kkk
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=929
Printed Date: 27 March 2026 at 12:38am
Topic: kkk
Posted By: tthorsten
Subject: kkk
Date Posted: 17 November 2004 at 11:51am
kkk
www.tb-audio.de
LEVELchek www.levelcheck.de
SPL tracking
SATlive www.satlive.audio
best Measurementsoftware for Live People
DBlimits
www.dblimits.com
Isemcon EMX7510 measurment Microphon
Posted By: Dom
Date Posted: 17 November 2004 at 7:28pm
Not got any measurement data saved, sorry.
As for SPL, I personally don't see any real reason to know what the SPL is.  It's either loud enough or its not, it either sounds good or it doesn't, anything else is just dick waving.
Personally I think they are loud enough.
Posted By: norty303
Date Posted: 17 November 2004 at 7:32pm
I'd still like to know tho....
*waves dick enthusistically*#
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: norty303
Date Posted: 17 November 2004 at 7:34pm
Actually, what the calculated extension and increase in SPL when you have multiples?  Is it generally the same for all horns or is it specific depending on throat shape, etc.
e.g. will 2 HD15's go 3db louder and 5hz lower than 1?  How is this worked out?
Posted By: tb_mike
Date Posted: 18 November 2004 at 3:08am
Well what seems to happen is that the spl is raised by +6db,even the lows ofcourse. Eventually with enough units,you maybe getting some lows that are a more useful level. I would imagine that 8would be loud enough indoors
Posted By: mobiele eenheid
Date Posted: 18 November 2004 at 11:24am
You will get 3dB increase by doubling the power. And 3 dB increase due to the summing of the lower frequencies. But only within the length of a quarter wavelenght
If the speakers in the cabs are for instance 0.5 mtr apart, the maximum frequency that will be maximal summed, is 343/0.5/4 = 171,5 Hz. Between 171,5 and 343 Hz there will be increase aswell as decrease depending on thewavelenght of the frequencies.
This is why a stack will give 6 dB per doubling of speakers, but doubling of the stacks will give only 3 dB increase (if placed around 3 mtr or more apart).
Posted By: JD01
Date Posted: 19 November 2004 at 12:51am
This rule only applies as long as the driver can push the air w/o problems. The Kappa for example has low BL and a 'not-that-stiff' cone and so it won't gain 3dB by coupling in bigger stacks if you double the number. Also, the bass range will get 'soft' instead of hard-hitting.... This is of course not a 'hard edge' process.... it's not that you have 4 and everything is fine and five will ruin every thing.... it gets worse by increasing numbers up to the point where further adding of horns won't gain anything (considered that the 'stand alone loading' of one HD15 is already high) but the size of the array (which will result in higher throw.....)
Date Posted: 19 November 2004 at 1:50am
Quote This rule only applies as long as the driver can push the air w/o problems. The Kappa for example has low BL and a 'not-that-stiff' cone and so it won't gain 3dB by coupling in bigger stacks if you double the number.
?? Can you explain that a bit more, I don't see the relation with not increasing SPL within a quarterwavelenght. I don't see what the stifness of the cone or the Bl for that matter has to do with it. And what do you call bigger stacks?
Btw. a Bl of 18,6 N/A isn't that low for a 15"
Date Posted: 19 November 2004 at 2:22pm
kkkk
www.tb-audio.de
SPL tracking
DBlimits
www.dblimits.com
Posted By: Dom
Date Posted: 19 November 2004 at 6:26pm
Originally posted by tthorsten tthorsten wrote:
could you just measure ..... 24 hd15s
Of course, I'll just go load the van up now...
Back in a jiffy...
Posted By: loophole
Date Posted: 19 November 2004 at 6:47pm
hey dom, while you're at it, do you think you could finish some cabinets for me? i only need you to make me a few labhorns, but remember to only use flint tools, i have a real thing about traditional woodworking. maybe if you bought a couple of dancestacks along as well i could have a listen to decide what i prefer.
if you do a really nice job i'll let you do the door at one of our hackney parties - i'll even let you keep any weapons you confiscate, i promise!
