't drop off well before 40hz
Posted By: Sypa
Date Posted: 19 June 2014 at 11:39am
Bass drum peaks around 63-ish hz but i must admit it sounds lovely.Yeah i heard about harmonics but still not a good track to test really low response as 40 to 30 hz is almost 20db more quiet than 49 in the song.But dont get me wrong i love scoops and the sound they make,and in majority of dub/reggae music in real life they dont need to drop really low as the bass content is all around 43-60 in about 9 of 10 songs. 30hz is overrated anyway.And in no way im taking sides here and saying they cant do below 40 :) . Source for frequencies foo musical spectrum.If you have foobar a lovely addon.
Date Posted: 19 June 2014 at 11:53am
Looking at those graphs, which always look impressive, would you be easily able to tell at a glance, at 45hz whether cab A was better than cab B, C, D, etc?
Posted By: Teunos
Date Posted: 19 June 2014 at 12:19pm
Indeed a wonderful tool, have used for almost three years now. You want to hear a track with low sub bass, Ivan Gough &Jebu, Kukatu. Flat out to 31Hz dirty electronic bass. http://s195.photobucket.com/user/teunvanderveeken/media/Kukatu_zps5e902492.png.html" rel="nofollow">
Date Posted: 19 June 2014 at 12:33pm
Teunos wrote:
Indeed a wonderful tool, have used for almost three years now. You want to hear a track with low sub bass, Ivan Gough &Jebu, Kukatu. Flat out to 31Hz dirty electronic bass. <a href="http://s195.photobucket.com/user/teunvanderveeken/media/Kukatu_zps5e902492.png.html" rel="nofollow"><img src="http://i195.photobucket.com/albums/z159/teunvanderveeken/Kukatu_zps5e902492.png" /></a> |
How about Lorde - Royals? Not one you might expect but very, very strong 35Hz.
http://i.imgur.com/Rce7q4b.png" rel="nofollow">
Date Posted: 19 June 2014 at 12:36pm
Here's Kukatu for reference, louder peaks but there's a big bit of the tune where there's no real bass!
http://i.imgur.com/W8pQffD.png" rel="nofollow">
Posted By: pfly
Date Posted: 19 June 2014 at 12:54pm
Toasty unfortunately I don't have better version at hand but where does this one hit? I'd say this is quite close to deep stuff that you hear at roots/dub events. I suspect lowest notes are somewhere around 35-40hz range.
Bass dropas at 1:15
https://www.youtube.com/watch?v=2JY55GIyFHM" rel="nofollow - https://www.youtube.com/watch?v=2JY55GIyFHM
