Danley DTS-20 plans
Category: Plans
Forum Name: Plan Requests
Forum Description: All plan requests here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=89118
Printed Date: 27 March 2026 at 8:46am
Topic: Danley DTS-20 plans
Posted By: audiophile.1963
Subject: Danley DTS-20 plans
Date Posted: 17 October 2014 at 12:35pm
Hi, I'm looking for the Danley DTS-20 plans construction and for the name of the woofer inside, someone could help me? Thanks for all
Kind regards
Giuseppe
Posted By: Twiggy
Date Posted: 17 October 2014 at 2:06pm
Lol
Posted By: all bass
Date Posted: 18 October 2014 at 12:29pm
Kind regards
Giuseppe
This nice guy named Thomas will be able to answer all your questions. You can find his phone number on his website: http://www.danleysoundlabs.com/about-us/contact/" rel="nofollow - Tom the speakerguy
Posted By: _djk_
Date Posted: 21 October 2014 at 2:40am
See the patent and use  the LAB 12 driver.
djk
Posted By: bitSmasher
Date Posted: 21 October 2014 at 2:48am
Tom's pretty good, but nowhere near as helpful as that Tony guy from another company
Posted By: snowflake
Date Posted: 22 October 2014 at 2:28pm
google images has some drawings on it. as said use the Lab12 driver or if you use a lower q driver redesign so it is closer to the mouth.
Posted By: _djk_
Date Posted: 22 October 2014 at 11:27pm
"google images has some drawings on it"
The patent has some good drawings, that and with the external dimensions from the data sheet he should be able to figure it out.
djk
Posted By: _djk_
Date Posted: 25 October 2014 at 9:21am
http://s56.photobucket.com/user/dkleitsch/media/dts20inside.jpg.html" rel="nofollow">
Details of the damped 1/4W stubs and woofer inductor.
djk
Posted By: mini-mad
Date Posted: 25 October 2014 at 2:01pm
Do those two ports have different IDs?
And whats with the damping choke?
...i know we are being silly here but still wouldnt mind knowing
Posted By: MattStolton
Date Posted: 27 October 2014 at 8:09am
Whilst no one is looking, I will try and be serious for a second - choke changes Le for the driver, can help to smooth out a lumpy plot, particularly on Tapped Horns. It is in Hornresp as a data input, load up a generic TH (martinssons data for HR is readily available), and make some changes to the Le Value, and see what it does.
Yes different diameter pipes. Again bang the numbers into WinIsd, and see how this effects A.N.Other box's response, and you start to get a feel for how genius bits of Danleys designs are. Lots of little subtle changes all kind of come together - art meeting with science.
(He told me, if I kissed his arse enough, he would give me the plans.....)
Matt Stolton - Technical Director (!!!) - http://www.wildingsound.co.uk" rel="nofollow - Wilding Sound Ltd
Posted By: KidCreole
Date Posted: 27 October 2014 at 12:09pm
He sells kits I believe
Mykey Wattco
Posted By: DMorison
Date Posted: 27 October 2014 at 1:25pm
They stopped that after a while, apparently they were getting too many support requests and complaints from under-experienced builders who didn't realise the work they needed to put in to make the things work well, which wan't what the company wanted to be putting their time & effort into.
