X15 cut list
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=92302
Printed Date: 26 March 2026 at 8:16pm
Topic: X15 cut list
Posted By: mailk
Subject: X15 cut list
Date Posted: 09 June 2015 at 11:43am
I wanted to build this cabinet, but i couldn't find the cut list for it.
So i decided to make my own and share it if someone needs it:
(I built it myselft with theese plans.)
18mm thick material.
Back panel:
Front panel:
Inner panels:
Side panels(x2):
Top-Bottom panels:
Posted By: mini-mad
Date Posted: 09 June 2015 at 12:20pm
..aaaaaaaaand the recommended drivers for YOUR cab?
Posted By: mailk
Date Posted: 09 June 2015 at 12:32pm
http://www.speakerplans.com/index.php?id=x15
Posted By: DMorison
Date Posted: 09 June 2015 at 7:29pm
First up, thanks for sharing - so many people just come and ask for stuff so it's good to see someone doing it the other way round Thumbs Up
Mini-mad's point is that the original drivers haven't been available for several years, so unless you're very lucky and find a replacement with very similar T/S parameters, then at least one panel (the port shelf) will need to be different to ensure the right tuning for whatever driver you do end up using.
(The current P.Audio series of drivers with similar model names to the originals have very different parameters so should not be trusted to work as-is.)
HTH,
David.
Posted By: mini-mad
Date Posted: 09 June 2015 at 7:50pm
...cheers! what he said Embarrassed
Posted By: mailk
Date Posted: 11 June 2015 at 1:57pm
I just had two cheapo speakers lying around for years and i wanted to do something with them, so i started to search for a plan.
I found the x-15 and i started to play with it and the speakers in WinISD. It seemed to fit quite well. (ofc. you have to adjust the port frequency)
They sound decent enough.
So i cant really recomend drivers for it.
It seems my drivers are out of production as well. old ones...
Posted By: DMorison
Date Posted: 12 June 2015 at 12:32pm
Then it's all good, thanks for sharing.
Posted By: ali4994
Date Posted: 17 August 2016 at 11:02pm
Did you cut from standard sheets of 244x122? If so, how many sheets do you need for one cab? Or even how many cabs out of one sheet, should that be the case
