15" Planar wave horn
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=89725
Printed Date: 27 March 2026 at 7:16am
Topic: 15" Planar wave horn
Posted By: Fatinator
Subject: 15" Planar wave horn
Date Posted: 02 December 2014 at 4:33pm
Hey!
I have looked around for a cheap per db, lightweight, easy to build kickbin to work with my void loaded X1 subwoofers and alone. And I think planar wave horn might be the easiest way to go..
So I modelled a 15" one because the 18" plans out there don't have the kick im looking for and they are too big.
It's a 56,5 liter ported to 45hz kind of horn loaded with eminence kappalite 3015LF..
Total voume is around 160L. And outer dimensions about 42x42x97cm
It should work alone without subwoofer for some partys with music that don't need sub bass.
Do you think this will work or did I do it wrong?
Im new to hornresp and not sure if this works in reality..
Here is a picture, everything is calculated with single cabinet and 2pi, more cabinets provide more low end and flatter response to 70hz.
I hope this is in the correct forum section..
Large picture: http://i60.tinypic.com/2r22og3.jpg
// André
Posted By: KidCreole
Date Posted: 02 December 2014 at 10:26pm
Like it
always love the sound of the PlanerWave
Mykey Wattco
Posted By: all bass
Date Posted: 02 December 2014 at 10:29pm
I see you are simming your kicks in halfspace. Unless you are planning to put them on the ground i would think 4 Pi gives a more realistical simulation.
Date Posted: 02 December 2014 at 10:53pm
Hmm I will use them on the ground.
I changed the volume to 85L and port to 50cm. Total Volume is increased to 170L.
It gave a better lower and higher end in both 4Pi and 2Pi, it will also be easier to build.
Do you think 15mm birch ply is thick enough for these cabinets?
18mm is very rare and expensive here in sweden..
85€ is the cheapest i have found so far, and they aren't very big hehe..
Date Posted: 02 December 2014 at 10:58pm
15mm is ok. My TFR kicks are 15mm
Mykey Wattco
Posted By: corell
Date Posted: 02 December 2014 at 11:06pm
would like to see the impulse response of this one, if thats possible?
Date Posted: 02 December 2014 at 11:17pm
Here is impulse response: http://i60.tinypic.com/2w66lhc.jpg
And here is frequecy response with 85L chamber: http://i61.tinypic.com/20jhuv.jpg
Posted By: corell
Date Posted: 02 December 2014 at 11:38pm
please go for the 85l chamber with shorter port then!
Date Posted: 02 December 2014 at 11:46pm
Yes, will do hehe
It seems to work better with other drivers too Big smile
Oberton 15B450, Faital 15FH500 and kappalite 3015(non-LF) seems to give about same response but with a little less 70hz spl :)
Date Posted: 03 December 2014 at 3:25am
I did some more accurate calculations on the box, It's barely any different from 85L version.
101db SPL from 70hz to 183hz, for a completely flat response down to 65hz four needs to be used, however it looks like it loose a bit kick and it starts to roll off already at 130hz.
In singles: 64-188hz (-6db) 125db continous, 132db at xmech 127 continous from 70hz.
In pairs of four: 45-180 (-6db) 136db continous,141db at xmech, 140 continous from 70hz
But the amout of power needed to reach these sound pressure levels would probably burn the voice coils.. And remember, this is just calculated, I don't know how they sound in reality.
Box size: 48*48*100cm
port area: 96,53125cm2*4 (four 48/50*22,65 sheets (21,15cm in middle 19,65cm inner, 45 degrees cut)
port area: 386,125cm2
Total port area(inkl wood/sheets): 513,025cm2
Horn area: 1511,75cm2
Enclosure volumes: box: 92,1375L, horn: 75,5875L, port: 19,30625L combined: 94,89375L total:187,03125L
Total front area: inner dimensions: 2025cm2 outer dimensions: 2304cm2
Total volume 230400cm3 = 230,4L
Cut pieces:
100*48cm(Top/bottom sheet)
100*48cm
100*45cm(left/right sheet)
100*45cm
2,5*45cm(top/bottom acess panel bracket)
2,5*45cm
2,5*40cm(left/right acess panel bracket)
2,5*40cm
45*45cm(speaker baffle)
45*45cm(acess panel)
10*45cm(box reinforcement front and inside)
10*45cm
10*45cm
10*45cm
48/50*22,65cm(port outer point-to-point, 21,15 middle/average point)
48/50*22,65cm
48/50*22,65cm
48/50*22,65cm
Total sheet usage:29223,8cm2
sheet size: 15x1220x2440mm
total sheet area: 29768cm2
Feel free to try it out if you want, but I think it needs more work to reach higher SPL 1w/m..
Edit: If chamber is 10cm shorter/20L less , it will have about 1db more at 70hz at the cost of some low end and more group delay at 70hz. :)
