amping
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=8941
Printed Date: 27 March 2026 at 9:35am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: amping
Posted By: jozoraz
Subject: amping
Date Posted: 04 March 2007 at 3:34pm
my plan is to build 4 cabinets. i will use the void v18-1000 driver. what kind of amplifier would you recommend. how woud you connect them (parallel/serial) !?
i was thinking about the void infinite7, connecting 2 speakers in parallel on each side. is that enough power ? what you think?
here are some specs:
http://www.voidaudio.com/product_detail.asp?id=31 - http://www.voidaudio.com/product_detail.asp?id=31
thanks for any opinions
Posted By: unclejam
Date Posted: 04 March 2007 at 8:16pm
yeah thatle do the job sommin good
Posted By: gingerbiscuit69
Date Posted: 05 March 2007 at 7:14am
the more power you can afford from a quality amp the better. Inf 7/8 would be perfect.
Posted By: Verr
Date Posted: 06 March 2007 at 4:11am
I've heard 4 1850 horns with V18's powered by an Infinite 8. This ran at a contolled 4ohms and it sounded awesome. The Inf 8 is more ideal as the 7 would be put under abit of strain
Posted By: Fushion Julz
Date Posted: 07 March 2007 at 6:10am
I run 4 PD1850s from an Inf 8...plenty of power and headroom...
The Inf 8 is a superb bass/sub amp...not all that subtle or detailed for mids, but for running PD1850 horns it is superb!
------------- FUSHION SOUNDSYSTEM
http://www.fushion.org.uk - www.fushion.org.uk
Date Posted: 07 March 2007 at 9:47am
i doubt an amp with that sort of power is meant for anything other than sub/bass anyway! proper overkill on mid ect whatever your rig size!
