would 18sound 12mb700 work?
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=89147
Printed Date: 27 March 2026 at 12:38am
Topic: would 18sound 12mb700 work?
Posted By: C-Audiofreak
Subject: would 18sound 12mb700 work?
Date Posted: 19 October 2014 at 8:08pm
hi guys when i build these cabs i'm thinking of using 18sound 12mb 700 as the suggested units would these be any good as the spec on the website states its ideal for horn loading and it will go in a small enclosure from 10-80 ltr's and i made the enclosure for the 12's in this cab approx 19l these units are also very high efficiency so if i start by building one pair of these to go with one pair of x1 and one pair of es18 bph kicks i will then know if i will need to build a second pair of everything.
Also how many folk would this rig cater for outside? ie 4, X1 4 ,ES18 4, MT122 if set up and driven correctly?
Posted By: cravings
Date Posted: 19 October 2014 at 8:58pm
http://www.speakerplans.com/index.php?id=faq10" rel="nofollow - http://www.speakerplans.com/index.php?id=faq10
there's some good info in the faq.
this one may also be of interest to you.
http://www.speakerplans.com/index.php?id=faq3" rel="nofollow - http://www.speakerplans.com/index.php?id=faq3
Posted By: Mark James
Date Posted: 23 October 2014 at 9:37pm
im pretty sure you want alot less than 19 litres for the rear chamber on the mt122 horn, pretty sure less than 1 litre is ideal [the suggestion of 10-80 litres is usualy for a reflex cab] il have a look at the t/s tho, if they are within say 10% differences from the pd123er or other known good drivers in this cab then it wil PROBABLY work as well
insert silly sentence here
